Question about Symphonic WF803 DVD Player/VCR
DVD's willl not play, the problem signal at the right top shows it rotating, but a message indicating a playback feature is not on the disc. Tried several disks that work fine on my computer with the same result. An audio CD plays well.
  • 6 more comments
  • scbce May 02, 2010
    Thanks. I have been fixing electronic equipment since the 8 track and tube TV days but this one blew me away. Does the laser block for the DVD need to be replaced or fixed?
    Thanks. another quick and useful solution from FixYa.
  • Anonymous Mar 11, 2014
    1996 ford mustang 4.6 wont crank over.but it will start if its push started.
    br9 breadmaker recipe
    My Benz SEL 380 with 116 engine looses power after driving 1 km stretch. If you switch of it builds the power and once more loos after onother one Kms. I have changed the fuel pump, ignition coil and igniters. Kindly advice
    Porter cable pressure washer won't keep running
    plugged in all night not charged and will not come on. tablet is only 1 year old
  • Anonymous Mar 12, 2014
    key turns but no lights light up on dashboard
  • 10,594 Answers
Laser Optical Block has inbuilt 2 sections, dvd and cd. Symptom shows dvd section of laser optical block in your combo player got bad and complete laser optical unit need to be replaced.
It is qualified technician job to replace it as it is not user level repair. Please check with local tv repair shop to get it fix.
Hope this info will help you.
Thanks.
Posted on May 02, 2010
  • Shahid Electronics
    Shahid Electronics May 02, 2010
    Good to know that, great.
    Laser optical block will be replaced as its not repairable thing. If you open the unit, you will see its near spindle motor that spins the disc.
    Thanks.
My DVD and VCR in one has always played DVDs, and now when I tried to play a DVD, it says playback feature may not be available on this disc. I've played the same DVD on the same tv perfectly before!!
sometimes the discs get scratched enough that the player has difficulty reading them, using some car wax on the disc to clean it may help
Mar 09, 2013 | Televison & Video
Unable to get any dvd to play.
It should also play---most likely a dirty or bad Optical Pickup in the unit---try to record a disc and play back on another unit?
Nov 02, 2012 | Televison & Video
After recording a number of discs and finalizing them I checked them out on the recorder and also on my MacBook Pro computer & they all worked. Now I wanted to play them back but I am getting
Have you tried the disks on different playback units. Those laser mechanisms do go bad after a while when they lose their ability to focus on disk surface. If other machines have same issue it may be the disk(s). If not, it may be the player. check it out since you have nothing to lose but a little time.
Sep 06, 2017 | Televison & Video
Disc error: Playback feature may not be available on this disc
Ok well I have a brand new disc from the store with Percy Jackson movie on it and it will not play. The disc plays in other players in the house and other discs play in the player just not this one.
Aug 18, 2009 | Philips Magnavox DVD/VCR Dual Player
Disc error "playback feature may not be available on this disc"
Hello arnita2211,
This error message is due to an improper format, that your dvd player can't handle. To correct this you need to use a program such as nero and in nero is a program called nero vision, that will recode the movie file into a dvd playable format.
You can download a trial of nero here
http://www.nero.com/enu/downloads-nero9-trial.php
You will have to purchase a license when the trial ends. Sorry we cannot give you a serial key for this as it is Illegal.
Thank you for trying Fixya!
Apr 08, 2009 | Philips Magnavox DVD/VCR Dual Player
the message you are getting is the machines waay of telling you that it can not read that disc. which means you will have to burn your discs in a different format. or your are using a type of disc it does not recognize.
tom
Dec 26, 2008 | Televison & Video
DVV Player won't play disc
Check to make sure your player can play other disks. If so then use the disk doctor to remove the scratches on your favorite disk. The area that all DVD players scan before playing a disk is probably smudged or scratched.
Nov 21, 2008 | Philips DVP3345V/17 DVD Player/VCR
ERROR MESSAGE:
If these disks have not been finialized then they will not play on the dvd player. Turn your computer on and see if they will play. If they will then you will need to the dvd palyer finialize them. I hope this helps you. If not get back to me and then we can try a different way.
Aug 15, 2008 | Hitachi 168589 DVD Player/VCR
DVD player problem
You may have had a brief power outage you did not know about. Then the DVD player needs to be unplugged from the wall and started up again or your lens may need to be cleaned Because your dvd player is only made to play region 1 discs and vcd's are region 2. You need to buy a dvd player which will play all region discs or is rated region 0 which is the same. www.dvdenergy.com/index.htm
Aug 06, 2007 | Sylvania SRCD227 27 in. TV/DVD Combo
Open Questions:
Symphonic WF803 DVD Player/VCR Logo
49 people viewed this question
Top Symphonic Televison & Video Experts
SHARCNET-USA
SHARCNET-USA
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
