Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Corsa when i brake there is a noise coming from the drivers side it sounds like water gluging
  • Buck Whyte
    Buck Whyte May 11, 2010
    your washing machine has a break you use? how neet :)
  • 525 Answers
I think this belongs in the automotive section
Posted on May 27, 2008
Water in footwell of corsa
HI yes 100% brake servo plate its a common on corsa c and combo vans water in the driver footwell and rear driver footwell. dealers are charging a fortune to replace the plate and you will see lots of videos on youtube on how to repair it without taking out the brake servo. fact is the servo needs to come out to carry out a good repair.
Aug 19, 2014 | Vauxhall Astra Cars & Trucks
I have a strange, intermittent squealing noise coming from the driver's side front. It sounds like it's coming from the tire, and when I put on the brakes it seems to affect it.
That sounds like the wear indicators are causing the squealing. They are a small piece of metal attatched to the brake pad, that when the pads wear down to a certain point, they began to touch the rotor when the brakes are applied and make a squealing noise to let you know you should check/replace your brake pads.
Nov 06, 2010 | 1993 Ford Probe
2004 Hyundai Santa Fe? squeaky noise frnt driver side wheel
I do think the same way. If the pads look flat and not so worn have the rotor turned to eliminate the squeaksyou are encountering
May 31, 2010 | 2004 Hyundai Santa Fe
The water will not completely drain between the drum and the side of the washer.
u need to replace the water pump on the washer under the drum it is gett gluged up
Apr 09, 2010 | Maytag Neptune MAH5500B Front Load Washer
Clunking noise when braking drivers front wheel
sounds like your wishbone bushes are worn,allowing movment in them when braking.
Jan 16, 2010 | 2001 Chrysler LHS
Screeching noise coming from driver side tire
The high pitch sound may come from the brake pads as metal parts hit the disc to signal the owner that it needs change. The metal parts gets exposed when the pads have worn out. The brake also has a hub to cover the disc. See if the metal plate is hitting it but this issue would appear when the wheels are in motion. Check if it is the belts, have the tension checked out. Other than that the bearings are the other items on your wheel that could cause a high pitched sound when you car is in motion.
Aug 09, 2009 | 2005 Dodge Neon
Noise from drivers side
hi how are you.there is a couple of things that will cause a rubbing sound.if it is a high pich sound then look at your dust cover behind your brake rotor.a low pich or a growling noise check your wheel bearing/hub assembly.with wheel off the ground wiggle it side to side and up and down you will have alot of play.or there is something hitting the tire.
Feb 02, 2009 | 2001 Daewoo Lanos
Clicking sound coming from the driver's side rear by the tire
We just recently purchased a 2000 Expedition. It is wonderful shape but it has started making a ticking noise from under the hood , when you start it. Can anyone help us?248c23f.jpg
Dec 26, 2008 | 2000 Ford Expedition
My car
This the time when you should no use your horn.......................
Mar 25, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
35 people viewed this question
Dan Webster
Dan Webster
Sal De
