Question about Epson Stylus Photo R1800 InkJet Printer
My Cyan and Blue cartridges are not printing - despite head cleaning three times their nozzles seem to be blocked. How do I clean the print head manually?
  • 4,041 Answers
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on May 02, 2010
Testimonial: "Thanks for your advice - I was able to rectify by changing the cartridges. Thanks anyway, Pineworks. Da Iawn."
Epson Sx415 New Cartridge,empty already?!?!
1. New original ink tank will dried for several times of head cleaning procedure.
. ....ran a nozzle check and cleaned print heads because it wasn't printing any ink on the paper.... ???
Nothing at all? If yes, problem is in the printer main board. Lost electricity to the head.
Jan 13, 2013 | Epson Office Equipment & Supplies
Wont print blue
Blocked print head nozzles
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked cyan print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required.
Oct 17, 2012 | HP Officejet Pro 8500 Wireless All-In-One...
HP Officejet 6310 will not print cyan
The Cyan print head nozzle maybe blocked.
If deep cleaning does not fix it then you need a new print head.
The cost of a new print head is expensive and it maybe better to get a new printer.
Oct 15, 2012 | HP Officejet 6310 All-In-One InkJet...
Printing colour is wrong, colours come out pink. Nozzle check indicates cyan colour is not printing. I have carried out cleaning, deep cleaning. I've cleaned the print head and finally just replaced the...
> replaced the print head
Did you replace the tri-colour ink-cartridge, or did you replace the print-head mechanism?
Are you sure that the CYAN part of the ink-cartridge is not empty?
Mar 09, 2011 | Canon i9900 InkJet Photo Printer
Despite cleaning ink head many times, the yellow cartridge seems blocked as colour not showing
You will have to clean the print head, not just the ink cartridges. Here's how to clear blocked print heads:
-run several head cleanings and print the nozzle check pattern
-if that doesn't fix it, remove the cartridge(s) from the blocked head and drop alcohol where the ink enters the printer.
-reinsert the cartridges
-run one head cleaning
-wait about an hour then run some head cleanings.
-if no luck, you may want to dip the print head into Isopropyl Alcohol overnight (can get it from chemist)
-if it still doesn't work, your print head may be clogged to the point where it needs repair or replacement, which will probably cost more than a new printer.
Nov 30, 2010 | Office Equipment & Supplies
Will not print cyan
The cyan print head may be blocked. Try several deep cleaning of the print head to see if it can clear the blocked cyan print nozzles. Also check the cyan cartridge, make sure it is not empty.
If none of this works then the print head needs to be replaced. NOTE the print head is not a cheap item, you may consider putting the money towards a new and better printer.
Nov 13, 2010 | Canon I960 InkJet Photo Printer
Not printing yellow or blue despite full cartridges & clean head?
alcohol burnout print nozzles, you have ruined your printer head. you need to replace-it.
Feb 13, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Blue (CYAN) not printing despite changing ink tank
enough ink b ut not printing at all - blank paper on every time despite noise as if printing
Aug 17, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Epson Stylus Photo R1800 InkJet Printer Logo
567 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
