Question about Sony Bravia KDL-46V4100 46 in. LCD HDTV
I cant open the remote to put the battery in it shows an qarrow and says slide, but it wont move
    Sniper:
  • 52 Answers
Most remote control battery covers open in the same manner, although it will say slide in the direction of the arrow it will also require a small amount of downward pressure on the battery cover as well usually at the top end of the cover ( If you hold the remote with the arrow facing from you it will be the nearest end of the cover to you ). This is because on the underside of the cover there will be one or two small hooked clasps moulded into the cover that lock the cover into position the the remote control stopping it from just slipping it off and getting lost. The downward pressure on the battery cover disengages the clasps below the body of the remote, allowing the cover to then slide free giving you access to the battery compartment.
Hope this helps,
James
Posted on May 02, 2010
How do I reset my jangling j's-2000c universal remote control?
Pull the batteries out from the remote control, and leave it out until step-4
Press and release each and every button, one at a time on the remote control, until every button has been pressed and released at least once.
If the remote control have slide switches; move the switch to each position, then repeat the button pushing as in step-2. {When you've done, be sure to put the slide switch in the correct position to operate the unit the remote came with.}
Put the batteries back.
Jul 09, 2015 | Universal Televison & Video
MY NETFLIX REMOTE FROZE HOW TO I RESET IT
Try the remote.
http://electrohelponline.blogspot.com/
Jun 15, 2015 | Sony Video Game Consoles & Games
How can I open the battery door, it is stuck?
Like the manual shows you have to slide the cover and than it will come up.
But if you managed to put the batteries in the wrong way around, or even worse if you let them in for a very long time the door can be blocked by some pressure.
Please press the battery cover down, before you try to open it.
Perhaps you should knock or tap with a finger. Not to much force, but a few taps on the cover. Than again press is down, while sliding outwards. As soon as it moves, careful slide it further till it opens.
May 20, 2014 | Fuji finepix a805 8.3mp 3x digital camera...
2004 sat ion cant access trunk to charge battery
Put a battery charger on the starter solenoid terminal
& a good ground,charge the battery then open trunk
& replace the battery
Feb 22, 2014 | 2004 Saturn ION
Wii goes on shows disc, but charged up remote wont work and also cant get to the wii menu screen and cant sync it
Open up the back of the Wii remote and hold down the small red button by the batteries. I had this problem when I bought a second-hand remote and even the reset trick didn't work. If this continues to happen, please help both of us!
Feb 21, 2011 | Nintendo Wii Console
Cant open my programmable key pad safe. the code wont work
Locksmiths agree try replacing the batteries just slide open the battery cover located just below the keypad.
Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated.
reconnect the connector and put back the battery holder. Slide the cover back in place.
How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safes my locksmith recommended me To install batteries,
turn the electronic lock case to the right and remove. Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
Aug 12, 2010 | Sentry Fireproof Safe
Replace batteries in remote CT-9969
there is a slide cover at the bottom of remote control. slide downside to open and then you will find a battery logo and a direction sign at the left bottom. do as what it shows and you will find battery compartment. good luck - annie
Aug 14, 2009 | Toshiba 62HMX84 62" Rear Projection HDTV
Cant find where to change the batteries in the remote... There is no obvious place to put them unless we try to bust it open. Help!
Heya Harvey,
On the panasonic remotes the batteries are under the slide down part of your remote. Where you slide the face down to expose more buttons keep sliding it down abit more and you should find two aa batts.
If this dosent make sense or you would like me to send a link for the remote let me know.
If you have any other problems please feel free to contact me
Thankyou for using fixya
Apr 21, 2009 | Heating & Cooling
Gas door how do i open it 2000 bmw 3231 remote is dead
The remote battery is not rechargeable but, it is replaceable. Most dealers and jewelry stores have
replacement batteries.
Apr 01, 2009 | 2000 BMW 3 Series
Remote unit slides open but cant find battery cover-model AR-DL10
When sliding the bottom part of the remote down, you have to lift it slightly (I did this with a letter opener - very carefully) to pry the door up from two stops that normally prevent the dorr from sliding down too far. If you look carefully, you can see what I mean.
Feb 04, 2009 | Fujitsu 24C1 Air Conditioner
Sony Bravia KDL-46V4100 46 in. LCD HDTV Logo
642 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
