Question about Sony Playstation 3 (PS3) Console
After playing for about an hour it shut itself down and the red light blinks but it start again.
  • 4,102 Answers
Hi this is a very common problem. the reason its doing this is due to the fact it is over heating, so here is a list of things you need to do to try and solve this problem.
1. unplug all wires and check all the air vents in the ps3's outer casing if any of them have a build up of dust then use a vac and vac these vents out removing any dust build up.
2. make sure your not using the ps3 whilst it is resting on carpet or any other heat source such as dvd player, sky box ,cable box basically your ps3 needs to be on a flat surface not carpet and it also must not be on top of any other electrical device as this will cause heat to build up.
3. if after doing those your still having problems then you could go out and buy a stand so that you can stand your ps3 up and doing this should stop it cutting off.
if after doing this it still cuts off then this would mean that damage has been done due to the first time it over heated the most likely problem is going to be with the heat transfer putty that goes between the processor's chip and the cooling fan elements now this can be repaired but its not the kind of job you can do yourself.
if you have any warranty left then your best option would be to take it back to where you got it from and get an exchange, if how ever your warranty has run out then you need to contact sony and find your nearest repair shop and ask them to see if they will repair it for you, now depending on how old yours is would depend on whether they will charge for the repair.
the problem with ps3's is that the processor is not getting cooled properly now sony can fit a better fan that combats this problem but if yours is one with the new fan then the chances are you will have to pay for the repair but if yours is the old type fan then they may fix it for free, contact sony and see what they say, that is if the problem is not solved by the ways i have told you.
Posted on May 02, 2010
Tv comes on with picture and then shuts down to red blinking light
It will be the LAMP the only last between 5,000 to 8,000 playing hours so if your not watching TV turn it off.
Jun 03, 2015 | Mitsubishi WD-60735 Projection Television
Why would my Hitachi rear projection turns itself off then red light is blinking
The power supply could be failing and shutting down periodically.
Jul 25, 2014 | Hitachi Televison & Video
I was playing Cod4 online, when it froze for a second, red light came on the console, and the console shut down. Now when i try to start up again, the fan comes on for a second, along with the normal green...
Check ur console first, then test the hard drive, then unplug the console from the wall for about half an hour and then plug it back in. The next step you can do to fix red light of death is to see if you still have a valid warranty for your gaming console and then Go online to expert sites which will show you some online programs that will fix PS3 red light blinking in just an hour better u download repair guide
click here to download repair guide
Dec 15, 2010 | Sony Playstation 3 (PS3) Console
My hitachi plasma tv model: p55t551 every time i
turn tv on the red power light comes on then goes off again
Jun 27, 2010 | Televison & Video
I have a Rinnai heating system 556F that shut off by itself and the lights start blinking. when I start it again it will start right away but it won't last long till it shut off again (1.5 hours). any...
This unit has a diagnostic error code recorder. To play back your error codes, with the unit off, push the up arrow, down arrow and economy button all at the same time and hold for 3 seconds. Record each number that lights up. In your owners manual or on rinnai.us there is a error code guide that may help. Or post the error codes on Fixya and I can give you some pointers.
Jan 27, 2010 | Honeywell Heating & Cooling
No video or audio, but red blinking light is flashing
The Unit is Shutting itself down to protect itself from more damage, the light is blinking to let you know there is a problem, the problem could be a number of things, check the horizontal output transistor. It's a good Place to start for shut down problems
Dec 15, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KDF-50E2000 shuts down and blinks repeatedly twice.
The 2 blink error is a temperature error and the 6 blink error is a thermal fuse error. You may need to unplug the set and get you a can of canned air, take off the back lower cover and blow out all of the fans inside the set.
Oct 20, 2009 | Sony KDF-50E2000 50" HDTV
Playstation 3 at power on, light becomes white then blinks red
Probably and overheating problem. Here's what I suggest:
Try using some compressed air and cleaning the vents out below. If that doesn't work then you'll have to remove and replace the thermal compound on the GPU and CPU.
You might also consider a System Restore if you can do it before it shuts off.
Jan 24, 2009 | Sony Playstation 3 (PS3) Console
I have a sony wega
Generally speaking whent he set shuts itself down, the standby light will blink a code. This will be a count followed by a short pause and then the count again etc.
When teh set shuts down, count the blinks and post it here. That will indicate the circuit that has the problem.
Dan
Dec 05, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony Playstation 3 (PS3) Console Logo
54 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
