Sony vgn-s1xp won't power up
I have a sony vgn-s1xp (similar to s360), which won't power up at all, no lights. I checked the voltage on the motherboard and is the correct one. I think something has fried on the motherboard. I need help to locate this part and fix it. Replacement of motherboard is out of question (600-900$). Please help
  • 1 more comment
  • getvas Dec 14, 2008
    I have the same problem, when I connect my laptop to the DC power with out a battery it would never turn on. Unless I connect the battery to the notebook.
    Please let me know the solution to solve this problem.
    Thanks
  • Randy107 Mar 21, 2009
    Hello Mike,
    Thanks for the detailed repair of a Sony VGN-S360P laptop that will not power up. I have tried all of your suggestions and the laptop is totally dead. I measured the voltage at the motherboard that comes in from the power jack and it shows approximately 16 volts which is correct. However the on-off switch does nothing. Typically when the computer is off the charge light will blink if it is plugged into AC power. That doesn't even happen. I think my computer has had a "stroke" and has coded. Do you have any other pertinent ideas?
    Please email me at sigma@mchsi.com.
    Randy
  • darryl coueslant May 11, 2010
    Is it as simple as the power switch itself?
    Novelist:
  • 156 Answers
Hi
Follow the procedure below to troubleshoot no power or the VGN-S1XP (VGN-S360) does not turn on.
While following this procedure, note the LED status at each step. This will provide additional information for further troubleshooting.
NOTE: Some computers are designed with hooks above the LCD screen that secure the lid when closed. A switch inside the holes below the touchpad [picture attached] detects when the lid is closed and latched. If the switch is stuck, the computer may not turn on properly. Check to make sure the switch is working properly.
Connect the AC adapter into a known working AC outlet and to the DC jack on the notebook.
NOTES: Do not connect the AC adapter to a surge protector or extension cord. If the DC jack on the computer is loose or damaged, the computer may require service. Some AC adapters have a POWER LED indicator and can be confirmed as receiving power by ensuring the LED is lit. If the AC adapter is damaged or the LED is not lit when plugged into a working AC outlet, the adapter must be replaced.
1. Attempt to turn on the computer. If same, press and hold the Power Switch for 15 seconds and try again.
2. If issue persists, remove the battery; disconnect the AC power adapter; press and hold the Power Switch for another 15 seconds.
3. Connect the AC power adapter. Attempt to turn on the computer. If the computer turns on without the battery, connect and charge the battery for 24 hours.
4. Disconnect all external devices that are connected to the computer. These devices include, but are not limited to, a modem, floppy disk drive, network connection, USB device, printer, keyboard, or mouse. Attempt to turn on the computer.
5. If issue persists, remove any additional Random Access Memory (RAM) that was installed in the computer and attempt to turn on the computer.
6. If same, remove all RAM and attempt to turn on the computer. Note beep codes and pattern.
Ensure to remove battery and disconnect AC before opening up the laptop to remove RAM. Electrostatic Discharge (ESD) precautions should also be adhered to.
NOTES: The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required. (In this case, the system board and or other parts may likely be faulty.)
Regards
Mike
Posted on Mar 27, 2008
Get a Mac
Posted on Jul 18, 2008
I would like to format my VGN-S360
hello. good day sir. maybe you can download a repair manual for the said PC notebook. here is a link where you can download it:
http://www.fixdevice.com/smanuals/file/41864.html
just type the code located below and click on the download link. hope this helps goodluck!
Apr 15, 2011 | Sony VAIO VGN-S360 Notebook
I can't log on bios for sony VGN- S1xp
Please restart the computer and try pressing the F10 or F8 Key to enter BIOS Setup. If the issue persists then it might be with the Keyboard or Hardware issue. In that case please contact Sony Service Center.The AC Adapter has to be used which is compatible with the particular model of the Notebook.
Mar 27, 2011 | Sony Vaio VGN S1XP Laptop Universal AC...
My friends sony vaio vgn-s1xp has all drivers except for the audio drivers. i have searched for days and cant find them, could someone help me please ?
i've just install xp windows to my sony vaio vgn-fs285h and i can't adjust brightness on screen, can anyone help
Jan 08, 2010 | Sony Computers & Internet
VGN-S1XP laptop will not power up despite resetting it.
have you tried taking the battery out and powering up without it in, if you get no power at all your charger is more than likely at fault. if you can power up then it is the battery or connections that are at fault
Oct 26, 2009 | Sony Computers & Internet
I need drivers for the sonvy vaio PCG-6F1L!
That is because the actual Sony model is VGN-S360.or VGN-S360P You should be able to verify it. The model nember is not on the bottom it is on the RH LCD hinge. I do not think you can download the drivers anywhere but you can try:
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNS360
or just buy aa set of recovery DVDs from Sony
If you have the VGN-S360:
http://servicesales.sel.sony.com/ecom/accessories/web/viewItemDetail.do?operation=getItemDetail&itemID=537841&searchOperation=modelSearch&searchText=VGNS360
If you have the VVGN-S360P then
http://servicesales.sel.sony.com/ecom/accessories/web/viewItemDetail.do?operation=getItemDetail&itemID=537842&searchOperation=modelSearch&searchText=VGNS360P
Mar 22, 2009 | Sony Computers & Internet
Computers & Internet Logo
1,793 people viewed this question
David Payne
David Payne
