Question about Dishwashers
Maytag model MDB100AWQ has four lights and clean blinking
Maytag model MDB100AWQ has four lights blinking when closed. Lights won't stop and machine won't start. Clean light also blinking. Tried turning off power and turning on. No luck.
  • 131 Answers
SOURCE: Whirpool Quiet III Clean light blinks
You, my friend, have the dreaded 'blinking clean light.' This means that the electronic control has detected that for three consecutive cycles,
1. the heater hasn't come on
OR
2. the water hasn't come into the dishwasher
OR
2.5. the water came in, but wasn't spraying around inside.
OR
3. the heater came on, but the temperature probe did not detect a 3 F degree rise in temp in a certain alotted time. (Is the water supply unusually cold?)
Originally, this fault code could happen if any of these happened just once. Now they program the elec control to wait until the 3rd consecutive ocurrence.
First, let's clear that fault code.
Since you did not mention any unusual sounds, I will assume the water is filling and spraying around inside.
Press 'heated dry', 'normal', 'heated dry', 'normal'. This activated the test cycle, and clears any fault codes. After 10 seconds, press 'cancel'. Open the door and carefully see if the heating element came on. (It should be hot.)
If it did come on, it's an intermittent problem, and could be related to the door switch. Some earlier models would allow the dishwasher to run with only one of the two contacts closed, but the heater would not come on. Be careful to close the door tight each time. They have redesigned the switch (or is it the door latch?) to ensure both contacts get closed.
If the heater did not come on, then you might need (in order of higest to lowest probability) a heater, a heater thermostat, or the electronic control board (heater relay.)
I haven't ever seen a failed temperature sensor, though it is theoretically possible.
You can continue using your dishwasher until it is repaired. Though, you may have to reset the fault code 2-3 times a week.
Posted on Mar 12, 2008
SOURCE: Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Posted on Mar 22, 2008
ngfam1
  • 639 Answers
SOURCE: i have the kitchenaid dishwasher
Dear friend,
ngfam at you service! happy to assist!
It's an electronic problem!
The lights are called codes and need to be diagnoed by a factory service person!!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 29, 2008
ngafm
  • 166 Answers
SOURCE: CLEAN and LIGHT WASH lights blink
peace,
Cut the power from the breaker source for 5 minutes. And it should reset the system!
Other wise you need hands on service
Posted on Sep 07, 2008
SOURCE: "Clean light" keeps blinking; dishwasher won't start new cycle
It says in the manual to check the heating element.
Posted on Sep 10, 2008
Maytag top load washer lights blink twice and stops working
Probably a error code. Check your Owner's manual, Troubleshooting section. No answer, try MFG customer service.
You may try unplug for several hrs. Black box may reset.
Feb 27, 2015 | Maytag Washing Machines
How to run a diagnostic for washer model MHWE450WW01 Maytag
Starting Error History Software Version and
Diagnostic Test:
NOTE: Washer must be empty and the control must be in the
OFF state.
1. Close the door.
2. Select any one key (except "STOP/CANCEL" and "CONTROL
LOCK" and follow the steps below using the same key:
Press/hold for 2-5 seconds, Release for 2-5 sec, Press/hold for 2-5 sec, Release for 2-5sec, Press/hold for 2-5 sec
3. Upon release, all yellow/green console LED lights will turn ON
for 5 sec.
4. If there are any failure codes stored by the washer, the display
shows them.
Note: The last four errors will be displayed.
5. Press the same key to advance to the next code.
6. After the indication of error codes, the UI, CCU, and MCU SW
version will be displayed.
7. The number of cycles since last clean washer cycle is displayed.
8. All green console LED lights will turn ON for 5 seconds.
9. Next the washer begins the automated diagnostic test.
10.To cancel out of service mode, press the "STOP" button.
Apr 10, 2014 | Maytag Washing Machines
MDB7749AWB
Hello I had the same issue the sequence for resetting the panel is;
heated dry...normal...heated dry...normal
all the lights will go on then off. on my machine it started the normal wash cycle. I let it run normally so far this worked.
Hope this helps.
Dec 30, 2011 | Maytag MDB7749AWB Builtin Dishwasher
Blinking "Normal" light on a Maytag model
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
Hope this helps... Please post back if you need more information.
Daniel
May 19, 2011 | Maytag Dishwasher
Maytag mdb/c-2 some lights are blinking and won´t stop. I can´t start the cycle of cleaning, well really i can´t start anything. Please any sugestion ?
press the "off" button and hold it down for several seconds. this worked for me when i encountered the same problem on my maytag jetclean this weekend. it reset my control panel and now it's working great!
Sep 11, 2010 | Maytag 24 in. MDB5600A Jetclean II...
Lights on the Asko D1996 keep blinking
This depends on the blinking pattern. Of the eight lights on the panel, if the four on the left blink on and then the right four lights blink on as the left ones go off, and keep blinking back and forth, that just means the mode has been set and the Start button pressed. After closing the door it should just continue on wherever it is in the cycle. (This is normal operation).
If you hold down the Start button, this resets the dishwasher. If you then close the door, nothing will happen because it thinks it's done.
If the lights are blinking in a different pattern, such as they all blink on and off in unison, that indicates an error condition and needs to be diagnosed. If the pump is not running constantly, then at least it's not because water is leaking out somewhere.
Sep 23, 2008 | Asko D1996SS Built-in Dishwasher
Kenmore dishwasher, model 665.170 344 01. "Clean" light keeps flashing and will not stop. Have tried everything in the manual and the light still will not stop flashing.
If the clean light flashes 7 times, pauses then repeats...
If the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive).
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Jul 18, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Lights flashing
The flashing lights usually indicate a jam or the flapper door not met which means a drink already dispensed. Just guessing here, but you may have a board problem. I have removed one dispensing drive motor and if I press that button all lights blink until I open the door and close it. Any chance you have a lot of ice buildup in the back? That could be causing a short or even caused connectors to loosen. A new connector board is $22 on partselect.com but that would again only be a guess. Check some of the other problems listed for other possibilities.
Jan 13, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Dishwashers Logo
Top Dishwashers Experts
