Question about Midland 1001Z 40-Channels Base CB Radio
No talking my cb has power but all im getting is a noise and no talking at all
  • Melanie Rogers May 11, 2010
    what kind of antenna do you have and how do you have it and your radio mounted
    Champion:
  • 219 Answers
This could be several things, first I'd look at your antenna system,make sure its matched to your truck. When I say this you need a good ground good coax at least 18 foot,the mount and it installed right and the right kind of antenna, they make many different one because not all work on what you're installing it on. Then I'd check your mic if it has a broke wire it can also cause the problem you're having, most midland mics are wired different so don't just find another one.
Posted on May 08, 2010
I have cobra 29 mobile cb an every now an then it dies out . Power is on on noise I can key the mike an the needle don't move an can't here talking
May be a chip inside there that controls receive and transmit. Its about a 16 pin chip. If its getting hot. you may need a new one.
May 19, 2011 | Cobra Radio Communications
I have lots of motor noise. when i unplug antenna it stops
The motor noise comes through power wires and antenna pickup. Get an old ferrite bar out of an old junk AM radio. That black bar with wire wound on it inside AM/FM radios. Tape it to your Antenna coax or try to add 2 of them. Just tape them to the coax at about 6" inches from your radio. Try to add a power wire filter to the RED(+) 12 volt wire and Black wire(-) to your radio. A power filter is just a Ferrite bead or small bar with about 10 wounds of wire and a 470uf capacitor from (+) to ground(black -). Make sure polarity on capacitor is wired (+)(-) that way too. Radio Shack has a "Power" line noise filter kit, that hooks up under your dash. Ask Radio Shack personnel about this they will help you locate a "noise filter" for noisy alternators.Its simple, also, your radio is doing a fine job if it picks up that sensitive through the antenna. That just shows you your antenna is doing a good job. I had a problem like that --I only talked on my CB with the ignition turned off though, it made since to park and talk.
Apr 21, 2011 | Cobra 29 LTD CB Radio
Well i dont really know much about this cobra 20 plus cb lol i know its old. but im trying to see if it is working well i got it hooked up to a battery and the antenna plugged in and it comes on but im not...
check the speaker it may be dry rotted and not working.use an external speaker. depending on the time of day you probably couldn't reach any one any way Get a friend to talk on another radio while you listen and then let him listen for you.
Dec 10, 2010 | Cobra 18 WX ST 40-Channels Base CB Radio
Whinning noise when talking
The antenna could be at fault causing feedback into the radio. check with a good SWR meter to confirm this. Also check the power lead to the radio, try to connect directly to the battery.....
Feb 21, 2010 | Cobra 18 WX ST 40-Channels Base CB Radio
My magnum when i key up it blows the fuse,what could it be?
check your aerial for open/short circuit/power wiring to cb in truck/upgrade the fuse by 1 amp/mike wiring (tx/rx) if the cb shop could'nt find anything wrong then the faults in the truck/aerial/power? or the cb shops not up to much! you could have a faulty output transistor in the cb if all else fails?
May 09, 2009 | Magnum S6 Base CB Radio
Rushing sound (noise) galaxy 88 HL
RUSHING SOUND ?
1. Get the noise then disconnect the coax and see if noise goes away on receive, if noise goes away then address the ground on your antenna,
if noise still there then address the ground wire from power source
Mar 30, 2009 | Galaxy Radios DX- 88HL Base CB Radio
Noise on cb when truck is running
You might try running an insulated wire and ground directly from the battery.
Apr 07, 2008 | Cobra 19 DX IV CB Radio
Midland 1001Z 40-Channels Base CB Radio Logo
Top Midland Radio Communications Experts
Steve
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
