Question about Cardo Scala-rider Wireless Headset
Scala Teamset sync problem
Driver set goes into pairing mode but passenger unit only blinks blue. Does not go into pairing mode or give red light after a long time. Press the passenger set button again you will get a red light indicating power off.
Set worked out of the box 4 months ago. Problem first appeared when passenger could hear driver but not the reverse. Tried sync procedure in the quick guide but now neither unit hears the other.
2 Suggested Answers
SOURCE: scala-600 discoverable mode
Hey you just have to hold the on/off button untill it starts rapidly turning blue/red, do you by any chance know the defualt code i lost the manual for it sadly
Posted on Dec 28, 2008
My one set of Scala Rider teamset pro will not let the second set talk to it but the microphone works- any solution?
Do the 2 units pair up when you switch on ? If they do try swapping the units to see if the problem changes from one helmet to the other.
If it does then the problem is with one of the units, if it stays with one helmet then it may be a wiring problem to the speakers.If they dont pairup when you switch on try re-setting the pairing and start again. With the unit turned on, press and hold the CTRL button for 6 seconds till the light flashes red then blue rapidly then press the volume up button for 3 secs, the red/blue should flash 5 times to confirm reset done. Then re pair the units for intercom, switch both units on, when they are flashing slow blue on one unit press the CTRL and Intercom Buttons simultaneously for 6 secs so the red light flashes rapidly, repeat for the 2nd unit, they should both go to a solid red light within a few seconds then slow flash blue to show they have paired for intercom use. If this does not cure the problem you will probably have to send the units for repair.
Hope this helps
Tim
Jul 03, 2014 | Cardo Scala Rider Teamset Pro
Not pairing with other devices
Have you turned blue tooth settings on your phone? Also you can pair your phone if the Bluetooth is working. Otherwuse you may be out of range. If that does not work have someone else try the bluetooth to eliminate the problem is with your phone.
Nov 15, 2013 | Cardo Scala Rider Teamset Pro
Scala rider connects to phone 1 and phone 2 and after 10-15 seconds it shut down
give it back. I also have problems with my Scala rider Q1 system. I would not pay R 200 FOR THIS TYPE OF RECEPTION and i have payed R3000. Bad deal.
Oct 29, 2013 | Scala-Rider Cardo Scala Rider Q1 TeamSet...
What is the passcode for the Scala LX700 bluetooth?
Four zeros is the PIN you want to use for pairing
  • 0000
That's also the default code for a majority of bluetooth headsets.
Here is the entire pairing process broken down:
1. Turn on your phone and make sure that its Bluetooth function is activated.
2. While the Headset is turned off, press the Wheel inwards for at least
8 seconds. The Status Light will begin rapidly alternating red and blue,
indicating that the Headset is in Pairing mode.
3. Using your phone, search for Bluetooth devices by following the
phone’s instructions.
4. After a few seconds the phone will list the scala-700LX as a “discovered
device”. Select it and follow your phone’s instructions to accept the pairing.
5. When prompted, enter 0000 (four zeros) as your PIN or passkey.
6. Your phone will confirm that Pairing was successful and the Headset’s
Status Light will begin flashing slowly in blue.
Apr 22, 2010 | Cardo scala 700LX Bluetooth Headset
How to connect with bluetooh
You need to:
  1. ensure the bluetoothicon1.png setting is turned on on the handset
  2. switch on the scala 500
  3. press and hold the scala 500 power button until the red and blue lights are both flashing (you have to hold the button in for quite a few seconds)
  4. now you can search for new bluetooth devices from your handset and it should find it to enable you to connect
  5. if it asks you for a code/passcode the default is 0000 for this headset
Sep 20, 2009 | Motorola Mobility Cardo Scala 500...
My Lg Decoy wont sync with my Motorolla bluetooth
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above.
Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Jun 05, 2009 | T-Mobile 81339TMIN T?•MOBILE BLUETOOTH...
Can't get existing bluetooth headset to work with new phone
I had that problem when I changed handsets. You need to:
  1. ensure the bluetooth setting is turned on on the handset
Jan 27, 2009 | Cardo scala-500 Wireless Headset
Scala-600 discoverable mode
Dec 08, 2008 | Cardo scala-600 Wireless Headset
How to put my headset in pairing mode
Do not use the power button to sync.
To sync device, Press + button (volume) and Silver button (on boom) at simultaneously. LED Light will blink RED & BLUE. Device ID should appear on your screen.
sometimes it is tricky and you do have to turn on the power
so try it both ways and if the power is on hold the 2 buttons for about 30 seconds to 1 minute if the light stays blue turn off and try again they are not easy to sync the code for pairing if they ask you for 1 is 0000
Dec 03, 2008 | Plantronics 510 Voyager Headset - PLN-510...
Cardo scala rider operators manual
the ususal way to turn on a scala rider headset is to hold the symbol fo rabout 5 seconds then hold just behind the symbol for another 5 sec's untill the light blinks red and blue then it will be able to link to your phone for the first time. if it links automatically or you have already linked it then just let it do its thing near the back you will find a sectioned off aread and in the center it will have a raised button that is the talk / answer / redial button just forward of that there is a button (the one that you held to make it blink red and blue) that is the voice dial button the icon itself is just for on/off the two raised areas on the back next to the charge port are the volume buttons up/down respectively
Oct 04, 2007 | Lands Phones
Cardo Scala-rider  Wireless Headset Logo
107 people viewed this question
Top Cardo Radio Communications Experts
vimal
vimal
richie46
Tom Chichester
Are you a Cardo Radio Communication Expert? Answer questions, earn points and help others
