Memory problems hi my name is mike and i have a problem with a msi mother memory it will only handle 1gb of memory even though it can take up to 8gb all memory is working because i tryed them separtleybut it freezes up when i try them toghter they are duel channel and the processor is a 3600+ also tryed them in differance slots the memories are 5300
  • JelleDeceuni May 07, 2008
    I have the same problem.
    I have a Kingston 512MB and a Apacer 512MB, same speed.
    My motherboard is an Intel D915GPN 3,2Ghz
    The RAM is working fine separated but if I put the 2 together my pc does boot.
    Can someone help me please....
    Novelist:
  • 104 Answers
Mmm thats something hard to figoure out... memory can be failing and it does not matter that you can dettect it one by one... so with that info is impossible to know whats happening... what I can tell you is that if you are running windows XP... you will waste 4 GB cuz XP can only manage 4 giga in good shape... the rest will not be much usefull...
for now try this and if it does not work come back with more info please...
1. Just connect only the basics... motherboard, cpu, vga adapter and power supply, nothing else.
2. Make sure the BIOS config is OK, read the manual to find any missing pieces on that matter. Check the jumpers part very carefuly... Your motherboard manual will tell you about RAM configuration posibilities and perfect matches.
3. Put ONE DIMM in the first slot, if it works turn off and try that same dimm in all slots... do that with all dimms and you will know if all dimms are at least booting and all slots are working at least to boot (which does not means everything is perfect) Motherboards can and will fail "whenever they want"...
if something fails you clearly have some kind of hardware problem either compatibility or unknown failure.
4. If every piece is working just install 2 GB and boot... then the 3rd and well... while you can.
Finally if you succeeded in every point before and you still have problems... its likely you have a harware issue...
Good luck
Posted on Mar 26, 2008
    Sergeant:
  • 349 Answers
If you are using windows 32 bit o/s it can only see between 3 & 3.5 gig no matter how much you put in, vista 64 bit o/s can see more.
check that the memory is the same all ECC or not
do not mix them.
if they are all the same ,put them in then bootup and go into the bios then exit save changes (none done),
it may be ok then.
good luck
Terry
Hi my pc lost 4gb of ram out of 8gb.. amd quad 2x4-630 //msi 785gm-p45 model7623
Hi jcarter123,
It's okay Sir.
The 4GB of your RAM weren't lost.
The PC reads the whole 8GB of your memory but it can only display 4GB.
Hope this helps you a lot.
Thank you for using FixYa!
Nov 01, 2011 | MSI Computers & Internet
MSI motherboard - RC410M MS7173. I had 1 memory card of 1GB - Ceon DD2 533 CL4 I bought the exact same one again, so I would have 2GBs. The board couldn't recognize the 2 cards now. The board suppose to...
could be defective board with broken contact try switch 1gb ram chip from one slot to other see if it work in both if not you got your problem also switch the testing 1gb ram chip with other 1gb chip
Mar 02, 2011 | MSI RC410M-L Motherboard
MINHA PLACA-MÃE (MSI PM8M3-VH)É DDR OU
English is understood here.
Read your user manual or search for a download on the Internet.
http://www.msi.com/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=234
"Main Memory
• Supports two memory banks using two 184-pin DDR DIMM.
• Supports up to 2GB PC3200 (DDR400) SDRAMs.
• Supports 2.5v DDR SDRAM.
(For the updated supporting memory modules, please visit
http://www.msi.com.tw/program/products/mainboard/mbd/pro_mbd_trp_list.php )"
Oct 23, 2009 | NEC I/O Plate for Motherboard
My msi pm8pm mb doesn't accept 1gb memory pc667 its accept only 256mb pc533, what i need to do to accept 1 gb memory, pls help me!!!!!! tnx!!
Your MB can take a max of 2 GB RAM. And it has to be DDR SDRAM. So, please ensure that it is compatible. Then only would it accept the RAM SIMM else it may damage the mother board. or the RAM itself.
Oct 13, 2009 | MSI PM8M-V Motherboard
Memory synchronization Problem
Did you reset the cmos on board first?
Jan 18, 2009 | MSI K8N Neo3-F Motherboard
Memory channel mode
Hi shinde32, you should know that dual channel memory should be bought as a pair. Your board has two DIMM slots as you mentioned. The board can handle up to 2GB max memory, as you have mentioned. What you do not seem to know is it is required to use the same amount of memory is each slot. See the bottom of page 55 in your manual. (Do you need the manual)? Download at this link;
http://download.intel.com/support/motherboards/desktop/d102ggc2/sb/d4798502_en.pdf
There is not a bios setting where you can enable or disable memory channels. The bios configures the memory automatically. Intel has a list of memory tested & passed for the D102GGC2 Mb. You can see that list at this next link.
http://www.intel.com/technology/memory/ddr/valid/DDR2_sodimm_results.htm
Bottom line, both DIMM slots should have two 512MB DIMMS or two 1GB DIMM's. (Like this memory);
http://www.bzboyz.com/ProductDetails.asp?ProdID=18112
https://www.thefind.com/computers/info-spd-dual-channel-kit-memory
This is what your search would look like,
"1GB x 2 DDR2 dual channel 533MHz SPD memory".
The Certified "SPD" is important for Intel MB's.
Good luck shinde32!
Need more help, post here.
Thank you for using fixya.
Mike
Jan 15, 2009 | Intel D102GGC2 Motherboard
I have a problem with my ram
That motherboard does not have a video circuit built-in, so the video sharing the system RAM does not make sense.
Have you checked the valid system memory configurations in your MSI manual pg 2-7 ?
Any chance that the bios is set for dual channel and you don't have equal chip sizes in the dual slots? Example : In dual-channel mode, equal size chips would go in slots 1 & 3 and in 2 & 4
Defective RAM is a possibility also.
Note1: Per MSI, all ram may not register correctly in windows unless 4 of the 2GB chips are used
Oct 25, 2008 | MSI P7N Diamond Core 2 Quad/ Nforce 780i...
Memory Card Problems
According to the samsung website " Samsung camcorders manufactured in 2004 and later can be used with memory sticks up to 1GB. Anything over 1GB is not guaranteed to work. "
I have the same problem. Video works fine on my 256MB card but not on my 4GB or 8GB cards. It would be nice to know if anyone has success with a particular card >1GB.
Jun 03, 2008 | Samsung SC-D353 Mini DV Digital Camcorder
RE: mother board not going on
Hi marlonvig, what type of memory (PC3200? or PC2700) memory are you using? What type in which slot?
The decription (In you're manual), refering to you're memory can be confusing.
You're manual says you can use up to 1GB of
PC3200 DDR400MHz only in Slot 1.
If you add DDR400MHz into slot 2. The board will not support it. (weird)!
If you want to reach 2GB of memory. You must use PC2700 (DDR333)MHz. 2x1GB PC2700 = 1GB DIMMS in both DIMM 1 & 2. You're board does not support DDR2 type memory.
Need you're manual? Download it from this link. Click on it.
http://www.asrock.com/mb/manual.asp?Model=775VM800
Asrock's home page for you're 775VM800 board.
http://www.asrock.com/mb/overview.asp?Model=775VM800
Mike
Apr 28, 2008 | Asrock 775VM800 Motherboard
Maximum RAM not achiveable for KT4V
What Operating System and revision are you running?
I don't believe that XP 32bit (not sure about 64) will recognize 3GB of RAM, but Vista will as long as your MoBo (Mother Board) supports it or possibly even more than.
My Asus MoBo will utilize 4GB but Vista 32bit will only utilize 3.48GB or so, and Vista 64bit will take up to 8GB if the MoBo will.
Let us know what O.S. you're running?
Mar 12, 2008 | MSI KT4AV-L Motherboard
Computers & Internet Logo
445 people viewed this question
David Payne
David Payne
