Question about Pinnacle Studio Ultimate 12 for PC
I want to convert an avi file to STX to edit it
I am making a tutorial with CamStudio but want to edit it with Pinnacle Studio Ultimate.
How do I convert the CamStudio avi file into a STX format for Pinnacle?
5 Suggested Answers
SOURCE: Quality issues archiving video as MPEG2 instead of AVI
This will not degrade the video quality.
Posted on Sep 23, 2009
Testimonial: "Thanks for that very prompt response. My only reluctance in not rating the help as "very helpful" is that you didn't give any reason with your comment"
hawkform
  • 217 Answers
SOURCE: Should Pinnacle Studio Ultimate 12 work on the new Microsoft 7
Yes Studio 12 will work good with Windows 7 32 or 64 bit
Posted on Dec 03, 2009
hawkform
  • 217 Answers
SOURCE: pinnacle studio 12 .stx fil
Hi and welcome to Fix yah,
I would suggest to you to finished edit your project and after that click on make movie tab or the number 3 tab of your Studio then do this procedure.
Disc Type : DVD
Audio Compression : PCM
Video Quality : Automatic
Use Progressive Encoding : NOT checked
Always Re-encode Entire Movie: Checked
Burn Options: Create Disc Content and then burn.
Current Media : Should show what DVD Disc should be used.
Target Media: DVD 4.7 GB
Copies : 1
Write Speed: lowest possible
Let me know what happen.
Posted on Feb 17, 2010
davevivek6
  • 20 Answers
SOURCE: My Pinnacle Studio 12 ultimate crashing
you should have to reinstall that.
it may be because of low video memory
if re installation does not work then download tuneup 2010 and clean physical memory .
still have problem then take another installation of it
Posted on Apr 24, 2010
Tip
How to convert MVI to AVI file for edit in Pinnacle Studio?
Some Canon digital still cameras (Powershot A75, A63, S410 etc), are capable of shooting a limited amount of video, since there is no tape, it is saved as an MVI file format. However, the MVI file format is not compatible with other programs. Even windows media player refuse to play MVI file. Besides, editing software like Pinnacle Studio and Windows movie maker do not work with the format. Because of this, the files need to be converted to a format that is more widely used, such as AVI so that these videos shot with still camera can be played and edited as easily as other common videos. This guide is to tell how to do that.
Software you'll Need: Pavtube Video Converter
Step 1. Download Pavtube Video Converter, and follow the prompts to install the program. Click "Finish" when the installation is complete, and Pavtube Video Converter will launch automatically.
Step 2. Click “Add” to load MVI files or directly drag the files into file list. By default, the files are selected. If you would like to join all the selected files together, check the box of Merge into one. You could view the files in preview window, simply highlight the file and click play button.
Step 3. Click “Format” bar to determine output format. Follow Common Video-> AVI Video (*.avi)/ DivX AVI(*.avi). Click “Settings” if you’d like to customize advanced audio and video parameters like Video Codec, aspect ratio, bit rate, frame rate, Audio codec, sampling rate, bit rate, channels. Do not forget to click “OK” to confirm your settings. Then type in a desired output location in the "Output" box.
Step 4. Click "Convert” to start converting MVI files to AVI. You could set auto shutdown in progress window or leave it there and come back later. After conversion you could edit the converted video in Pinnacle Studio, and make a film out of it or burn it onto DVD.
Learn more: http://www.pavtube.com/guide/convert-mvi-to-avi-for-edit-in-pinnacle-studio.html
on Mar 25, 2010 | Cameras
I have used CamStudio to successfully capture onscreen videos played via VLC (in AVI or FLV formats) - however it wont capture the videos in 3gp format played onscreen by VLC. All that I get is a black...
Your VLC doesn't support that format(3gp).you should convert that file into avi or flv,just download video converter like altysoft video converter for free...just type it in your browser then go..save the file and innstall.
hopes this helps and goodluck
Feb 18, 2011 | CamStudio
How to put .mov in pinnacle studio to edit
Welcome to Fixya,
.MOV file is not supported to used and import to your Studio 11. I suggest to you to go ahead and try to convert that file to mpeg or AVI.
Jul 15, 2010 | Pinnacle Studio Plus Version 11
Pinnacle won't accept mpeg videos how do I convert so that it will support it.
I will recommend to use the windows movie maker to convert the video.
Import the video to the m=program that I mentioned. Then export it to avi or mpeg 2 format. Once your done, Import the video to the pinnacle studio program.
Jun 19, 2010 | Pinnacle Studio Ultimate 12 for PC
Pinnacle studio 12 .stx fil
Disc Type : DVD
Copies : 1
Feb 14, 2010 | Pinnacle Studio Plus Version 11
My pinnacle 12 project opens as an empty project in pinnacle 14
Welcome to Fixyah,
Suggest for that if ever that the project wont open to your Studio 14 go back to your Studio 12 and then render it as File and used either AVI or MPEG then after that import that to your Stduio 14 the re edit the video again,.
Regards,
Joey
Dec 14, 2009 | Pinnacle Studio Ultimate 14 for PC
Mts files are out of sync when I import with Pinnacle 12 Ultimate what do I do?
AVCHD video Converter can play, edit and convert AVCHD files(.mts, .m2ts) simply by importing the footage from hard drive, the powerful codec pack designed within the program will then automatically analyze AVCHD format then transcode them to your delivery formats. All the process can be done within minimum time at fast speed, while original video quality is kept.
AVCHD video converter enables you to convert AVCHD to friendly video formats like avi, mpg, wmv, mp4, mov, flv, asf, rm so that you can easily work on them with Windows Movie Maker or Windows Media Player.
Nov 22, 2009 | Pinnacle Studio Ultimate 12 for PC
Video editing
Hi
In this case you need to convert it again. Lossless AVI format or HIGH QUALITY video format. Then drag it PINNACLE 12 and BURN.
Nov 20, 2008 | Pinnacle Studio Version 9 for PC
Pinnacle Studio Ultimate 12 for PC Logo
429 people viewed this question
Top Pinnacle Computers & Internet Experts
AL Schehr
AL Schehr
Level 1 Expert
Alun Cox
 Ian Kayhan
Ian Kayhan
Are you a Pinnacle Computer and Internet Expert? Answer questions, earn points and help others
