Question about PfaFF Creative 7570
I took my machine to be 'cleaned', and when I get it back the pressure foot has no pressure. I'm in Jacksonville FL and cannot find anyone that repairs Pfaff sewing machines (1473 CD). I need some help!
  • 632 Answers
Independent repair shops will work on any model, it's the parts they have no control of. The good thing is that we have ebay, where most hard to find parts always pop up. All or 95% of sewing machine stores here in Bay Area Ca. sell and service PFAFF, even vintage metal mechanical models.
Posted on Jun 19, 2010
  • 1 more comment
  • Debra Greene
    Debra Greene Sep 05, 2014
    this is not the way to fix it ! Not good a answer !
  • Ed Paje Sep 05, 2014
    Your right, I didn't mention how to fix it and that's really a no good answer. My mistake suggesting her where she might find hard to find parts from and maybe someone who is certified to fix it. Next person I'll help with PFAFF problem I'll send them to you. Thanks!
  • Debra Greene
    well if so many people have this problem on a Pfaff machine , we should be able to fix it . I am disabled and cant take my machine anwhere. Is there a easy fix or part ?
How can I run pressure foot selector switch
Pressure on foot is regulated by the screw on the top of the machine directly above the pressure foot bar. Make sure your lever on back of machine is down, then turn the screw by hand, left for less pressure and to the right for more pressure.
Has anyone adjusted the presser foot inside the machine? That can throw it off or sometimes you need to look under the machine head into the oil pan to make sure there isn't something stuck and holding the pressure up from there.
Is this a new or used machine? Does it have enough oil in the pan?
Jul 13, 2016 | Juki DDL-8700
How do I put my foot controller back together, I took it apart because it will not turn off. My model # 66 - AA307535. Controller # 192257
more than likely, your variable resistor in the foot pedal is shot. cleaning is a low probability repair. replace the pedal assembly.
Oct 19, 2014 | Singer Sewing Machines
Pfaff 1371 pressure foot won't come down on it's own
I just addressed this issue with my 6110. There is a spring in the shaft for the pressure foot. Over time the white grease that lubricates the spring and the plastic piston at the top dried up, gumming up the works. I took it all apart, cleaned out the bad (now hard grease), re-greased and put it all back together. Works like new. I used a lithium grease as it is easy on plastic parts.
Sep 04, 2012 | PfaFF Sewing Machines
How to open front of janome 8050
You typically don't need to remove panels to clean the upper tension. Just take some un-waxed dental floss and run it through the tension area a good few times while the pressure foot is in the UP position..
Remember one thing about these "computerized sewing machines" Computers are DC power... otherwise known as "Direct Current" but more memorable because DC is also the "DEATH CURRENT."
Jul 22, 2012 | Janome Sewing Machines
How do I change the presser foot on an elna mini sewing machine?
I dodn't know your model really well but it will be one of the following:
a clip on foot that you just pull down on to remove,
a clip on foot with a button at the back of the pressure foot holder - press the button to release the foot
a clip on foot with a little lever at the back of the pressure foot holder - lift the lever to release the foot
If it is a clip on foot, then you just need to raise the pressure foot lever, put your fingers onto the pressure foot and press downwards, it should unclip.
To put one on, place the pressure foot onto the needle plate under the pressure foot bar and lower the pressure foot bar down onto the foot, lining up the base of the foot holder with the little bar on the foot, it should click into place.
Oct 10, 2011 | Elna 2007 Mechanical Sewing Machine
I have Singer Curvy 8763. It seems that the foot control stopped to work. The machine does not sew, its impossible to wind the bobbin. It is possible however to sew backwards with the help of reverse...
I be s 8763 was sewing beautifuly, took off pressure foot to make a buttonhole read the manual followed directions button holer kept gumming up with thread and the alarm kept going off, then got flustrated, put back on the sewing pressure foot now it is like the needle is out of line will not pick up bobbin, and is definately hitting something by the bobbin, will not sew
Nov 04, 2010 | Singer 8763 Curvy
Feed dogs are not pulling the material back
White sewing machine model 510, feed dog problem; fabric is not moving; I must firmly pull fabric through.
The feed dog is moving; fabric is not.
The fabric is not feeding properly; the fabric goes back and forth. However, the fabric does not continue to move away from me.
The feed dog is positioned up and is not smooth, it feels rough when I touch it with my fingers.
Because I had not used this sewing machine for a couple of years, before sewing, I cleaned the inside with the wire brush that came with the machine.
In an attempt to trouble shoot the problem, I applied varying pressure foot levels and stitch lengths.
Does anyone have any suggestions as to what may be the problem?
Jun 27, 2009 | Kenmore Sewing Machines
Cant find a web site for parts for my 1985 husky wr250
Viking Office products may have your part that you are looking for. Their phone# is 1.800.421.1222. They are in Jacksonville, FL. Also another source is Superior sewing machine & supply Corp. their phone# is 1.800.274.5808 they are located in NY, website: www.superiorsew.com.
Apr 12, 2009 | Husqvarna Viking 1
Machine foot will not work
Have you taken the foot control apart yet? What have you got to lose. Possibly something came loose that you can put back in place? There are small carbon contacts that may be put back in place. Just remember to put it back togeather the same way you took it apart. Or keep an eye on eBay and ask questions. Mostlikely a generic footcontrol will work. Good luck. Rick
Aug 20, 2007 | PfaFF Tiptronic 2040
Sewing Machines Logo
492 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
