Question about Nokia N95 Cellular Phone
N95 nokia hi the screen will not light up when the slider is opened. every thing else works ok
You may need to update the software on the phone!
Posted on Mar 25, 2008
N95 slider problem . LCD goes blank on sliding . it appears that there is problem in Strip. do u get separate strip or it comes alongwith slider....
No the Slider strip doesn't come separately because the strip is merged permanently to a circuit that has your earpiece ,light sensor,and front camera you cannot seperate it in any manner because the only unlockable part over there is the LCD screen .i would recommend you to get your phone serviced from nokia care only because the strip is the most important part in a slider .. even if you get a local strip installed from a local mobile repair center it wont last for a month ..even i had the same problem 4 months back ..because quality of the strip matters .......
Dec 28, 2010 | Nokia N95 Cellular Phone
Slider or ribbon problem
its a flex problem. The flex that connects the screen to the phone board is probably weak or has loosed contact.
This kind of problem is common with slide and flip phones. The flex worn out or get damaged because of the constant opening and close of the phone.
I would advice that you take the phone to a repairer to fix the problem for you.
Take care.
Mar 18, 2010 | Nokia N95 Cellular Phone
N95
hi friend,
go to website
www.sparepartsformobiles.co.uk/mobile_phone_spare_parts.asp?...%20ribbon%20with%20keypad...
Then consider changing the Flexi PCB (ribbon). This is a common failure as the ribbon can suffer wear as the phone slider opens and shuts. Eventually the ribbons become worn and often this results in a screen failure. Changing the ribbon can cure this in most cases... We advise that a new ribbon is added when the screen is changed it’s a good way to service this type of part. So if you do have a screen problem including a screen failure then consider changing this part before you spend good money on a screen.
thank u for using fixya
regards,
sivaranjini
Aug 11, 2009 | Nokia N95 Cellular Phone
I have a Nokia N95 8gb and in anger threw it across the room. Its is now well and truly broken. I have experiance with repairs, so have tried to repair it myself. I fixed the slider problem but on power...
You can find replacement LCD screens for N95 in this link. There is also a video explaining the installation:
http://www.pantallas.biz/epages/wwwpantallasbiz.sf/en_GB/?ObjectPath=/Shops/160419/Products/N95
Note that N95 and N95-8GB have different LCD screens.
I hope it helps.
Ignacio del Olmo
May 30, 2009 | Nokia N95 Smartphone
Nokia n95 8gb blank screen
hi the main problem is not in ur display screen. the lcd is ok. but inner connections might have got damaged.
Jan 19, 2009 | Nokia N95 Cellular Phone
Nokia n95 8gb
i think after all that you should replaced the mainboard
Oct 20, 2008 | Nokia N95 Cellular Phone
Can't see a thing on screen
hi sir
please remove the battery and memory card.. and after inserting the battery first for saffer side go to tools>settings>phone> restore factory setting . after restart insert memory card it work,s sir..
if doesn.t work mite memory card may be corrupted..
Sep 01, 2008 | Nokia N95 Cellular Phone
My nokia n95 its got a blank screen plz help
it's you flex, the ribbon that connects your board and lcd.. it maybe lifted... or you have to change the flex if there's a cut.. bring it to the center to replace or re attach it could be loose too...
Apr 18, 2008 | Nokia N95 Cellular Phone
Please help me with my nokia n95
its your flex (the ribbon that connects to u'r board and lcd.. it maybe disconnected, or it is broken have cuts.. it can be re attach or replace the flex..2nd it could also be u'r lcd, but i'm sure it's u'r flex... bring it to the pro's.
Nokia N95 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
