Question about Compaq Evo N610C Notebook
Battery Charging Dear, I tried to check the voltages of my laptop battery, but after this battery test light only blinks but my laptop does not charge this battery, Is there any possiblity to repair this battery
  • 55 Answers
There's no way to repair batteries once they stop holding a charge. you will need to buy a new one.
Posted on Mar 25, 2008
SOURCE:
Lenovo z570 not powering on
Measure the voltage at the AC Adapter plug, and see if it is within 5-10% of the rated voltage. If the voltage is not correct, then the battery will most likely not be charging, and the system will drain the battery and die in the middle of what it was doing...booting in your case.
You can tell how much voltage is remaining in your battery and if it is charging by checking the blinking of the battery status light.
Download the Hardware Maintenance Manual here:
http://download.lenovo.com/UserFiles/UserGuide/en/User%27s%20guides%20and%20manuals/Z370&Z470&Z570/Lenovo%20Z370Z470Z570%20Hardware%20Maintenance%20Manual%20V1.0.pdf
and go to page 30 and look at item 7 under battery status for blinking light meaning.
1. Blinking amber: (500ms off/1s on)
The remaining power of the battery is less than 5% of
its capacity.
2. Blinking amber: (100ms off/3.2s on)
The battery is being charged with the remaining
power between 5% and 20% of its capacity.
3. Amber: The computer is operating on battery power with the
remaining power between 5% and 20% of its
capacity
With the AC Adapter plugged in, and giving the correct voltage, If you are getting 1. Blinking Amber (light on for 1 sec, off for 1/2 second), then the battery is not being charged. Could be AC Adapter, Battery or Battery Circuit on motherboard. If the light is solid on 3. Amber, then the battery is not charging, and is draining.
Also make sure the power socket on the laptop is not loose or damaged. If it is, then it will need to be replaced.
I hope this gets you in the right direction.
Apr 25, 2014 | Lenovo IdeaPad Z570 Notebook
Toshiba l505.no power,blinking light battery for 6 time then stop ?
Can only guess your battery is bad. Try charging. If you have the only other way to find out is to check the battery and the voltage with a multi-meter and if it has a charge. If so, then it's a problem in your laptop
Sep 07, 2012 | Computers & Internet
Battery charging LED not lighting up when the laptop is put for charging and the laptop is not getting on.
probably the charger is not working right. Please check with with a spare charger or borrow with someone to check. if the laptop switches on the charger has the problem. Buy a new one with same specification to avoid further problems. and please dont forget to vote my answer with the thumbs up symbol below. thank you.
Jul 19, 2011 | Toshiba Satellite Pro 490CDT Notebook
Crazzy compaq 6910p when the battery is first pluged in all the lights blink, Only one led stays on and its a green speaker. if i hit the power button the charging light will blink 8 times. the speaker...
Your battery is bad and causing a problem. most likely it is feeding an incorrect voltage into the computer. replace teh battery and it should fix the problem. If you have already replaced the battery with a new one the charging system is faulty or the AC adapter.
Dec 23, 2010 | Computers & Internet
Hi, i have asus eee pc net book, what was the issue is...... when ever i try to charge my netbook when netbook is truned on, the adopter light is blinking. when the netbook is truned off its chargeing...
When the adopter light is blinking. when the net-book is turned off means that is charging, but if the light remains for a lobg period of time there is something wrong with the battery or the charger.
Here is small tool Imtec Battery Mark designed to test the battery laptop life. You can run laptop battery test in two modes (fast and normal) and Imtec Battery Mark will provide full assessment of your Laptop battery at the end of test.
The dead battery charger means the charger can not work : can not charge the laptop battery or can not run the laptop. When our laptop battery can not charge, we must check the battery and charger state. Now let me list the steps of test our battery and charger below.
Make sure the powerbook g4 battery charger cable is plugged in and the output is to power.
Look closely at the battery. Is there corrosion or leakage? If so, replace the inspiron 6400 battery immediately.
Test the charger. For DC chargers, a voltmeter set at 25 VDC and touch the contacts with the probes. The meter should read about more than 1 V Evaluation of the shipper. If the reading is zero, change battery catheters.
Testing a AC charger through the establishment of a voltmeter to 25 VAC. Tap the contact probes. The transformer in the charger is bad if you get no reading.
Check contacts. These are strips of metal or points in the appliance and charging cradle. With the batetry charger unplugged, clean with a cotton swab. Use a fine emery board to remove visible corrosion.
Dec 07, 2010 | ASUS Eee 4G Notebook
AA battery blinks red when inserted in charger. Is it dead?
You will need to check the voltage of the battery before and after charging , If the voltage is not coming up to 1.2V then the battery is defective. even if the voltage is present but does not drive the unit then the charge is not retained. If so the battery can be defective.
check the terminals of the charge for the charging voltage, use a Ammeter with a load to test the current. If these test prove good then the charger is working fine.
Nov 24, 2010 | Energizer (CHDCWOB) Battery Charger
Respected i have d610 the charging light blink 3 time red then green and not changing the battery
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Oct 12, 2010 | Dell Latitude D610 Notebook
Battery of my laptop is not charging .It is constantly showing 37% charged. charging is not increasing nor thegreen light is glowing but laptop is running with A.C. power. AC power light is glowing...
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
Sep 08, 2010 | HP Pavilion dv6000z Notebook
My toshiba satallite p200-1ee laptop is not charging. Battry life left: 40% When on: The Charging light blinks 3 times every few seconds and the screen dims with it. When off (But pugged into mains): the...
If you plug the charger into the computer without the battery and the laptop runs fine, then I would suggest to you that your battery is failing and will no longer accept the charge. On the other hand if the laptop will not stay running or acts strage and the screen dims and gets bright, then I would suggest to you that the charger's built in voltage regulator is failing and will damage the laptop if it continued to be used. A bad charger will also permenently destroy the battery condition.
Dec 01, 2009 | Computers & Internet
Battery indicator switching off and on and running lights with it
Your alternater is boarding a plane out of town. Actually it's the regulator built into the alt. Have your battery and alternator both tested. High charging voltage can burn up yor battery and lights. Here it is in a nutshell. The lower the voltage the higher the charging amps. At 15 volts the alternater is not charging the battery but simply pouring out voltage.. Have your battery load tested because it tell the alt wat to do, Have the alternater test to see if it has a comprehension problem. IFirst, make sure your batt cables are clean and tight.. Especially the negative cable.Good luck
Jun 14, 2009 | 2002 Kia Sedona
Compaq Evo N610C Notebook Logo
53 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
