Question about Hitachi 53UWX10B 53" Rear Projection Television
POWER LIGHT BLINKS WHEN YOU TURN IT ON NO PICTURE
POWER LIGHT BLINKS NO PICTURE WHEN TURNED ON
  • Anonymous Mar 31, 2008
    I have the same problem. When I turn on my 53uwx10B all I get is a blinking red light and some clicking sound. When I pulled off the back I see that there are 2 green lights that blinking in sequence the "top two' One to the left towards the front of the system and then there are two in line and it is the top of those two that is blinking also. I just got this from my sister and thought I would play with it to see if I can get it fixed or just toss it... What say you…? Is this something that can be fixed…? If not by me then by a repair man cheaply?
  • Butchilee May 17, 2008
    I replaced the ICs (convergence) and 1 resistor(RK50,2.7 ohm),after putting
    everything back together, I ended up with this "power LED blinking problem,
    it played for a while with terrible convergence before it started blinking.
    I plan to recheck my soldering and go from there.
  • 927 Answers
Good Day;
TO: But: You said you replaced the IC's, but you did not what number you used.l The original were STK 392-110 the correct replacement by Hit are STK 392-150's.l have experienced were the new IC's were bad. Double check your connection and others in that circuit, minor crack on jumpers, look closely.
TO: Guest; I think you have a completely diff prob. The lights indicate that B+ circuit is working, there should be at least 6 lights. The one that don't blink or turn on is your problem area.
Beside each led there is a number eg; sp7. Please look more closely at those green lights. Please get back to me I will try to help you.
Good Luck!
Posted on Jun 13, 2008
Replaced lamp but lamp light still blinks orange
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Nov 22, 2011 | Mitsubishi WD-57731 57" Projection HDTV
Screen will not light up.standby/timer light blinks continuosly
check for any cold solder on the high voltage section of your tv A high voltage section is located at the power supply section, this is where the power cord is connected.resolder them,the horizontal section it is where the plyback transformer is located resolder them and the CRT board this is the boad that is attatched to the picture tube...good luck
please rate my help..
Jun 04, 2010 | Sony KV-35S42 35" TV
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
LG 42 LCD no sound or picture
Did anyone find out the solution for this??????? I have the exact same problem with my LG 32 LCD. I only had it for a year and a half, and the green light blinks a few times and it shows no picture. Not even a red light when the tv is off. The same thing happened a couple weeks ago and by some miracle it started working again.
Jan 28, 2009 | Televison & Video
Cannot see picture....
you probobaly. need a new bulb, my dad had the same problem. he orderd a new bulb off the internet and now it works just fine
Apr 22, 2008 | JVC HD-52Z575 52" HDTV
Blinking Standby Light
KV32hs500 tv won't turn on. Standby light blinks 7 times, stops and then 7 more times, etc.. The tv will usually come on after about 2 hours or so of being off. Plays fine when on but once it gets turned off the problem happens again. Any suggestions? T.V. is 5 years old.
I have a similar problem . mine blinks 6 times or 7 sometimes also,and comes on with sound ,no picture for about 2 seconds then shuts off. Anything?
Jan 31, 2008 | Televison & Video
50 inch 1999 TheatreView Television
#1 When I turn on the TV the power button comes on then blinks 6 times then goes off for a few seconds then repeats the cycle. I have sound over my surround system during this time but no picture.
#2 My sound would crackle and pop every once and a while until now it does nothing. I have to watch it with the surround sound on.
Nov 26, 2007 | RCA HD52W59 HDTV Projection Television
JVC 42 INCH PLASMA POWER LIGHT BLINKING ONLY NO PICTURE
no kidding? what is the problem so prevelant in this unit? obvious design flaw.
Dec 19, 2006 | JVC PD-42WX84 42 in. HD-Ready Plasma...
Open Questions:
See all Hitachi 53UWX10B 53" Rear Projection Television Questions
Hitachi 53UWX10B 53" Rear Projection Television Logo
43 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
