Question about Cub Cadet Street Sign- tractor lawn riding mower parts
2008 Cub Cadet LT1042 Won't Start
I have an LT1042 that just up and quit. I was mowing and the darn thing just shut off.
I replaced the spark plug, cleaned air filter, oil (was full), etc.... I checked the plug and it is sparking. Put just a bit of gas into the spark plug hole and it started right up for about a second then quit again. So it's seems like it's not getting fuel for some reason, but not sure why.
Anyone have any ideas?
  • 246 Answers
SOURCE: cub cadet 1610 rans the battery down went mowing.
Hello bigdave1138:
From your Description it Sounds like the Stator/Charging Coils are Bad or the Voltage Regulator (if Applicable) is Bad.
For Testing the Electrical (Charging) System on Mowers you can Use this Site Addy; http://faqs.custhelp.com/cgi-bin/faqs.cfg/php/enduser/std_adp.php?p_faqid=3438&p_created=1101706364&p_sid=4fQ1f8Xi&p_accessibility=0&p_redirect=&p_lva=3443&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NTEmcF9wcm9kcz0mcF9jYXRzPTAmcF9wdj0mcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1Wb2x0YWdlIGFuZCBTdGF0b3IgQ2hlY2s*&p_li=&p_topview=1 and Use the Link for AC Volts/DC Amps Meter Setting Chart. This is for Briggs Engines and Works Well for Kohler and Other Engine OEMs.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 12, 2009
  • 25 Answers
SOURCE: 2160 cub cadet that wont start.hot spark to the plugs
You've solved for some of the equation. Spark. Fuel. Air.....all in the proper sequence. Now, what condition are the plugs ? I'd change them out if they have any wetness to them. Check your fuses as well. Another thing is the 'safety switches' - located in seat, on parking brake, etc. One of these could have come undone or gone bad/loose wire. I'm thinking the latter....
Posted on Jun 22, 2009
SOURCE: I own a cub cadet LT1042. I started mowing tonight
Replace your drive belt
Posted on Jun 30, 2009
97F350diesel
  • 1326 Answers
SOURCE: what do I do if my cub cadet 1862 has no spark?
Try replacing the spark plug first, if still no spark, sounds like the ignition coil is going/bad.
Posted on Aug 06, 2009
  • 110 Answers
SOURCE: Cub Cadet LT1042 PTO won't disengage
If its an electric PTO then the switch on the dash is bad, Its a lever type ungagement then the little break shoes that rub on the blade spindles are either worn out or mis adjusted.If it started when you changed the blade drive belt its possibly the wrong belt??
Posted on Nov 01, 2009
Cub cadet lt1050 starts but after mowing for awhile i shut it off it wont start again
be sure the air fins on the engine are clean. make sure the fuel line is away from heat source. loosen the fuel cap and see if it starts. sometimes if the cap don't vent it will not let it start. change the spark plug. check to see when it does this if it still has spark. the coil may be going bad.
Oct 05, 2016 | Cub Cadet Garden
Cub Cadet LT1042 PTO keeps shutting off after mowing several feet, will turn right back on but keeps shutting off
I have a Cub Cadet 1605 and it does the same exact thing. Try the PTO switch on the dash. I replaced mine and it works fine. Hope this helps.
Oct 12, 2013 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet ltx 1045 wont start, no spark.
remove the top cover from the engine and remove the small wire from the coil if still no spark the coil is bad
Aug 07, 2012 | Cub Cadet Garden
Cub cadet 1515 won't start
I just had the same problem. I installed a new spark plug, sprayed some starting fluid in the engine and it started right up. I mowed my entire yard, and my neighbors yard with no problem?? I'll post more next mow and let you know if it has fixed the problem!!
Apr 29, 2012 | Cub Cadet Street Sign- tractor lawn riding...
Two years ago, my mower (cub cadet lt1042) wouldn't start. Replaced the solenoid switch and it worked the rest of that summer and the first half of last summer. The middle of last summer, I mowed part of...
hard to say, I would make sure the inline fuse is good, then use a vehicle and jump start the mower. I am sure you know how to ensure the mower is ready to start, so we won't cover the pto,brake,etc. Good Luck Tim
Mar 26, 2011 | Garden
PTO WHEN PULLED DOES NOT ENGAGE....BLADES DO NOT START...
Check your mower deck spindles and belt. If belt is slipping at all the PTO will not engage.
May 10, 2010 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
My cub cadet mower LT1042 will not start. It acts like it wants to, and you can really smell gas too. Has a new battery, starter, and spark plug.
Just had the same problem with our LT1042 and it was the fuel shut off soloniod. Could not buy just that piece so we took it off and cut off the piece that went up on the carborator and put it back on. Started right up. Now it back-fires when we shut it off but it runs.
Mar 31, 2010 | Oregon Scientific Electric PTO Clutch for...
Cub Cadet Model LT1042 (2007) The reverse mode does not function.I turn the switch to reverse mode & push the button for reverse mode and the light does not indicate on and I cannot reverse mow since...
Nearly all lawn tractors on the market are designed to kick the cutting deck out of drive when reverse is engauged.
This is controlled by a simple electronic microswitch which can be disconnected but I would advise to leave it as it is ;)
Oct 11, 2009 | Cub Cadet Garden
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
148 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
