Question about Sony PlayStation Portable (PSP) Console
Umd psp froze in the middle of a game. now umd will not load
    Problem Solver:
  • 8 Answers
Hi, its sounds like the laser has gone as thats what reads the disks, i can recommend here for replacement laser to fit yourself or a repair service: www.console-spares.co.uk
Posted on Mar 26, 2008
SOURCE:
Ello. My PSP won't read UMDs. The loading
Most likely the laser is weak. It has been awhile since I have changed a laser in a psp. But first off you should clean the laser with a q-tip and isopropyl alcohol and dry it with the other end of the q-tip. It doesn't take much for them to not be able to read a disc. If it still doesn't work you will need to replace the laser if you aren't that great at working on electronics or very small things you need to find someone to do it for you.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/benjamin_494963e790f97efb
Nov 01, 2017 | Sony PlayStation Portable (PSP) Slim...
Error 80010087
Check the firmware of your PSP. Some games may not work if the latest firmware is not installed.
You usually get this message if the UMD has errors reading or the UMD is not present or was ejected in the middle of playing a game. You should try testing your PSP with other disks, if it doesn't have the same problem with other disks then your UMD is most likely scratched or damaged.
If you are using a modded PSP then you will get this error if you load a game from the memory stick without having a disk inserted in the drive. Or if the game that you are trying to load requires a higher firmware version. You will need to install a higher modded firmware to fix the error if that is your case.
Hope this helps.
Jun 29, 2011 | Sony PlayStation Portable (PSP) Console
Psp won't load umd games
The UMD drive is bad, you can either look around for a replacement drive if you know how to take apart your PSP to replace the drive or just get a new PSP.
Aug 08, 2009 | Sony PlayStation Portable (PSP) Console
Psp will not play any games, but it makes wirring sound
do u use a umd or are u using memory card for game play
u can try this out power on the psp press the select button and choose reset device and if still problem persists tell me the option that u use for game play umd or mmc
Jul 12, 2009 | Sony PlayStation Portable (PSP) Console
Psp(1001)won't read umd games or movies
If your PSP isn't reading games and/or movies and the problem isn't that your trying to play dirty, bent, or damaged UMD discs there are a number of other reasons your PSP is not reading disks correctly =
- Your UMD motor may be malfunctioning.
- Your laser may have worn down from use over time.
- Your UMD drive tray may be bent.
- There may be a foreign object in your UMD drive
Common symptoms
* disks fail to load
* extremely slow loading
* strange whirring noise when trying to read disks
For whatever reason your PSP has stopped reading games and/or movies we will get your PSP back to you and playing like like new fast! Our price includes labor, parts, and return shipping via priority mail.
Visit PSP UMD Drive REPAIR if you are interested in an affordable and reliable PSP repair service. We have been serving the whole United States for more than 2 years!
Jan 05, 2009 | Sony PlayStation Portable (PSP) Console
Psp error # 80010087 The game can not be started
Hi robbimic,
The first thing to check is the firmware of your PSP. You should make sure that your PSP has the latest firmware loaded. Because some games will not work or load up if the latest firmware is not installed or loaded up.
You usually get this error message 80010087 if the UMD drive has errors reading the UMD disc or otherwise the disc is not present or was ejected while in the middle of playing a game or loading a movie. I suggest that you try to testing to see if the problem happens with other UMD discs, if it doesn't then most likely the disc could be damaged or scratched.
Now if you are using a modded PSP then you will get this error if you load a game from the memory stick without having any UMD disc inserted in the drive. Or if the game that you are trying to load requires a higher firmware version installed into the PSP. You will be required to flash a higher modded firmware to fix this error if this is your case.
Hope this helps!
Peace! :)
Oct 21, 2008 | Video Game Consoles & Games
Not reading umd
your son probably dropped his PSP at the time and the UMD drive broke or if your son says he didnt drop it you can get a cutip and softly clean your UMD reader the little bubble sorta in your PSP be carful while doing that
Jul 15, 2008 | Sony PlayStation Portable (PSP) Console
PSP MLB 08
cleen the umd laser with a q-tip and windex. dampen the q-tip andwipe across umd laser. dry with other side of q-tip. take out game wen turning psp on
Apr 09, 2008 | Sony PlayStation Portable (PSP) Console
Psp not reading game discs
umm i have the same problem your umd drive is probaly broken to check this open your umd slot and with the opening facing you, you should see a litlle tab sticking up (black or gray) and hold it down your umd scanner should emit a red laser and moves up and down.
Nov 16, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
23 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
