Question about Pride Jazzy 1113 Power Chair
Dead Battery Chair stood for 1 Year, Can I get the Batteries charged ?Or they need to be replaced, Is this covered under Warrenty. Chair is 15 Months old. Thank You Joe Colavita
  • 13 Answers
SOURCE: Led lights flash and Pride Go chair won't move.
Firstly disengage the drive levers and then "flick "them in fash.
Second pull out the large plug that is between them.
Check for damaged or bent or loose pins. press it home firmly .
I did this on my wifes chair and she zooms around.
All switched etc should be off during charge.
Lastly i fully discharged then recharged the battery to ensure no "battery charge memory".
To fully dicharge i shoved a small box between back wheels so to lift of ground and then a elastic band to hond controler on.
Posted on Feb 02, 2010
  • 61 Answers
SOURCE: Hello,
It sounds like a battery problem more than anything. If it were a fuse, the chair would not move at all. When batteries are stored, they need to be kept charged by charging every couple of week or so (ideally). There may be other problems causing this, such as a short somewhere or a problem with one of the motors/brakes/electronic componets draining the batteries, but I feel this is unlikely given what you have described. I would have the batteries checked at a dealer with a proper battery tester. Preferably have the charger checked at the same time. We use a specific battery/charger tester in our shop that is connected to a computer and will give a graph of the battery/charger condition. This way there is no arguments as to whether the batteries or charger is faulty. Hope this has helped.
Posted on Mar 24, 2010
  • 11 Answers
SOURCE: Jazzy 1103 will not charge. Power cord and
The battery charger is only made to last 1 year if you
re lucky. They are all made in China very cheaply and some only last a matter of months. If you are on Medicare they will replace the charger if necessary after a year. Good luck, hope this helps
Posted on May 16, 2010
  • 177 Answers
SOURCE: The chair has been standing idle for quite some
Hi. This depends on how the batteries perform after you recharge them.
Sometimes you can get a bit more life by completely running them flat. Then reverse charge them. Then run flat again and recharge the correct way. Use a light bulb to run them flat. You will need to remove the batteries from the machine to do this. When you charge the batteries, charge them in parallel with a 12 volt car charger. Keep the charge rate down to 4-5 amps.This will ensure that both batteries are charged up to the same level.
Be carefull with batteries, as they give of hydrogen and oxygen gas when charging, and this can explode if there are any sparks from the charger terminals.
After doing this try the batteries in the machine. Charge them with the correct charger and see how far you can travel.
The batteries probably wont be as good as new ones, but they might do for a while.
Good luck. Neil.
Posted on Jun 22, 2010
  • 31 Answers
SOURCE: My Pride Go Chair battery appears to discharge
Yes prob one of the batteries are bad, but you may want to replace both.
Posted on Jun 26, 2010
Battery charger on quantum electric wheelchair starts out ember color then starts flashing red I check wires everything is plugged check it about 3 months ago everything was ok now th chair won't
Did you charge it at all during the 3 months? Did you store chair on a full charge? Check to see if batteries are dead. Batteries should be disconnected and/or stored on a full charge. If left connected they should be fully charge every week.
Mar 17, 2013 | Health & Beauty
Batteries for Renegade power wheel chair won't charge
if the batteries are OLD they are quite possibly totally dead and need replaced
Apr 10, 2017 | Health & Beauty
The batteries in my mother in laws Jet 3 are about 6 months old and charge up to nearly 13 volts,but the travel is now about one third the distance that it should travel bfore losing charge. what should...
If you have someone do a load test on her batteries I'm sure they will find one weak battery that does not stand up under the load. Make sure that the batteries are fully charged before they do the load test and if one or both of the batteries drop more than a volt and a half under load then they must be replaced Most batteries are under warranty for 6 months lets hope you made it under the wire. Now if Medicare paid for her chair then they will pay for a set of new batteries contact the provider where she got her chair for repair Hope this helps
Apr 28, 2011 | Jet 3 Ultra Power Chair
I have aenigma wheel chair with a shark contoller when you switch it on all lights come on then only one left hand light flashes red thanks Stuart
Stuart iy\ts indicating low battery voltage charge the batteries and see if it goes away if it doesn't then the batteries need replacing or your charge is not working correctly If after charging overnite when you get up in the morning the charger should have a green light on and the battery level should be full. If after just a bit it goes to the red flashing light then your batteries are bad and need replacing. If the chair is less than 6 months old then the batteries are under warranty and your provider(where you got your chair) must replace them at no cost Hope this helps
Mar 20, 2011 | Ctm HS-2800 Power Wheelchair
Ilet chair set for 4 month is the battery still good
With power wheelchairs letting the batteries sit for 4 months without charging them leads to early battery death. The lead plates inside the battery sulfate over time and the battery discharges. If the batteries were fairly new (less than 1 year) before they sat for 4 months they can be resurrected and recharged but may not hold a charge very well. Distance traveled will be very reduced. You can try removing the dead batteries from the wheelchair and charge each individually with a 12 volt battery charger set to deep cycle. You will be able to see if the batteries come back up to full charge and do not burn. They cannot be recharged easily or safely inside the equipment and the charger that came with your equipment will not turn on. They should be removed from the wheelchair first. If the batteries take a charge and the PWC runs plan on using your power chair charger on them for at least 12 to 20 hours to bring the charge back up. Test the batteries over a short distance so you don't get stuck far from home. If you don't get very far before the batteries quit, invest in some new ones. Hope this helps.
Nov 13, 2010 | Health & Beauty
I have a pride go chair that is only one year old. I USE IT INSIDE MY HOUSE ONLY A COUPLE OF TIMES A DAY AND CHARGE THE BATTERIES EVERY NIGHT. The off board charger has already been replaced once under...
The small batteries (17 Amp hour I believe) are notorious for lasting a year and often much less. I consistently replace the original OEM batteries supplied with this chair at the 6 month point. The manufacturer warrants these sealed gel lead acid batteries for only 6 months. Try the AGM (advanced glass mat ) batteries and you should get better life out of them. They might be more expensive at retail pricing but your insurance should pay for the better batteries in my experience. Make sure the charger replaced under warranty is the correct amperage for these small batteries otherwise the output could burn the battery plates.
Aug 16, 2010 | Pride Go Chair Travel Power Chair
What are the cost od replacenebt batteries? The offf board has alreadtv been replaced under warrant it is only one year old AND USED VERY LITTLE IN THE HOUSE, IS IT A LEMON?
Did you purchase the chair or Medicare? This chair has small batteries that need tender loving care If you do not use it often you need to charge the chair at least once a week and always put it up fully charged. Once the batteries get weak then no chair charger will pick them up. Check with a local battery warehouse or similar supply store for 2 12/12 batteries. Hope this helps
Jazzy 1103 will not charge. Power cord and electrical outlet verified good. Plug in chair for charge, the ammeter indicator bar remains at 0, even after several minutes. If chair is powered on (while...
May 15, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Hello, The green battery lights seem to go out rather quickly, and then the speed LED's flash on/off and the chair slows way down. After recharging it fully last night, the speed lights started flashing...
Mar 24, 2010 | Jet 3 Ultra Power Chair
Pride Jazzy 1113 Power Chair Logo
104 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
