Question about Sony Handycam DCR-HC40 Mini DV Digital Camcorder
No funciona la pantalla de mi camara sony DCR-HC40 NTSC ypor consiguiente no puedo dar play ala cinta o entrar al menu.....que hago ayudaâºpor favor
SOURCE: problem with my dvd player
Estimado, tenes que correr la llave que esta a la derecha y colocarla en OUT, con eso ya te va a funcionar
Saludos
WP
Posted on Sep 28, 2008
  • 3 Answers
SOURCE: PUEDO UTILIZAR MI CAMARA DE VIDEO SONY DCR-SR 30
Si puedo utilizar su camara por eso. pero, la directiones estan en engles.
Primero es para S- Video
La orta mas pavajo estan directiones para USB Streaming
How to use a Sony® camcorder as a Web cam with a composite video or S-video connection.
Solution
sp.gif sp.gif IMPORTANT: The computer must have a composite Video or S-Video input jack [FIG. 1]and compatible webcam software installed. Some computers may require a video capture card and/or sound board.
NOTE: This procedure cannot be performed when using the battery of the camcorder as a power source. If the camcorder is turned on, but not recording or playing a tape, it will automatically turn off after 5 minutes to conserve battery power. In addition, please be advised that this procedure may not work for all Sony camcorder models even when using the AC power adapter. Some models have an automatic demonstration mode that will activate after 5 minutes if the camera is turned on but not recording or playing a tape.
  1. Plug the AC power adapter for the camcorder into a working electrical outlet and then connect it to the camcorder.
  2. Connect a composite video cable or S-Video cable to the VIDEO or S-VIDEO jack on the camcorder. NOTES:
    • Sony camcorders usually come packaged with composite Audio/Video cables; S-Video cables are sold separately.
    • To purchase either of these cables, check with your local electronics dealer or visit the Sony® Parts and Accessories Sales Web site or by call (800) 488-7669.
  3. Connect the other end of the composite video cable or S-Video cable to the VIDEO IN or S-VIDEO IN jack on the computer.
  4. Turn on the camera by moving the POWER switch to the CAMERA position.
  5. Remove the cassette tape from the camcorder.
  6. Turn on the computer.
  7. Start the webcam application to be used. NOTE: Contact the software manufacturer for assistance with setting up or using the webcam software.
[[Direct Accessories and Parts Center, DAPC]] How to use a Sony® camcorder as a webcam using USB Streaming. Solution
  • Not all Sony® camcorders are equipped with a USB Streaming port. For compatibility information, or if you require further assistance with any of the steps below, consult the instruction manual of your camcorder. A copy of the camcorder instruction manual is available in the Manuals/Specs/Warranty section of the Sony® eSupport Web site
  • The USB Streaming driver is not compatible with the Apple® Mac OS® operating system.
  • The computer should have a factory installed USB port and compatible webcam software, such as Microsoft® NetMeeting®.
  1. Install the USB Streaming driver on the computer from the CD provided with the camcorder.
  2. Restart the computer.
  3. Plug the AC power adapter for the camcorder into a working electrical outlet and then connect it to the camcorder.
  4. Connect the supplied USB cable to the camcorder and computer.
  5. Turn on the camcorder by moving the POWER switch to the CAMERA position.
  6. In the camcorder menu, set the USB STREAMING option to ON .
  7. On the computer, start the webcam software.
Posted on Apr 06, 2009
  • 566 Answers
SOURCE: Cómo puedo que mi grabadora sony
Descarga esto software Digital Voice Editor Version 3.1.03 for Windows Vista/XP/2000.
64 bit Windows versiones no son por el suportadas.
Posted on Jul 28, 2009
SOURCE: I HAVE A SONY HANDY CAM RECORDER CCD-TR6 NTSC Y
were do i plug in the power cord
Posted on Oct 03, 2010
  • 11800 Answers
SOURCE: me formatearon mi computadora, por
All drivers are here
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VPCEE31FX&LOC=3
Posted on Feb 15, 2011
No puedo entrar a mi pagina de facebook me dise error
Este será un mal español porque estoy utilizando un traductor, pero yo haré lo mejor:) No puede ser muchas cosas mal. Por lo general, reiniciar el equipo va a funcionar,pero si eso no funciona eso significa que hay un problema con facebook, por lo que sólo tiene que esperar a que lo repararan.
Jul 06, 2011 | Facebook Social Network
Como puedo programar un control de remplaso para tv2?
Hola mi nombre es Kimberly Ecobar con DISH Network. Tengo enetendido que necesita programar su control de remplaso con su T.V 2. Para programar el control tiene que hacerlo desde la T.V numero1, cuando usted se encuentre alli tiene que entrar a la pantalla System Info. Esto se puede hacer oprimiendo el boton de Menu 2 veces en el control #1 o tambien oprimiendo el boton System Info enfrente del recibidor, Una vez se encuentre dentro de la pantalla System Info hacia la parte de abajo tendra algo que dice Primary Remote Address y Secondary Remote Address a la par de esto una cajita blanca que contiene un numero adentro. El procedimeinto a programar el control es el siguiente: oprima el boton de SAT localisado en la parte de arriba hasta que los demas botones se iluminen en rojo una vez esto suceda ingrese un numero ente 1-15 (pero diferente al que se encuentra dentro de la caja blanca a la par de Secondary Remote address) y despues el signo de numero (#) seguido por el boton de record. El numero dentro de la caja blanca para secondary remote address debe de cambiar al numero que usted elijio si esto no secede asi intente de nuevo el procedimiento esta vez oprimiendo el boton de record 3 veces. En este link puede encontrar todo el procedimiento y mas informacion en como programar su control http://www.dishnetwork.com/SupportSection/remote-setup. Si tiene mas preguntas o necesita ayuda por favor contactenos directamente al 1800-333-DISH, gracias y espero esto le sirva de ayuda.
Feb 12, 2011 | DISH Network IR Remote Control
Esta prendida la tele y no se mira nada que hago para que funcione
Hola mi nombre es Mayra Diaz con DISH Network. Muchas disculpas que est? teniendo estos problemas con el sistema. Por favor, me puede describir un poco m?s de lo que aparece en su pantalla. Aparece un mensaje usualmente puede que aparezca un n?mero de tres dijitos ala mano derecha de la pantalla. Si no ay ning?n numero si me puede dar mas detalles del problema q est? teniendo con mucho gusto le ayudar? con su problema.
Jan 01, 2011 | DISH Network IR Remote Control
No puedo entrar al facebook :(
no tengo soluciones necesito ayuda....No puedo Ingresar a mi pagina de fcb.. me sale este msj....Tu cuenta está inhabilitada temporalmente debido a labores de mantenimiento, pero debería estar disponible de nuevo en unas pocas horas. Disculpa las molestias. que hago ayudenme xfa!!!
Dec 02, 2010 | Google Chrome
Como puedo arreglar el audio de mi compuntadora
mi pc es ACER ASPIRE T160, no puedo escuchar el sonido, el problema es desde el comienzo no da sonido ni al prender
Sep 05, 2009 | ZT Group CISNET A7022 PC Desktop
No funciona
Ulises,
A ver si me entendes, el televisor se ha descalibrado con el control remoto.
o por la tecla que apretaste o por algo que paso.
Para que funcione nuevamente simplemente debes volverlo a programar.
Ya se que no anda, y ya se que probaste mil veces.
Ahora empeza de nuevo y programa el control remoto como si empezaras desde cero
Para ello necesitas el codigo de tu TV para ingresarlo en el control remoto.
Los codigos normales del Silvania son 0054, 0030, 0020, 0096
Si estos numeros no funcionan dame la informacion que te pido abajo
modelo de tu Sylvania
modelo de tu y marca Remote
Oct 19, 2008 | Vehicle Parts & Accessories
Ayuda para desbloquear
buenas tardes tengo un tv modelo HTV-2115 y tiene un candado rojo en la esquina inferior izquierda el canal no lo deja de mostrar y donde deberia tener la hora aparecen las rayitas no me deja usar el control sino para apagarlo y de los botones laterales solo lo puedo apagar como puedo desbloquearlo sino me da acceso al menu ni con el control ni con el menu lateral. darme respuesta al messnger viittoria1997@hotmail.com Gracias es de Venezuela
May 24, 2008 | Televison & Video
Problemas con la camara web
Hola soy nuevo en esto de los foros, tengo problemas con mi camara web 1,3m que viene integrada a mi Toshiba Satellite A215-S4807, tengo Windows Vista Home Premium, entonces mi camara web casi nunca logra funcionar con el msn e incluso el programa que trae ("C:\Program Files\Camera Assistant Software for Toshiba\traybar.exe.exe") no funciona correctamente ya que a veces funciona y otras no... ahora ultimo no ha querido funcionar mas con el msn.
Quedo de ustedes y esperando sepan ayudarme.
Gracias de antemano. Carlos
Jan 25, 2008 | Computers & Internet
Conectar JVC GR-DVM5 al ordenador con el sistema operativo Vista
necesito drivers para bajar videos desde mi camara jvc gr-dvm5 al computador que tiene windows vista home.alguien me puede ayudar con alguna informacion o sitio donde los puedo encontrar??
Dec 23, 2007 | JVC GR-DVM5 Mini DV Digital Camcorder
Sony Handycam DCR-HC40 Mini DV Digital Camcorder Logo
116 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
