I have a RUUD 13pja42a01 heat pump. The main breaker in the house was turned off about a week ago. We have not tried to turn on the AC until today and the outside unit will not come on. The main breaker in the house is on as well as the heat pump breaker. I was looking for a reset button but cannot find one. Also in the box outside connected to the unit it does not appear that there is a breaker in there.
  • 8,220 Answers
Check the small wires going outside to the contactor for 24 volts. If you have 24 volts then maybe the magnetic operator coil that pulls down is bad.
Posted on May 02, 2010
I have a Ruud achiever series heat pump. the unit would not kick on. the LED's under the cover are flashing that there is a high pressure lockout. is there a way to reset this on my own? i had a...
If condenser area is squeaky clean see if there is a way to reset the uit electronics. Check with Rudd for reset and then try again. If that does not do it then there may be an obstruction in the cooling system causing the high pressures and making it turn off for self preservation. You can also carefully push down on the contactor relay to see if the compressor starts at all - maybe there is an issue with the compressor.
Sep 15, 2017 | Ruud UAMB Air Conditioner
I have have an older kenmore electric dryer that won't start. Let me give you some detailed information about the events that happened prior to the discovered failure. -This dryer hasn't been used for a...
The heat is not a factor.Make sure you do not have a tripped breaker. Otherwis if you had a power surge to the dryer, ther could be electrical damage.
Aug 11, 2010 | Kenmore Dryers
Ruud UBHC AC System - Provides no Aux Heat
Tried this on my unit today, and observed the same results, but got Aux Heat (with A setting), if the H (blue wire) connected to B terminal, as per instructions for my 6036 Ritetemp. However, in this case, when the set temp is reached, I hear the click, but HVAC still blows aux heat indefinitely.
I also have RUUD UBEA 17J10..., and replaced my old honeywell with 6036, and can't get heat pump working. Both of my units are 14 years old, so I'm thinking to replace them soon.
Jan 06, 2010 | Ruud UBHC Air Conditioner
Ruud ac wont come on. mfg 03/99. thermostat
Have an electrician check the connections in your panel, this sounds like a loose/bad nuetral connection
Jul 26, 2009 | Ruud Heating & Cooling
The outside unit on our Ruud heat pump won't turn on. The inside fan blows but the unit outside sits idle - no fan turning, nothing. It was cooling earlier today, but when I came home from shopping, the...
first look for red button neer the copper line set if has one push it second inspect thermostat wires for weed eater damage check disconnect for fuses check breaker at main panel pull disconect and remove cover check stat wire connections look at the capacitor if swelled up on top bad if all look ok put disconect in using insulated object manually push in contactor if unit comes on check for 24 volt ac on yellow stat wire to common if none stat wire could be loose at indoor unit or stat bad hope this helps you
Jun 05, 2009 | Ruud UPMC036 Air Conditioner
Amana Heat Pump Tripping Breaker
My guess I would say, you either have a wire that is short to ground or if the contacter pulls in, then I would say the compresser is short to ground.There also could be some capacitors that could be short.
Apr 07, 2009 | Amana PTH123B25AJ Heat Pump Air...
Ruud central air conditioning and heat system
there is a fan relay in the unit. it is stuck and needs to be replaced
Oct 21, 2008 | Ruud Heating & Cooling
Help on my ac unit
no special tricks alyson.....prolly just a breaker or fuse.check the main panel for a turned off breaker and at the unit there's a disconnect box that may have a bad fuse.
Aug 23, 2008 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
125 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
