Question about Miele s558 Silver Moon Vacuum
Electrical power down while vacuuming (not a reset)
Miele Silver Moon - about five years old. We just replaced the HEPA filter, the bag and the thin filter.
Problem: It frequently powers down while vacuuming. We have to notch the power back up - then it powers down again. It's not a hard reset power down with a light coming on - it's a decrease in the electrical setting to nearly no suction at all. A marble passed through the hose and seems to roll around and through easily, so it doesn't look like a hose obstruction.
  • 1 more comment
  • PhillipsVA Apr 05, 2008
    During vacuuming, the unit powers all the way down (still on, but not functioning.) We are foreced to push the '+' button on the handle to get it back up to power. It is increasing in frequency.
  • JonahBegone Apr 24, 2008
    I borrowed a friend's hose and handle from his Silver Moon and tried it out on mine - no problem. Power stays on high all the time. Therefore, the problem must be in the hose and handle, probably in the circuitry in the handle used to vary the power.
    So... I took the hose and handle assembly apart to take a look. It is difficult to take apart and difficult to put back together, but with patience I managed. (Those are Phillips screws, by the way, and not Torx.) Anyway, there are three metal to metal contacts where the hose fits into the handle, used to trasnfer power to the motor head; these had a blackish sort of carbonized dust on them. I cleaned this off and copied down all the part numbers on the little circuit card in other to order a new one. Put the whole thing back together. Guess what? The problem absolutely went away!
    My guess is that the carbonized dust was conducting a little bit and perhaps causing some fault detection circuit to shut down the power. Static guard circuit of some kind? I don't know.
    So... I fixed this problem for nothing by taking apart the hose and handle, cleaning it, and putting it back together. Try it!
    JonahBegone
  • lgwg58 Dec 27, 2008
    This is the same problem I have with my Miele Silver Moon. Would like to know as new solutions come along. I will try the suggestions mentioned here.
Thank you JonahBegone!
My 4 years old Silver Moon has been power down off and on for a couple of months, but all of sudden it kept doing it. Then the power won't turn on when I plugged it in ( this turns out to be another problem, see my other posting). I took your advice on taking the hose and handle apart. I unscrewed the 5 screws, but can't pull the handle apart to look inside. I was able to see the 3 metal contact on the hose that you mentioned through a 1/4 inch gap when I forced the handle apart. I cleaned the black stuff off through the little gap by rotating the hose a few times. Then magically, my power down problem also went away. Thank you once again.
Posted on Jul 06, 2008
  • kelizgirl Sep 13, 2010
    Thank you so much for the information. Red Velvet did the same thing, and now after cleaning the 3 metal contacts, it works excellent!
Have a Miele Red Velvet which was behaving the same way. It would automatically power down (suction) whether I was using the power brush or hardwood attachment. Read this EXTREMELY HELPFUL submission—took the handle apart and cleaned the three contacts with an electrical contact cleaner and Q-Tip and viola!, it works flawlessly.
Posted on Jan 31, 2009
Mine was doing the same...powering down. I also cleaned it, as described. worked well for a short time. now it powers down even with clean contacts. I have been disassembling it for more then 4 time for the last year. Got tired and really frustrated. Ready to buy a replacement.
Posted on Jan 09, 2011
  • jirkajana Feb 28, 2011
    I had the same problem. The problem is loosing the contact at the top part of the handle - where the hose meets the handle. You can try to fix it by opening the handle and putting some ELECTRICALLY CONDUCTIVE grease ( graphite grease or similar) on two rings and contacts you will see there. Undo one screw on the bottom plastic "ring" and pry it out. You might brake little latches on the opposite of the screw, but that would not matter too much. Undo all the screws you can see on the handle and pry it little bit open. I could not open it all the way, but made the gap wide enough that I could use cotton swab and first clean the metal rings little bit and then apply the conductive lubricant. It has been about a year since and it is still working fine, $ 200.- saved :-).
    President:
  • 1,673 Answers
Could be trhat the variable speed control is going bad. There also is an electronic control by the motor which could be the problem.
Posted on Mar 27, 2008
Miele Silver Moon Losing Suction Power
That is possible, also check for a.m. exhaust filter off the motor. Usually a very fine filter to stop dust that gets past the bag. May just need to open it up and clean out the accumulated debris.
May 02, 2013 | Miele s558 Silver Moon Vacuum
if there's no blockages and filters all OK it's probably the suction fan that as worn down and not creating as much suction..
I have a Miele Silver Moon 558 and the red light is staying on saying reset - what do I do? - I do not have a manual. Thank you marilyn@drmelvin.com
well for the manual, you may download it from here. note that you will first have to give some kind of rating before download link activates. otherwise, light indicate when replacement exhaust air filter (key RESET) (after approx. 50 hours of operation, which corresponds more or less, an average use a year).
Jan 23, 2011 | Miele s558 Silver Moon Vacuum
I just bought a Miele s558 Silver Moon, seems like
good vacuums bags are very expensive and parts too
return it
May 11, 2010 | Miele s558 Silver Moon Vacuum
I just bought a Miele s558 Silver Moon, seems like it's from 2000 or so. If it's in good condition, can I expect this machine to last another ten years? Or would it have been better to buy a lower end...
Greetings from GoVacuum,
Ahh, the Miele Silver Moon model S558i. This is great model that I know a lot about because I actually own this exact model. I have had my Silver Moon now for going on 10 years, with almost no problems. The motors in the Silver Moons are excellent, and should last 20 or 25 years without problems. This particular model did have one major problem however. This is the first model that Miele put the suction controls in the handle of the hose of the vacuum, allowing the user to easily adjust the suction setting with fingertip controls. The problem with these models is that static electricity (usually happens when vacuum carpeting) causes the hose to shut down the power to off. You can be in the middle of vacuuming, and all of a sudden the vacuum will turn off. You can easily turn back on the vacuum with the push of a button, but it's irratating for sure.
Miele did come up with a solution for this problem with a newly redesigned hose, part number SES125-3. Since this new design has come out I haven't had a single issue with my hose. The way you can tell if you have the old or new hose is by the numbers (or lack of ) on the different suction levels. If your hose goes up to 1100 Watts, then this is the older style hose. If you're hose simply has a minimum to high setting with no numbers at all on the hose, then this is the redesigned 125-3 hose.
If you have the older style hose, I would get the dealer that sold you the vacuum to exchange the old hose for the new hose, you definitely don't want to have to buy that new hose ($150+). If you have the new hose, then I would say stick with the Silver Moon over the newer Miele models, in my opinion the Silver Moon is one of the most durable models that Miele has ever made.
The only other thing you need to be careful of is the cord reel. When you are retracting the cord reel, it's best to kind of guide the cord back in, and take it slow rather then just stepping on the cord rewind pedal. The cord reel can sometimes be touchy, especially if you are rough with it. If you're careful with it, you should never have any problem with the vacuum cleaner as long as you change the filters on a regular basis as well as the bags.
I hope this helps, if you have any further questions, please feel free to contact me at chris (dot) jones (at) govacuum (dot) com.
Thank you,
Chris Jones
GoVacuum.com
Mar 18, 2010 | Miele s558 Silver Moon Vacuum
My Miele Silver Moon "Reset" light is blinking. What do I do?
Ahh yes, the Silver Moon. One of Miele's best made vacuums ever! So good that out of all the different vacuums that I could of chose for my home, the Miele S558 Silver Moon was the one I chose.
When you're Reset button is flashing, this simply means that it's time to replace the HEPA filter on your vacuum cleaner. Miele included this feature on their upper end models to alert the user when their filter needed to be changed.
The Miele Silver Moon uses Genuine Miele S-Class HEPA Filter for S300i/S600i, and Miele S7 Uprights. Miele Part # 04854915 (replaces 04854911) Which can be purchased from GoVacuum for $52.95 with free shipping.
Once you have installed the new HEPA filter, simply press down on the flashing Reset button to restart the 50 hour internal timer inside. Miele recommends to replace this filter after every 50 hours of vacuuming.
If this answer was helpful, please click on the helpful Thumbs Up icons in the top right hand corner of this Solution.
If you have a repair that you would like explained, please check out our Q & A website, askgovacuum.com.
Thank you very much,
Chris Jones
GoVacuum.com
Feb 19, 2010 | Miele s558 Silver Moon Vacuum
How do I install new filters on a Miele Blue Moon?
There are two filters on the blue moon. The hepa filter and the motor filter. You get to both filters the same way. You open the lid, like you do when you change a bag. The motor filter is right behind the bag inside a plastic cover. There should be two tabs you can pull down to open and access the filter. The hepa filter is located toward the back of the bag chamber but on top. There is one tab in the middle that lift up on.
Sep 23, 2009 | Miele Blue Moon Bagged Canister Vacuum
Miele big blue
Could be a problem with the cord. There also is a circuit board by the motor that could be the problem. Did you drop something in the hose to see if it comes out the other end? Because you could have a clog. Or just unhook the hose and see if it runs that way.
Apr 26, 2008 | Miele Blue Moon Bagged Canister Vacuum
Motor stops running after a few minutes
One thing you could have a bad motor control, part #05408630, mounted by the motor, the other could be a bad variable speed control, part #05412914, it is on top near the back.
Dec 08, 2007 | Miele s558 Silver Moon Vacuum
Miele s558 Silver Moon Vacuum Logo
1,001 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
