A broken washing machine knob (GE wjrr4170eiww)
I broke a washing machine knob that controls the water level. As I was setting the load size, the knob broke. Along with little black dial that connects to the knob!
I was thinking of opening the washer where the control panel is, but there are three weird looking screws on top of the panel that keeps me from opening it. What can I do?
Kascade
  • Anonymous Jun 15, 2008
    I have a smililar model WJSE3110WW.. with the same problem.
    During the move - the movers broke off the knob (with the little black piece coming out the of the control panel stuck in the knob)
    I asked around and response I got was you will have to change the switch. That would be fine except the switch is part of the control assembly (switch is not separate). The control assembly sells for $125+shipping.
    Any one who has fixed this sort of issue please educate us
    This sucks - I think this GE could have used a metal "axis" to put the knob on.
jsrock516
  • 5911 Answers
SOURCE: How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Posted on Apr 22, 2008
SOURCE: water doesn't stop filling when selector switch is on Super (GE)
replace water valve
Posted on Oct 12, 2007
  • 1122 Answers
SOURCE: the washer overflows with water. help
make sure the water level hose is connected to the tub and the switch,you can remove the front panel to and flip up the top check,let me know now you do-mike
Posted on Dec 02, 2008
jsrock516
  • 5911 Answers
SOURCE: Ge washer wont stop filling with water
The usual culprit for a washer that will not stop filling is the pressure switch. The switch is located inside the operator console behind the load size, or water level knob (this knob has different names based on the washer model). Before assuming the pressure is defective, however, inspect the pressure switch and ensure the small plastic air hose is still attached to it. It is common for this small air hose to come loose or develop small cracks or breaks. Without the hose installed, the switch cannot detect the appropriate pressure in the wash tub and will not shut off. The result: as washer that continually fills and will overflow. What appears to be a significant problem may only be a loose hose and few minutes of your time. Please inspect the switch, check the entire length of the hose for cracks and make sure the electrical connection(s) are intact and not corroded, then get back to me. I hope this helps you.
PS Make sure you UNPLUG the washer before servicing!
Posted on Dec 20, 2008
  • 686 Answers
SOURCE: Wash cycle knob turns without controlling wash cycle
it's possible go to www.repairclinic.com and enter the numbers you have posted and it will show you what they are. I have the same problem. What I did was not pretty but it works for now. I broke a piece off of your part#387997 and simply turn my dial that way and then pull the center out to start the wash. Considering a new timer is close to $100+ and it works fine this way , well you know...
Posted on Apr 06, 2009
WHY IS WATER LEVEL LOW CAN I CHANGE THE SETTING ON WATER
there should be a knob on the control panel showing small, medium, large maybe even super. that is how you change the water level. Its for different amounts of clothing your washing at a time. If you put in a few clothes then you have the option of using less water.
Jul 31, 2014 | GE WBSR3140DW Top Load Washer
Whirlpool GSQ9669LW1 washer. Originally Load Size was set to small. After water was filled to that level and machine started to work, wanted to add more water. Turned the Load Size knob to Medium, nothing...
You would have to start the wash cycle all over in order to get enough water for the med load size. Once the washer starts it cycle you have to cancel that cycle to start a new one. Hope this is a help to your question
Apr 24, 2014 | Whirlpool Washing Machines
Washer wants to start at the Wash portion of the cycle, not the Fill portion
Hi this is a bad pressure switch, it is located in the control panel behind the knobs, its the switch that changes the water level, sometimes you can switch it back in forth real fast from small to large size load and it will start working. But it will eventually need replaced, that part usually runs around $30-50.00.
Sean
Mar 26, 2011 | GE WWSE5240G
Over flows need to locate fill sensor and repair
A plastic hose couples from a bottom outlet in the outer tub up to the back of the water level control and increasing air pressure, exerted by the rising water level in the tub, causes the pressure sensitive switch on the level control to trip (which shuts off the inlet water) when the rising pressure exceeds the spring pressure set by the knob on the control. Either the hose has an air leak, or the level control is faulty (the problem is usually the level control). Hope this helps!
Oct 19, 2010 | GE WBSR3140DW Top Load Washer
What does the ''Reset'' position on the ''Load Size'' knob do?
if you have filled machine to say small water level and change your mind you turn to reset and then set your new level hope this helps
Nov 06, 2009 | Coffee Makers & Espresso Machines
The washing machine will overflow, flooding water onto the floor. Flooding has happened 8 times, and it attempted to do it about another 5 times (I stand there and watch it and turn off the water supplies...
ive included a solution to a similar problem that i solved earlier this week, i hope you find this helpfull...
I am assuming this is a top load washing machine.... the load size selector button has a hose attached to the back of it. This hose goes down to an overflow box mounted to the side of the tub. This tube often gets clogged and the machine cannot tell where the water level is. 1) dissconnect the tube from the level selector switch and ( w/it unplugged ) attach another tube to it and blow into it. you should hear a clicking sound. this means your level selector switch is functioning properly. if it does not click then it needs to be replaced. 2) dissconnect the tube from the level selector switch and ( w/it unplugged ) blow into the tube and you should hear air going into the tub, ( this is best performed with water in the tub ( bubbles ) )....hope this helps
Asker's Testimonial " Thanks rdrsp. When I took the control panel off, I found that the tube had fallen off the control valve. I put it back on with a band clamp. " - bill_marv460 "
Oct 22, 2009 | GE WVSR1060A Top Load Washer
Ge washing machine pull knob
Replace the knob...The teeth on the back of it have broken.
Dec 01, 2008 | GE WBSR3140DW Top Load Washer
Washer will not fill
I had a problem almost like yours. The hose attached to the load size switch had a clog in it, and the washer wouldn't fill with water or spin. Will need to take the front panal off to check the whole line.
Jun 06, 2008 | GE WBSE2090A Top Load Washer
Washing Machines Logo
1,296 people viewed this question
Top Washing Machines Experts
