Question about Sony PlayStation 2 (PS2) Console
I just fix my play station 2 disc its hard going around trying to fix scratches any ideas?
  • 186 Answers
Video store has a cleaner that fill's in cracks ;
Posted on May 02, 2010
Why my dvd wont play on my player
Does that disc work on other players? Do other discs work on your player?
If you tell us more about the player, the disc, and what happens when you try to play the disc, we'll be able to make better guesses about what the problem is. Can you play other discs? Does that disc work in other players?
Not having specifics, here are some ideas, in the order in which they popped into my head:
1) That's a Blu-Ray disc and you have a DVD player.
2) The disc is dirty. Take a wet cloth (or paper towel), put a little dish soap on it, and gently swipe the shiny side of the disc from the center of the disc to the edge (don't wipe the cloth around and around the disc). Rinse the disc with cold water. Wipe with a soap-free wet cloth. Rinse again. Wipe with a dry cloth (or paper towel).
3) The disc is scratched. Some players handle scratched discs better than others. There isn't much you can do here. There are kits that can repair some scratches, but the kits aren't free, and they don't work a lot of the time.
4) You are putting the disc in upside-down. The side with the printing on it has to face up.
5) Your DVD player is dirty. Open the disc tray and blow as hard as you can into the player. Try not to blow any spittle into the player.
6) Your DVD player is broken.
7) Your disc is NTSC (Japan/US) and your player is PAL/SECAM (the rest of the world). Or vice versa.
8) There is some thing about region codes which is some kind of copyright protection scheme that means not all discs will work with all players.
9) Your disc is a CD, not a DVD. (I think most DVD players can play CDs, though.)
10) Your disc is DVD-ROM, meant to be used in a computer.
Mar 02, 2015 | Televison & Video
Tip
Xbox help for "Can read CD but NOT DVD."
Step 1: Inspect and clean your disc Take a close look at the bottom side of your game, movie, or music disc (the side without a label or image). Are there scratches? Excessive scratches or smudges can prevent your console from reading the disc. Clean your disc 1. Hold the disc by the edges without touching the top or bottom surfaces. 2. Using a soft, clean, slightly damp cloth, lightly wipe from the center of the disc outward. Note Do not use solvents to clean the disc. 3. Once the disc is clean, load the disc into your console and see if the disc plays. If the disc still does not play, try step 2. Step 2: Try other discs Try other discs to determine whether the problem happens with any disc or only with this particular disc. If multiple game discs, DVDs, or CDs will not play: 1. Make sure the media type and the disc region code are compatible with the console. 2. If the problem happens with several discs of different types (games, DVDs, and CDs), skip to “Step 7: Request a repair” below. If a specific game disc will not play: 1. Search the Microsoft Knowledge Base to determine if the game title has any known problems. 2. Make sure the media type and the disc region code are compatible with the console. If the disc you are using has a region code that is compatible with your console but you still cannot play the disc, try step 3. Step 3: Clear your system cache If your Xbox 360 console can’t play multiple game discs, try clearing your system cache. Here’s how: 1. On the console, go to My Xbox, and then select System Settings. 2. Select Memory. 3. Highlight any storage device, and then press Y on your controller. 4. Select Clear System Cache.
Note If Clear System Cache is not available, use the button sequence described in the following article: 971755 How to clear the Xbox 360 console cache 5. Try to play a game disc. If you still can’t play a game disc, try step 4. Step 4: Remove the hard drive If the problem only happens with game discs, let’s try temporarily removing your hard drive. If your Xbox 360 console does not have a hard drive, skip to step 5. 1. Turn off your console. 2. Locate the hard drive on your console. 3. Press the release button on the hard drive and lift the hard drive from the console. 4. Turn on your console. 5. Try to play a game disc.If this step resolves the problem, reattach the hard drive and contact Xbox support to order a replacement hard drive. If this step resolves the problem, reattach the hard drive and contact Xbox support to order a replacement hard drive. If you still can’t play game discs, try step 5. Step 5: Disconnect memory units 1. Turn off your console. 2. Unplug any memory units attached to your console. 3. Turn on your console. 4. Try playing a game. If this step resolves the problem, reattach the memory units and contact Xbox support to order a replacement memory unit.
on Feb 15, 2010 | Video Game Consoles & Games
Tip
How to play a scratched disc on xbox 360 or some other consoles
Note: I have only experienced using this trick on the XBox 360 Console.
One common problem that video game players have all the time are scratched discs. A helpful way around buying a brand new game or a disc scratch remover, is to first:
a.) Borrow the same version of the game from a friend
OR
b.) Rent the same version of the game from a store
Now, take the unscratched disc, and install it to your hard drive.
And lastly, now you can put in the scratched disc and go to "Game Library", choose the game, and select "Play from Hard drive."
The reason this trick works, is because when you play your disc from the hard drive, it uses minimal memory from the disc itself.
NOTE: Installing a disc to your hard drive does NOT replace having to put in the game to play it.
You still need a copy of the game in order to run it from your hard drive. I believe this is some security feature so people don't go around copying the games and not buying them.
Also, I would NOT install the scratched disc to your hard drive, for this will not help your problem at all.
on Jan 23, 2010 | Video Game Consoles & Games
My 360 only plays cds or dvd s wont play games please advise
Feb 15, 2010 | Microsoft Xbox 360 Console
Fifa 09 football problem. telling me to clean disc as it is unreadable i am cleaning the disc and restarting the console but it keeps telling me to clean the disc.
OR
Jan 23, 2010 | EA Sports Video Game Consoles & Games
Xbox 360 disc drive problems.
There could be a couple of causes, and there could be a couple of solutions. The solutions may not be too fun though.
First possible problem:
1. Your discs could be scratched. If that's the case, clean them off as best you can with a soft cloth and all that. If that's not the case......
2. It could be that your disc drive is messed up.
If 1. didn't solve your problem, than here are some possible solutions.
1. Your lens could be dirty, in which case you can try a lens cleaner (probably not the problem)
2. For many with this problem, formatting their hard drive (yes their hard drive, not disc tray) solves the problem. Unfortunately that's a major bummer because you'll lose everything on the drive.
3. If you're brave enough to go through the second one and it still doesn't solve it, you're going to have to send it in for repairs cause it looks like the disc tray is going kaput.
As a side note, for those rare occasions when you do get it to work, try installing the game(s) to your hard drive, this way it won't be so reliant on the disc.
Best of luck man :)
Nov 29, 2009 | Microsoft Xbox 360 Console
Unit wont read game disk. Plays Movie, and CD disk no problem..Any suggestions
Hi rico617,
If 1. didn't solve your problem, than here are some possible solutions regarding 2.
3. If you're brave enough to go through the second one and it still doesn't solve it, you're going to have to send it in for repairs cause it looks like the disc tray is having incompatibility issues with your games (yeah I know it's dumb)
Best of luck man :)
I Freez up every 5-10min.
try to play it on another xbox....might be the cd....if so try to get another cd. if not uninstall and reinstall the patches. or also try to rip the contents of the dvd-rom to the hard drive and play with both disc and hard drive....maybe too much stress on the dvd-rom drive such as overheating or cyclic rundary errors
Apr 24, 2009 | Microsoft Xbox 360 Console
Play station 2
If you have your playstation 2 standing upright it may be this tht ios causing the problem as the disc will not be correctly line up with the laser that reads the disc this could also cause scratchs on the discs, its best to have the playstation 2 in the downright postition.
Jul 04, 2008 | Sony PlayStation 2 (PS2) Console
Sony play station 2 slimline
your disc is dirty and has lots of scratches on it get a new disc
Jun 28, 2008 | Sony PlayStation 2 Slimline Console
Sony PlayStation 2 (PS2) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
