Question about Video Cameras
A tape is stuck
The tape player will not play. and a casette tape is stuck in the unit.
  • 3 more comments
  • GatorMommy May 25, 2008
    My camcorder seems to be "dead". The tape will not eject. There is no power at all. I plugged it in to charge but .. nothing. No charge light-nothing. I was filming on a sunny day yesterday and it just went black. I got home and can not get it to do anything. I can not get it to power on to look at still shots either. HELP!!!!!
  • mindya1015 Sep 04, 2008
    The tape got stuck in mine too. Cannot even play or record, because the screen says Eject! when you turn it on.
  • Anonymous Sep 21, 2008
    Mine "died" to. for no reason at all!
  • shipolito Nov 15, 2008
    I'll place my name on this list too.
    This happened to me about 3 years ago.
    Since then, my camcorder is resting at the bottom of a drawer.
    Does someone knows how to fix it?
  • alexspeyer Nov 26, 2008
    The tape is stuck, it won't open when I eject, so I cannot take it out. I cannot do anything, when I turn it on, it tells me to eject and beeps.
I have the same problem! No solutions?!?!
Posted on Sep 21, 2008
Some have suggested taking off the battery, wait a few hours, then put the battery back on. Mine has a stuck tape also & I'll try that solution this weekend...Good Luck (Me Too!)
Posted on May 24, 2008
I have an rca portable radio tape and cd player RCD175, and it plays good, but wont play cassette tapes. I put the tape in and press pas and the play button wont stay pressed in. What causes that?
Hello
It is due the mechanism trouble to your set. The casette tape deck mechanism should be troubleshooted. It is a skilled work. Just contact any experienced service technician to make this set right.
Feb 28, 2012 | Audio Players & Recorders
Does my JVC HR-XVC33U have a disc burner or a reader only?
Greetings Lightfingers - Your unit is only capable of viewing DVDs and has no capability for burning DVD's
If you would like to burn DVDs you can buy a burner for a PC for about $20-25 USD at a place like newegg.com.
Regards and thanks for using Fix Ya.
Mikeywaf
May 10, 2011 | JVC HR-XVC33U DVD Player/VCR
When I put a casette tape into the tape player of my 2003 Hyundai Santa Fe double din cd tape head unit there is a message on the display that says TIGHT TAPE then the tape ejects how to correct this so...
If it does this with all of the tapes your cassette player needs to be cleaned. there might be some dust in there that is stopping it from working correctly. You can blow it out using an air compressor (NOT ON FULL) just blow it gently out so nothing gets moved from the air.
You can also use keyboard cleaner from any computer store (it is just a can of compressed air) walmart and zellers also have this for you.
If it only does it on that tape stick a pen through the round hold and wind it all the way around to the other side this should loosen the tape a bit for the player to play that tape.
May 04, 2011 | Car Audio & Video
My cassetteplayeris broke but the front panel says tape unpluged it radio won't play pluged it back in few days later tharadio came back on.going down the road it swithched from radio playing back to tape...
the cage mechanism of the cassete is dropping causing it to shut the radio off ,only solution is to remove the radio and open case then jam the cage into the no casette position with a piece of wood or a folded up cardboard ,i think this will cure the problem
Feb 15, 2011 | Car Audio & Video
Car casette player won't accept cassettes. I put a cassette in and it spits it right back out.
Your casette player must have something lodged in it that's why it spits the casette tape back out. If you are able to, try dislodging the player from your dashboard. Shake it and if there's something noisy inside, chances are that's your culprit. Try to get it out by shaking the player while keeping the casette tape door open - like getting coins from a piggy bank. :)
Hope this helps!
Fix14
Jun 16, 2010 | Car Audio & Video
I have a KEH-P1010 it just keeps switching the casseette back and forth and won't play it.
Are you using the same casettes in the car all the time? It sounds like the tapes are getting loose on the spool. Try a new casette that hasn't been used in the car.
Nov 11, 2009 | Pioneer KEH-P4020 Cassette Player
Sony dual casette player/recorder
Unit may have slipping drive due to defective belt or tape may have wrapped around captsan. Have serviced
Jul 28, 2008 | Sony Dual-Deck Cassette Player/Recorder...
USING IN MY CAR
There are no adapters SPECIFIC to this unit - if your car has a casette tape player, buy a casette adapter for mp3 players
May 11, 2008 | iLO (2 GB) MP3 Player
Dew and casette eject
With the dew indication, the tape will not load. This is to prevent the tape from getting stuck inside the unit. If "drying out" the unit has had no effect, either the sensor itself is bad or the connections to it are defective. Opening these is no simple task for the novice. Bring it in for service. It should not be more than about $100 to fix this problem.
Dan
Apr 09, 2008 | Sharp Viewcam VL-Z1 Mini DV Digital...
Go gear in the car
If your jeep has a casette tape player, you can buy a casette adapter that will plug into your GoGear headphone jack.
-Tha Mp3 Doctor
Jan 03, 2008 | Philips GoGear HDD1830 MP3 Player
Video Cameras Logo
792 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
