Question about Black & Decker String Trimmer Cordless 12" 18V
GL545 Strimmer Type 2
How do u re string the spool on the GL545 strimmer.
5 Suggested Answers
SOURCE: grasshogXP string trimmer GH1000-ca type 2 7.2 amps
You can order replacement parts from:
http://www.toolpartsdirect.com/cgi-bin/noframes.cgi/blackdecker/CST2000_TYPE_1
Posted on Jul 14, 2008
  • 4 Answers
SOURCE: got a Black & Decker GL301 strimmer but have lost instruction manual. dont know how to fit new cutting wire
Go to Homebase, B&Q, Ebay or your local hardware shop and buy a new spool, ALM part number BD032.
Posted on Jun 01, 2009
  • 4 Answers
SOURCE: Black & Decker GL720 Strimmer not working
Hi there, I just thought I'd mention that I also have a Black & Decker GL720 with the same problem. I'm pretty sure it is less than 1 year old too, so well within the 2 year manufacturer's guarantee here in the UK. I think it may be a UK specific model and the phone number from MrFixIt looks like a US number.
I have tried taking the plastic casing apart, but with no luck, as the two halves won't come apart easily, even after removing all the screws. Ah! OK, I've found out the reason that it wouldn't come apart now, there is a screw hidden under the 123 sticker.
It's all apart now, and I see what is wrong, there is a belt running between a small cog and a large cog, and in my case the large cog has partially melted and the belt has come off. Unfortunately, I'm not sure I can get the replacement part now. Hopefully with yours, MrFixit, the belt might have just slipped off, fingers crossed.
Anyway, here is a service diagram of it in case it will help anybody, but as you will see it says only certain parts can be ordered. If anyone locates a supplier of all the parts please post it here.
Many thanks
Simon
Posted on Jun 03, 2009
  • 133 Answers
SOURCE: GL 320 String trimmer - nylon string keeps breaking
It sounds like the sting is wound backwards. Try winding a short piece in the opposite direction. If it is backwards, it will be gone in a hurry.
Posted on Apr 20, 2010
How do I change champion strimmer cord
this is the pdf user manual for it
Champion Strimmer Manual - 64.140.158.30
64.140.158.30/champion/champion-strimmer-manual.pdfChampion Strimmer Manual - 64.140.158.30 homelite: operator's manual 25cc string trimmers - owneriq - read your operator?¢?€?™s manual your manual ...
Jul 17, 2016 | Garden
Champion strimmer 25 cc cord
its a pdf
64.140.158.30/champion/champion-strimmer-manual.pdfhomelite: operator's manual 25cc string trimmers - owneriq - read your operator?¢?€?™s ... kimmel manual kawasaki petrol strimmer tg24 manual ' champion ...
Black decker troubleshooting
ensure the spool is not ended if so replace with new spool of string. also check the retaining screw in the middle is not too tight. undo it one click at a time to alow the spool to unwind when the motor runs
always disconnect your strimmer from the power when doing this also wear protective footware and long trousers, when using such tools.
May 20, 2014 | Black & Decker Irons
Purchased a gardentec petrol strimmer a while back from netto store...where can i get a spool replacment to fit my strimmer.
try Lowes or any Agway, and if that dowsn't work, try checking on line with your type of trimmer.
Apr 22, 2012 | Garden
Hello, i have a B&D GL545 type2 strimmer and it looks like i think looking at exploded drawing its the actuator, a little white plastic bit that slots into the top of the spool in the groove. so my...
yes, there should be a spring, it maybe cheaper and less of a headache to just buy a replacement head, if not at any home improvement stores they sell parts for mowers/trimmers. Good Luck Tim
May 22, 2011 | Black & Decker Garden
How do i fit the spool on my black and decker strimmer model no GL535
guide the two strings thru the holes in the outer ring,then push it down into place,and screw knob on
Jun 21, 2010 | Black & Decker String Trimmer Cordless 12"...
I have a black & decker gt701 strimmer. i recently replaced the line on the spool but now it wont feed, ??
Remove cup from bottom of unit by depressing 2 detent tabs and pulling away from unit.
Replace empty spool with new full one or wind on aftermarket string. Wind in direction of
arrow on spool. Make sure spool is seated on rachet firmly.
Apr 16, 2010 | Black & Decker Garden
Rethreading a garden strimmer
Hi Deborah,
You need to start from the beginning of the trimmer string. Remove the entire spool. Insert the start of the line through and wedge it into the little groove to keep it from coming loose. Now wind the line tightly and neatly in the direction shown on the spool. (it should provide an arrow stating to "wind this way". As you near the end of the line, keep it snug and push the end through the hole where it leads out to the cutting zone. As you re-insert the spool into the housing, make sure it stays tightly wound as you lock it into place. This should help. Usually when your string is too short, you tap the **** of the spool on the ground to advance the line. It should feed a bit at a time, and when you hear it getting cut off, you should stop advancing the line.
Hope this helps.
Apr 13, 2010 | Black & Decker Garden
Strimmer cord keeps breaking
the eyelets on the trimmer head may be worn and cutting the line ..look for groves in the eyeleys may need to replace the spool
Sep 01, 2009 | Garden
Black & Decker String Trimmer Cordless 12" 18V Logo
132 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
