Question about Riccar 8955 Upright Vacuum
Remove and replace belt - Riccar 8955 Upright Vacuum
  • 438 Answers
Hi There,
Here's a very helpful repair that I did exactly for your problem on how to replace the belt on your Riccar. Your model, the 8955 is more difficult then other models due to the rug/floor selector knob. No worries though, I explained this step by step with pictures.
Hopefully this helps you,
http://www.fixya.com/support/t4373126-replace_belt_in_8850_model
Chris Jones
GoVacuum.com
Posted on May 03, 2010
How to Change belts on dc33
The belts are in the clutch. You will need to disassemble the clutch to replace the belts. It's easier to replace the entire clutch. First remove the brushroll, then remove three screws and the cover over the clutch assembly, remove the belt around the motor shaft to pull the clutch from the nozzle housing. It is wise to replace brushroll if it's worn or frayed. I have a tool available to make putting the brush roll back in easier. I also have belts, clutch, brushrolls and filters available if needed.
May 12, 2018 | Dyson Vacuums
How to replace belt on a bissell 66e1 pro heat lift off pet carpet cleaner
There are two belts on your model. Remove the screws on the end cap assembly on each side to remove the assembly to gain access to the belts. Remove the screws holding the brush roll assembly to remove and replace the belts.
Jan 08, 2017 | Bissell Vacuums
Remove housing the change belt on air speed
There are screws that hold the housing for the belts on. Take all these screws out and the housing should come off. Remove the old belt You have to take your vac model number and make and ask either at a vac store or sometimes a hardware store also carries them
To replace you have to take the brush off and you should clean and lightly oil the ends and replace with the belt on then put housing back in place. Replacing all the screws.Don't try repairing with it plugged in.
Sep 09, 2014 | Eureka Vacuums
How to replace belt on dirt ***** broomvac
Remove the cover over the Beater Bar
Aug 18, 2014 | Vacuums
Need to replace belt in eureka envirovac model 4470
You must remove the screws that hold the top cover onto get to the belt. Remove top cover then remove brush roll to install new belt. Replace belt at least twice per year for proper cleaning.
Oct 26, 2013 | Eureka High Filtration s Mighty Mite...
Sears Kenmore Whispertone Vacuum Problem:
If you push inwards on each side of the light cover on top you can remove it. With the light cover removed remove the (2) access screws. Now you will be able lift of the entire top cover from the base. You will then see the belt and roller brush, remove the old belt and replace with a new one. You can get the replacement belt you need here:
Kenmore Whispertone Replacement Belt
Oct 28, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Unable to replace belt
On most machines you have to remove the bottom plate to replace the belt. Simply remove the screws, take out the old belt, put the new one around the motor shaft, then around the brush roll and stretch into place.
Apr 15, 2009 | Vacuums
Kirby g4 belt replacement
Facing vacuum,turn belt lifter knob counterclockwise till it stops.Lift headlight hood,and unlatch brushead,and remove.Looking thru the hole in back,turn belt lifter knob clockwise to release belt.Remove bottom plate,and bend one end of bracket to remove end of brush roll.Slip new belt on and replace brushroll back into bracket,and replace bottom rug plate.Looking thru hole in back,turn belt lifter knob until the hook inside picks up belt.Replace brushead,and again,turn belt lifter knob clockwise to drop belt onto shaft.
Dec 18, 2008 | Vacuums
Eureka vacuum belt how do i replace on model #4688
How To Replace Brush Roll Belt
NOTE: Turn off the switch and unplug the electrical cord
before replacing belt. Belt pulleys can become
hot during normal use. To prevent injury, avoid
touching the motor shaft when checking the belt.
1. Lower handle to floor to change belt.
2. Loosen, but do not remove, two screws to release hood.
Lift hood to remove.
3. Lift left end of brush roll.
4. Remove and discard belt.
5. Place new belt around motor shaft.
6. Place belt around brush roll pulley.
7. Align left end cap with base. Push end cap
securely into place.
8. Pull right side of brush roll to stretch belt.
Secure right end cap into base.
9. Rotate brush roll to seat belt.
10. Replace the hood. Make sure hood front is
behind furniture guard. Hood should seat
onto self-locating screw tabs.
11. Tighten screws.
You can goto this website enter in the model number 4688 and you can see detailed pictures of how to change the belt as well as print off a new user manual.
http://www.eureka.com/servlet/FindOwnersGuide
Regards
Feb 14, 2008 | Vacuums
Belt replacement
Hi.
You are correct there are 2 belts.
They can be tricky to replace most shops will state they cant be replaced & you require new clutch.
So try this site http://dysonmanuals.llc.nu/ for manuals on how to remove clutch unit & replace both belts they are very good with lots of high quality pics.
Chris..
Jan 26, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Riccar 8955 Upright Vacuum Logo
349 people viewed this question
Top Riccar Vacuums Experts
Chris Nomland
Chris Nomland
Jim Parker
Jim Parker
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
