Question about HP Photosmart 812 Digital Camera
I have Internet explorer 8 installed on my pc desktop. Recently the software for my HP 812 digital camera will no lower start the feature to allow downloading of images from the camera chip to the computer, and now the software itself will not start when I click on the desktop icon. How do I get the manufacturer's supplied software to work (like it did for years) with Internet explorer 8 on my computer? Dave
  • dsteckley May 02, 2010
    The recommended download appeared to allow my HP digital 812 software to start and allow for view and print option, but the 'unload' images feature still appears not to activate when I click on that menu item. Is there another update or software patch I require?
    Dave
    This solution got the software to start however the 'unload' images menu item within the software program still will not activate and unload the images from the camera.Dave
  • HP Master
  • 6,487 Answers
This can be a software related problem which is related to Internet explorer and HP releases some software update to correct the problem that you have. Go to this link and download the software update that you need.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=382085&prodSeriesId=56973&prodNameId=56975&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=oj-46104-1
Posted on May 02, 2010
When I unistalled internet explorer 8 by accident but how do i reinstall internet explorer ?
Oops! Well, it may not be such a bad problem. This is what Microsoft has to say about it:
Reinstall Internet Explorer in Windows 8.1 and Windows 8 Because Internet Explorer is now a Windows feature in Windows 8.1 and Windows 8, you can't uninstall it. However, you can turn it off. To do this, follow the steps in the "Turn off Internet Explorer" section in Install or uninstall Internet Explorer (http://windows.microsoft.com/en-in/internet-explorer/install-ie) .
After you turn off Internet Explorer and then restart your computer, Internet Explorer will be removed from your computer.
You can also turn the Internet Explorer Windows feature back on to reinstall it on your computer.
Feb 04, 2015 | Dell OptiPlex Computers & Internet
Tip
Internet Explorer 8 takes longer than expected to start.
Symptom:
When launching Internet Explorer, you may notice that Internet Explorer takes longer than expected to start.
Cause:
This issue can be caused if there are damaged or incompatibilities with installed Internet Explorer add-ons. This behavior may be more visible in Internet Explorer 8 due to changes in the way that Internet Explorer 8 handles the internet zones list.
This issue can also be caused if using Spybot and the Spybot immunization feature is enabled.
Resolution:
To resolve this issue, troubleshoot the Add-ons to determine which Add-on may be causing the issue and then disable or uninstall the Add-on and then contact the manufacturer of the Add-on for support with that Add-on.
To do this, follow the steps listed below starting with Step 1.
Note: If you currently have Spybot installed with the immunization feature enabled, you will need to disable that feature until that issue is resolved. If you’re not sure how to disable the immunization feature, contact the vendor for more help.
Step 1: Run Internet Explorer 8 in "No Add-ons" mode to determine if the issue is Add-On related.
loadTOCNode(2, 'resolution'); Internet Explorer 8 add-ons, such as ActiveX controls and browser toolbars, are used by some Web sites to provide an enhanced browsing experience. An error may occur if an add-on is damaged or if an add-on conflicts with Internet Explorer 8.
To determine whether the error is caused by an add-on, run Internet Explorer 8 in "No Add-ons" mode. To do this, follow these steps:
  1. Click Start, and then type Internet Explorer in the Start Search box.
  2. Click Internet Explorer (No Add-ons). Internet Explorer 8 opens without add-ons, toolbars, or plug-ins.
  3. Test Internet Explorer to verify that it works correctly. If issues still occur, try Step 3.
If no errors occur, the problem is caused by one of the add-ons that typically load together with Internet Explorer 8. In this case, continue to Step 2 to determine what Add-on is causing the issue.
Step 2: Use the Manage Add-ons tool to determine which add-on is causing the issue
loadTOCNode(2, 'resolution'); Use the Manage Add-ons tool in Internet Explorer 8 to individually disable each add-on to determine which add-on is causing errors. To do this, follow these steps:
  1. Open Internet Explorer 8.
  2. Click Tools, point to Manage Add-ons , and then click Enable or Disable Add-ons.
  3. In the Show box, select Add-ons that have been used by Internet Explorer to display all add-ons that are installed on the computer.
  4. For each item in this list, select the add-on, and then click Disable under Settings.
  5. When you have disabled all the items in this list, click OK.
  6. Exit and then restart Internet Explorer 8.
  7. If issues do not occur, repeat steps 1 through 3.
  8. Click Enable for a single add-on.
  9. Repeat steps 6 through 8 until you determine which add-on causes errors to occur.
After you have used this process to determine which add-on is causing errors, you can disable that add-on. Or, you can uninstall the software that installs the add-on. We also recommend that you contact the software vendor that provided the add-on for additional troubleshooting and support.
Step 3: Reset Internet Explorer 8 settings
loadTOCNode(2, 'resolution'); To determine whether a performance issue or an error message is caused by configuration settings, reset Internet Explorer 8 to its default configuration. This step will also disable any add-ons, plug-ins, or toolbars that are installed. Although this solution is quick, it also means that, if you want to use any of those add-ons in the future, they must be reinstalled.
  2. Click Tools, and then click Internet Options.
  3. Click the Advanced tab.
  4. Under Reset Internet Explorer Settings, click Reset.
The information in this article applies to:
  • Windows Internet Explorer 8
Keywords: MS Article ID 969938
on Mar 29, 2010 | Computers & Internet
Cant find the add/remove programs in control panel, im using windows 7.. i want to uninstall IE9 and install IE8
Click the start orb in lower left corner of desktop and type "prog" without the quotes. At or near the top of the list of results that comes up will be "Programs and Features". This is what the add/remove control panel section is called in windows 7. Just click that and uninstalling works the same as it did in xp.
Sep 26, 2011 | Microsoft Internet Explorer 8
Recently I upgraded Microsoft Internet Explorer 8 to Microsoft Internet Explorer 9 and I am having problem with my Real Player, not able to download any program. So I wanted to uninstall Microsoft Internet...
Windows Internet Explorer 9 has been installed as a system update in the operating system, and as such can be removed from the Uninstall an update control panel menu.
To get there click the start orb in the lower left corner of the screen, and then Control Panel in the right menu.
Locate Uninstall a program in the Control Panel and click on the entry.To uninstall Internet Explorer 9 click the View Installed Updates link in the upper left corner of the screen. This opens a listing of Microsoft updates that have been installed on the computer system.
Right-click on Windows Internet Explorer 9 and select uninstall from the context menu.
To complete the uninstallation, the computer needs to be restarted in the end.
After restart ur pc Run reginout cleaner to clean it's registry files
Dec 08, 2010 | Microsoft Internet Explorer 8
I am using windows xp. I recently loaded office 2007, and now my internet explorer (Ver 8) hangs up when attempting to load active x. All the internal settings are correct. HELP!
Install DirectX 9.0c, that should fix your problem. Find DirectX 9 at www.filehippo.com > scroll down to Drivers on the lower right of screen > double-click on DirectX > Download Latest Version > double-click on download to install. The other thing you should do about installing Office 2007 > go back and install it again to get features not installed the first time.
Oct 31, 2010 | Microsoft Internet Explorer 8
Is free internet explorer 8 works as original to protect pc from virus
Hi Guest
Internet explorer 8 itself will not protect your Pc from viruses or malware , but it will make your browsing experience more secure and Avoid you going to phishing and scam sites by using the feature called Phishing Filter and Protected Mode ,
It is always advisable to install a seperate Anti Virus software for your Computer
Thanks And regards Aboobacker S
Jul 07, 2010 | Microsoft Internet Explorer 8
Explorer 8 removal
Steps for Windows 7 loadTOCNode(3, 'resolution'); To uninstall Internet Explorer 8, follow these steps:
  1. Close all programs.
  2. Click Start Collapse this image Expand this imagevistastartbutton.jpg, and then click Control Panel.
  3. Under Programs, click Uninstall a program.
  4. In the tasks pane, click Turn Windows features on or off.
  5. In the list of windows features, clear the check box next to Internet Explorer 8.
  6. You receive a warning message in a pop-up window. Click Yes.
Internet Explorer 8 will now be uninstalled. The system will restart after the installation.
Steps for Windows XP or for Windows Server 2003 loadTOCNode(3, 'resolution'); To uninstall Internet Explorer 8, follow these steps:
  2. Click Start, and then click Control Panel.
  3. Click Add or Remove Programs.
  4. In the list of currently installed programs, click Windows Internet Explorer 8, and then click Remove.
    Note If Windows Internet Explorer 8 does not appear in the list of installed updates, try the alternative steps for Windows XP or for Windows Server 2003.
  5. Follow the instructions to uninstall Internet Explorer 8.
  6. When the uninstall program is finished, restart your computer.
Please rate the answer. Thank you!
Apr 27, 2010 | Microsoft Internet Explorer 8
Am trying to add a tab to my browser (vista) it is the google mail.com tab. how do i do it please
Download and Install Internet Explorer 8 and that's how you can use Tab option.
This Feature of Internet Explorer 8
Oct 09, 2009 | Sony VAIO VA10G PC Desktop
Why keyboard gets stuck on HP notebook while using e-mail
Dear Sir,
From what i understand you have an issue with the keyboard malfunctioning in your email or internet browser....The keyboard mistypes or skips an alphabet or sometimes types one alphabet a couple of times in your email or internet browser... Please check which internet browser you are using if it is Internet Explorer 8 then please uninstall it...We can uninstall the Internet Explorer 8 in 2 Ways...The first is if you have installed it personally then Click on Start - On the right pane click on Control Panel - Click on Programs & Features and uninstall the Internet Explorer 8....The second way to uninstall it is if has been downloaded as a update to your notebook... We need to click on Start - On the right pane click on Control Panel - Click on Programs & Features - On the left hand pane we have an option that says View Downloaded Updates - Go To the Windows option and you will get an option that says Windows Internet Explorer 8 and uninstall it... It will take it back to Internet Explorer 7 and your problem will be resolved if incase it does not then please contact me giving a brief description of the issue...
Aug 04, 2009 | HP Compaq Evo Notebook N600c
HP Photosmart 812 Digital Camera Logo
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
