Question about Briggs & Stratton Gas Pressure Washer 20244
Starting problems unable to start. followed the instructions but does not start
    President:
  • 512 Answers
Sounds like jets are plugged in carb. Take off carb and take apart and spray with carb cleaner. Use jet tools and clean out jets, spray with cleaner real good then put back together. You may need to get a carb kit if gaskets are dry rotted.
Posted on May 03, 2010
Compaq starts on pluging power indicates red signal and stops few second
To help you troubleshoot the issue for unable to start the computer, there can be several reasons. Please find the link given below and follow the step-by-step instructions given on it:
http://answers.microsoft.com/en-us/windows/forum/windows_vista-update/unable-to-start-computer/1fbecac8-06a0-42b1-a7fd-0becc2687f31
Also find the additional link given below that can be useful:
https://technet.microsoft.com/en-us/library/bb457123.aspx
GuruAid.com
Jun 27, 2016 | Compaq Computers & Internet
Unable to adjust power level, the power level button on the control panel does not respond.
Try pressing and adjusting the power level before setting the cook time, or maybe before pressing start. Worked on my Panasonic
Dec 12, 2013 | Microwave Ovens
My xperia x10 gets continuously hanged and then gets into a reboot loop. please help me identify if its a problem with the motherboard or software version as it has started to give such problems after...
Could be either hardware/software.
To eliminate a software problem google "seus" which is Sony Ericsson Update Software.
Try HERE for download if unable to find it.
Install the software.
Start the software amd follow instructions (SEUS takes a few mins to start at first)
Select your handset and continue instructions.
You will need to select the REPAIR option if it tells you your handset is up to date.
If after all of that is done and you still have problems.
Take it back to the shop at tell them it's faulty.
Explain that it only started after it was updated via Sony Ericsson Update Software.
Feb 24, 2011 | Cell Phones
After cleaning show the clean unable 46
Unable to Clean error means purge counter is already full. Please refer below for the instructions on troubleshooting your machine.
You need to enter into "maintenance mode" to start the troubleshooting" procedures.
  1. To enter MAINTENANCE Mode: Press MENU, MONO START, 4X on ARROW UP. (within 2 seconds).
  2. Using arrow up button look for the following: (a). 8 then press SET (b). 0 then press SET
  3. Using MONO START, just press it until the word "PURGE XXXXX" comes out.
  4. Using arrow up button look for the following: (a). 2 then press SET (b). 7 then press SET (c). 8 then press SET (d). 3 then press SET
This is to reset the purge counter. Then press stop/exit
5. Using arrow up button look for the following:
a. 0 then press SET
b. 1 then press SET (To reset unit)
a. 9 then press SET
b. 9 then press SET (To exit Maintenance mode)
If you still encounter the problem, please don't hesitate to call on us again. Thank you.
Jun 10, 2010 | Brother DCP 165C Compact Color Inkjet...
I am unable to set my Canon M155 Printer for the Copy function.
Try scanning and check the image.If it's same the problem is in ribbon cable of scanner.
Nov 12, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
I am unable to re-load XP or Vista. The computer
When the computer first starts up, try tapping over and over the F2 key, or the Delete key. This will bring up the setup screen. Once you get into the setup screen, find the place where it lists all the devices for booting up the computer. Make sure you select the CD ROM as the first boot device. Save the changes, put the recovery CD in the drive, and let the computer start up. Follow the instructions on the screen carefully, and you should have no problems from there. After the operating system is installed, you will have to install all the drivers for your system.
Jun 23, 2009 | Dell Dimension 4600 PC Desktop
Emachine
Probably the only solution is to reinstall all the programs (starting with the Operating System).
If your unit came with a Disk, insert this before turning on and then follow the instructions after you have turned it back on.
Good luck.
Apr 13, 2008 | E-Machines eMachines Desktop PC
Briggs & Stratton Gas Pressure Washer 20244 Logo
502 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
