Question about Poulan 14" Chainsaw
Fuel line replacement on Poulon 2050 14 inch Gas Chain Saw
Is there a special tool needed to reconnect the fuel line into the fuel tank & carburetor?
Any tips on reconnecting the lines is appreciated!
Thanks
Rich
  • Rich Calcaterra May 02, 2010
    Thanks for the two quick replies!
    I thought the fuel line connected to a nub within the fuel tank and didn't pass thru it and the carb side also connected to the same nub but on the other side of the tank, otherwise I think it would leak fuel.
    Hope I am not sounding troublesome with my questions, just confused.
    Thanks again!
  • Rich Calcaterra May 03, 2010
    The nub is designed as is the repair clamp for a garden hose meaning it has raised serrations that grip the hose.
    It takes a bit of force to push the hose onto the fitting which is a problem when you try to connect into the tank.
    Thanks again!
    Brigadier General:
  • 4,088 Answers
First rule is to replace only one line at a time. Needle nose pliers is the only tool you should need. Replace the fuel line from the filter in the tank to the carburetor by removing the filter from the line, extract the line out of the tank, and remove the other end from the carburetor. Use the old line to measure for the replacement. Measure the point where the old line passed through the tank wall down to the filter connection. Mark this point on the new line, and push the line into the tank far enough to attach the filter (which you have checked for plugging), then pull the line back out to the mark. Make sure that you use the proper line for this connection as the filter must flop around to the lowest tank level so that the saw doesn't run dry of fuel when operated on it's side. The other connections are straight forward--just replace one at a time. Don't be stingy in making looping turns as you don't want future kinks. Hope this helps!
Posted on May 02, 2010
Testimonial: "I'll give the needle nose pliers another go at it! Problem is, the pliers aren't able to pass into the neck of the fuel tank from my last attempt."
  • 1 more comment
  • drallim May 02, 2010
    You should not have to push the pliers into the opening where the line runs. Try cutting the blunt end to a point so the point sticks through, then try to grab the pointed end and pull it into the tank interior side. Surgical 'hemostats' usually have a longer reach than pliers. If the line is over-sized, you may have problems with this procedure. Good luck!
  • drallim May 03, 2010
    Do you see this 'nub' that you speak of? Most saws that I have run across, just pass the fuel line directly through the wall of the tank and rely on the line fitting tightly into the hole to block leakage. If you indeed have a 'nub', you can get long 'hemostats' from Harbor Freight tools to work inside the tank. I would think that the relatively long internal line plus the weight of the filter flopping around would work the line off of the nub. Any leakage is into the carburetor area and would be swept into the engine as it evaporates. Don't know if this helps any.
    Any chance the nub unscrews or otherwise pops out? This makes you want to be very sure the lines are bad!
How do you replace a fuel filter for 235e husqvarna chain saw
They are kinda hard to get them out but it is in the fuel tank on the fuel line just get it out the gas tank filler hole then pull off and replace with new one..
Jul 15, 2014 | Husqvarna 235e 16-inch 34.4cc 2-stroke...
No fuel going to carb
Either you have a air leak fuel inline or at fuel tank or a plugged up carb- sour aged fuel or foreign debris
Jun 12, 2013 | Craftsman Sears Chain Saw Manuals Model...
Fuel line is broken 2 inches short from filter in tank. How do u replace line? Do you need rubber grommets etc.
if you go to home depot you can buy a fuel line kit for a few bucks that comes with all of what you need
Mar 01, 2011 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Diagram of fuel lines from tank to primer to carb and back to tank for a poulan 2050 chainsaw.
clip_image002.gifFuel components are onthe "Engine Assembly" & "Handle, Chassis, & BarAssembly" detail pages.
Replacement fuel lines can be found at yourlocal chainsaw seller/mechanic. They are different diameters.
Fuel Line Replacement
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, the output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Feb 21, 2011 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
After replacing the fuel lines on a mac3200 gas is running out of the bottom of the saw, after the tank emptys the fuel quits leaking. the saw runs great though
This is usually because you used a fuel line that is too small to seal the holes they pass through in the fuel tank. When they pass through the holes in the tank they should be very tight so gas cannot leak past the lines.
Jan 31, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
How to connect the fuel lines for Poulan Model # 1950 Chain Saw
The following link should be very helpful:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
A link to a Poulan model 1950 Type 7 follows (may not be your saw, there are 7 different Types and 2 Woodsharks (LE))
http://www.ordertree.com/modelinfo/PWE/1950-Gas-Saw-Type-7/75.1950-Gas-Saw-Type-7.1.59.1.html
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Jul 22, 2010 | Poulan 14" Chainsaw
Need to replace gas line inside mcculloch chain
You need to disassemble the case to get to the fuel tank. Pull out the plug fitting and replace the internals with new factory grade parts.
Jun 30, 2009 | Garden
Loose Fuel Line
Hi rhopdo
Check where is the hole for the fuel line on the gas tank.Take off the fuel filter.Try to reconect the fuel line.
best wishes savumihai71
Dec 01, 2008 | Garden
Poulon Wildthing 18" Gas Chain Saw
Some Poulans vent thru a fuel line going from the tank to the carburetor. Some vent thru the cap but eventually the duck bill valve starts leaking fuel. Then I suspect some people change that cap to one without a vent, which causes the problem you are describing.
Sep 11, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan 14" Chainsaw Logo
447 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
