Question about Zanussi F1045W Front Load Washer
Zanussi f1045w brushes access problem
Hi. i need to swap the brushes how do i access the motor. it looks like i have to lay the machine on it's back and take a plate off the bottom. seems a bit excessive just for brushes but can't see any other way.
  • 269 Answers
Yes you can lay the machine on its back and depending on the type of motor you will need either a posidrive screwdriver or a small 5.5 socket.You will need a torch to locate the brushes which are at the rear of the motor be careful as not to lose the screws in the motor when removing or replacing sometimes a bit of bluetac on the tool you are using can help to hold the screws.Be careful with the new carbons on the brushes as they can break easily,take note as you remove the old ones and locate the new ones onto the pegs and replace the cables.I am not sure of the plate you are talking about.If you have problems then it may be easier for you to remove the motor but you will have to split the body of the machine
Posted on May 03, 2010
Zanussi 1200 essential washing machine, cleaned out filter now will not fill with water
Go back into the machine and check for a disconnected wire cause by cleaning out the filter. Oh and did you remember to turn the water faucet back to the on position? It helps to plug the machine in to the A/C outlet, too. Keep an eye attuned to a safety switch on the access panel as well. It may have an alignment or broken plastic fastening/ mounting design.
Feb 08, 2014 | Zanussi F1045W Front Load Washer
My Zanussi nexus fl881 wont spin. Can you tell me how old this washing machine is and how to fix/whether to get new one?
6/8 years old.....Souynds like new motor brush kit needed. price of parts about £30. plus labour possible 30 mins work to fit..Hope this helps
Apr 01, 2011 | Zanussi F1045W Front Load Washer
I have a Zanussi FLS1183W aquacycle 1050 washing machine. It has stopped spinning and I suspect the carbon brushes. How do I access the motor to examine/replace the brushes?
There is no solid base to this washing machine so if you simply lie the machine on its side you can access the motor from underneath.
Jun 01, 2010 | Zanussi Washing Machines
Zanussi Aqualux washing machine
the belt is a tight fit so you need some strength
remove top. loop belt over the motor pulley and start belt onto drum pulley. turn drum pulley and belt will work its way on. there is just enough room to do this
Oct 08, 2008 | Zanussi F1045W Front Load Washer
indicated low water pressure from your external supply or blocked filters in the fill hose. turn water off, remove hose and check filter in end of hose - it is just a bit of gauze. also look into the valve and clean out if needed
Jul 20, 2008 | Zanussi F1045W Front Load Washer
Zanuusi brushes
I'm pretty sure that it is the brushes;) It's pretty easy, but you must know what you are doing:)
Jan 29, 2008 | Zanussi F1045W Front Load Washer
FITTING NEW BELT ON ZANUSSI WASHUNG MACHINE F1045W
It is'nt any adjustment on those machines. They were fitted with eleastic belts. Is the belt not tight enough, you need a new belt.
Jan 23, 2008 | Zanussi F1045W Front Load Washer
Zanussi F1045W Front Load Washer Logo
149 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
