Question about TurboChef TORNADO Electric Oven
F7 code TurboChef TORNADO F7 code
    Problem Solver:
  • 14 Answers
HELLO the F7 fault code means that you have opencircuit in the , ir thermocouple which is in the bottom element or the thermocouple for the top cc element,
Posted on Jul 22, 2010
We have Turbochef NGC N6. The units high limit thermostat had tripped. Re-set thermostat and found cooling fan not working. also found thermal cut out ( top left rear looking from above ) had also tri
ur high limit trip because ur heater overshoots the program setting for the temp replace ur k4/k5 solid state relay for it controls ur temp for the heater.
Sep 21, 2014 | TurboChef TORNADO Electric Oven
Turbochef tornado electric oven overheating and smoking one transformer is working fine but the new one is overheating
If transformer is looking burnt then replace it . It will show you F3 code once the transformer is. Totally burn. Tell me if you need help . I am tech for turbochef
Oct 14, 2011 | TurboChef TORNADO Electric Oven
Oven is displayin f1 blower and f7 thermostat, blower is not running?
Usually these happen when IO board is about to go. I have experience this . Clean the board and try to plug in wire connector back to the board. If it eke minarets or creates any new error code then you definitely need io board
Feb 11, 2011 | TurboChef TORNADO Electric Oven
How to fix F7 in turbochef
F7: Thermocouple Open
CC Thermocouple
Reads 999?F/C or
IR Thermocouple
Reads 1999?F/C
1. Check the connection of open thermocouple on the I/O control board.
If the connection is OK, verify thermocouple is not an open circuit
by using your ohm meter. The cook cavity thermocouple should
measure approximately 4-5 ohms and the IR thermocouple should
measure approximately 30-40 ohms. Measure at the I/O control board
40-pin connector.
o Thermocouple indicates open circuit: Replace defective thermocouple.
o Thermocouple OK: Replace the I/O control board.
Oct 04, 2010 | TurboChef TORNADO Electric Oven
How Can i change Motor in TurboChef Tornado
Its an easy fix although expencive for the parts. Just remove the rear blower cover then the six 1/4" nuts and it will come out.
Jul 12, 2010 | TurboChef TORNADO Electric Oven
This is the 3rd time for this turboChef oven - door not closed.
it is because the switch kits are not setup properly.they need to set to open and shut in the right order,hope this helps regards lse
Jan 16, 2009 | TurboChef TORNADO Electric Oven
F3 Mag Curr. on Turbochef Tornado
Hello. Interesting coincidence, but that error code is for the magnetron/microwave part of the toaster. You will need to have it serviced by someone familiar with the unit, it could be easy and reasonable, if just a fuse blew, but not likely. If the fuse blew, it is 20amps, so something took it out. Call turbo chef, they will get you to the closest servicer, may be able to help you on the phone.
Here:http://www.turbochef.com/commercial/site.php?PAGE_TYPE=CONTACT
or 1800 90turbo
Hope that helps, and thank you.
Dec 21, 2008 | TurboChef TORNADO Electric Oven
TURBOCHEF C3 AND TORNADO
what setting. the code to get into diagnostic area is 9428.
Nov 22, 2008 | TurboChef TORNADO Electric Oven
TurboChef TORNADO Electric Oven Logo
745 people viewed this question
Top TurboChef Ovens Experts
Dennis Boxerman
Craig Butler
Craig Butler
Are you a TurboChef Oven Expert? Answer questions, earn points and help others
