Question about Black & Decker Garden
Instructions on black and decker gk1635t electric chainsaw of how the chain tensioner is adjusted and set up initialy
    President:
  • 2,220 Answers
Your OM follows:
http://www.2helpu.com/PDMSDocuments/EU/Docs//docpdf/gk1630t,%201640t_gb_md09.pdf
See page 10 please.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on May 02, 2010
How to repair a chainsaw
your clutch springs are weak. replace springs or clutch assembly
Jul 17, 2014 | Black and Decker USA BLACK & DECKER...
I need to repair
The Chain being loose can be caused by not having enough tension on it. The owners manual will explain how to put the tension on your chain and properly maintain them.
May 07, 2014 | Black & Decker Garden
What type of bar chain oil should I use
For spring/summer use, you can use Motomaster ("spring/summer") or Stihl "medium" chain oil. If you use in very cold winter condition, you need thinner oil, specifically made for it.
Feb 02, 2013 | Black and Decker USA BLACK & DECKER...
What type of oil does my black and decker chainsaw GK1635T need
The chain lubrication should be a non fling chain oil, the non fling addative helps to keep the oil on the bottom of the bar where most cutting is done, rathere than spraying off the end of the bar.
Sep 17, 2011 | Black & Decker CCS818 Chain Saw
I do not have a manual.... I can't adjust the tension. It looks like I have too much chain, the screw is as tight as I can get it. Help!! I have a Cordless Chain Saw, model CCS818 TYPE 1.
the bar should also raise and lower when you apply tension onto the blade - one way or the other it shoudl allow you to tighten the blade.,.. If it is still loose after that, you may be more safe to grab a new blade if this is from wear or use.
Also another fyi: If you get these blades hot and too tight, when they cool, they can warp your bar... I always loosen the chain on mine (per owners manual) immediately after use so it will not do any damage when it cools down..
Did you try to find an owners manual at black and decker dot com?
Best regards
Ck
Mar 08, 2011 | Black & Decker CCS818 Chain Saw
How do you adjust the tension in the black and decker 16 inch electric chain saw. The chain is too loose...
UNPLUG THE CHAINSAW. if it's got a bolt or two on the right hand side loosen them, then turn the adjuster screw next to the bar until you have about 1/4 inch slack in the chain. tighten nut/nuts. if it's got tool-less adjustment loosen the cover bolt, turn the tensioner, tighten the cover bolt.
Mar 28, 2010 | Garden
I WANT TO ADJUST THE CHAIN TENSION
On the front of the chainsaw under or on side the blade you will see a screw that is inside the cover. Loosen the one or two nuts that hold the cover and blade on just a little. Then turn the screw I talked about clockwise and you should feel the tension adjusting on the blade. If you do not you may have some broken pieces and further inspection is necessary.
Sep 09, 2009 | Black & Decker Garden
Garden Logo
1,099 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
