Question about GE WBSR3140DW Top Load Washer
Adjitator does not move
Mahine turns on but washer adgitator does not move
    Guru:
  • 351 Answers
If the machine will spin but not agitate, then the transmission needs replacement. You should probably get an estimate from an appliance tech to see if it is better to replace the part or the machine.
Posted on May 04, 2010
  • 20 Answers
Could be the agitator coupling is stripped out
Posted on May 07, 2010
How to fix an activator/agitator not working
If the drain motor filter is cleared out and still not working then you are going to need to replace the motor in your front loading washer I had lightening strike near my home once and although it would still adgitate it would not spin properly or even adgitate properly After having service men come out a number of times I ended up replacing almost every part including the motor which finally fixed the problem
Apr 23, 2014 | GE WSXH208A Front Load Washer
Adjitator is loose
my clothes are soaked after spinning and leaked water in the floor adgitator is loose
Feb 20, 2013 | GE WBSR3140DW Top Load Washer
The whole tub on the machine moves from sise to side when adjitating
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Jan 06, 2011 | GE Washing Machines
Adjitator won't work
if the adjitator and the spin cycles do not work the coupler between the motor and the transmission is at fault
May 23, 2010 | GE WJSR2070B Top Load Washer
Our washer does not spin. It vibrates, but when you open the lid, it is clear that nothing has moved.
Does the washer adjitate well during the wash cycle. If the washer fills and pumps oput the water but does not adjitate or spin well the coupler that couples the motor to the transmission is stripped and worn our.
Nov 28, 2009 | Cars & Trucks
Washer wont agitate, but drains and spins ok
hello. i can assist you. when a washer won't agitate, one of several expensive repairs are in order. If your washer is more than 5 years old I recommend replacing as opposed to repairing. That said if you want more information on what might be wrong get back.
Nov 03, 2009 | GE WBSR3140DW Top Load Washer
My machine will just stop after the adgitate cycle.
Manually turn the knob to the spin cycle and turn it on.
If it does not spin, replace the lid switch.
If it does spin, replace the timer.
Feb 24, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer Adgitator
To answer your question, both. It could be the reason as your washer agitates, it is moving back and forth in short increments. This can cause the bolt to back out. However, the rubber washer is not the only thing to hold the bolt in. When the bolts are installed in the factory (and also replacment bolts from the manufactuer) they come not only with a rubber seal that helps keep the bolt from turning, but also the shaft of the bolt is coated in a thread-loc substance. I would recomend adding some thread lock to it (availible in hardware stores, auto parts stores, and even in wal-mart). If your bolt still persists in coming out, I would visit my local appliance parts store with my model number (located under the lid towards the rear) and purchase a replacment agitator bolt. These are fairly inexpensive. It will come with fresh thread, thread -loc and a new rubber washer, all of which will help to hold it in correctly. If you have any more troubles, send me a message back.
Jun 28, 2008 | Washing Machines
GE WBSR3140DW Top Load Washer Logo
321 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
