Question about Kenmore Refrigerators
I have a kenmore top freezer refrigerator, it has water coming into the refrigerator from the freezer, I have cleaned it.
  • 1 more comment
  • cherylharp54 May 02, 2010
    We could take the very bottom off, the rest does not come off, we see what looks like a drain, but I can't see where it comes out of the freezer, I can tell that the drain pan under the refrigerator is not getting any water in it. I cleaned as much off the coil and compressor as I can get to. The model of my refrigerator is 106.0658615.
    Kenmore model 106.9658615...I cannot find the drain
    the tray has no water in it. I cannot find where the drain starts. I see it at the bottom where it should be going into the tray but it is not
  • 3,866 Answers
Ok pull the fridge out and check the tray at the bottom is that full or is the drain clogged? You need to empty that try and unclogged that hose if not you get this issue 9 times out of 10, let me know ether way please do click the accept button for my efforts today.
Posted on May 02, 2010
  • Grand Canyon Tech
    Grand Canyon Tech May 02, 2010
    this means its clogged any why its residing inside your going to need a repair guy flush that out
  • 1,170 Answers
    1. Step1To correct the problem, you must locate the drain and inspect it for blockage. Often, you'll find it frozen, but it's usually always solid debris blocking the flow of the water that's CAUSING it to freeze: and that must be removed from the drain or it WILL happen again.
    2. Step2Where is the Drain?
      After unplugging the fridge from the AC power, go ahead and pull the unit out where you can access the back. This is also a GREAT opportunity to clean dust off of the condenser coils and compressor, which will GREATLY lower your energy costs! (Use a Vacuum with brush attachment)
      Depending on the model of refrigerator in question, the drain port can be located in several places. The most likely location is just under the freezer, which is actually the top of the fresh food compartment: The tube usually comes out there, and down the outside of the refrigerator; (On Back) However, it can also be under the coils behind the false back and/or side walls. At any rate, when looking for it, keep in mind that its' sole function is to drain water away from the evaporator coils when the unit is defrosting itself; Therefore, it's almost ALWAYS just under the freezer at the end of a "channel" that directs all of the water into it.
  • Arjun Komath May 02, 2010
    1. Step3Cleaning the Drain... Depends on what's causing the clog.
      If it's iced up, the quickest way to thaw it is with a hairdryer. It takes just a minute with the hairdryer set on max.
      Before you get happy and close everything up though, ALWAYS check the tube for debris.
      About 95% of the time, I've found something in a frozen drain line. Remember: It wouldn't have been frozen in the first place if the water had been able to drain off!
      After checking the pan under the freezer for debris in the pan and exit hole, you'll need to check the tube itself. The best test is just to blow through it like you would a straw. If it's clogged, you'll feel some resistance.
    2. Step4To clear a clogged pipe: There are numerous ways, but the most efficient is to use a can of electronics duster. (ONLY the kind that comes with a nozzle extension tube) WITH A PAIR OF CLOTH OR LEATHER WORK GLOVES ON BOTH HANDS!: Stick the nozzle extension down into the drain tube. Wrap one hand around the top of the tube and the nozzle to form as tight a seal as you can, and press the trigger. The clog should be blown right out: if not repeat as necessary. Reconnect it all, then pour a little water through it and check for leaks. Hope this helps!
  • Arjun Komath May 03, 2010
    Part #325 is the drain.
    You can see a picture of the drain hose : http://www.appliancepartspros.com/PartIm...
There is an opening in the refrigerator part just under the freezer. I have water coming from it draining into the fridge section. What can be done?
There is a drain trough at that point, for the defrost water, that is clogged.You need to clean it out. It may have iced up.Hope this helped.
May 18, 2011 | Kenmore 63074 Top Freezer Refrigerator
Water leaking inside of frig, seems to be coming from vent below freezer
Usually if a refrigerator is holding water this means that the condensate from the freezer is not going down into the pan in the bottom, the water has to go somewhere so it ends up in your refrigerator. Find the drain line in the bottom and try some how to blow it out, if you can do this and clean the pan you should be ok.
Mar 21, 2011 | Kenmore Top Freezer Refrigerator
Water coming from freezer vent into refrigerator
the drain hole in the freezer is clog ,
open the freezer back wall and make sure the drain hole in the middle bottom under the coils is free al the way to the pan next to the compressor. you clean it with hot water and a pump, use hair dryer first if it is frozen on the top. good luck let me know if you need more help.
Jan 11, 2010 | Kenmore 64802 Top Freezer Refrigerator
Kenmore top freezer/frig has water coming out underneath applianc
THE HOSE THAT COMES FROM THE FREEZER TO THE TRAY EITHER ISN,T LOCATED IN THE RIGHT POSITION OR IS DETACHED WHERE IT COMES OUT THROUGH THE WALL
Aug 11, 2009 | Refrigerators
Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
Jul 01, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water in bottom of frigerator
Hi, The drain is plugged coming from the freezer section. Please get me a model# and I can assist you with this problem. Thanks Vic
Jun 14, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Water is leaking on the top shelves in my kenmore refriderator water is leaking on the top shelves in my kenmore
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freezer.
May 31, 2009 | Kenmore 64802 Top Freezer Refrigerator
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freezerr
Apr 28, 2009 | Kenmore 64802 Top Freezer Refrigerator
Kenmore refrigerator leak
I have an Amana refirgerator with a top freezer and had the same problem. I turned off BOTH the frig and the freezer for 24 hours. That allowed every thing to dry out. It has been running now for a week with no problem.
Jun 26, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore Refrigerator-Freezer top
install a defrost drain tube heater call sears for a part number have the model handy befor calling
Apr 21, 2008 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Refrigerators Logo
32 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
