Question about Weber Genesis Silver A Grill
Burner won't ignite
Gas is getting to the burner, but the crossover ignition doesn't turn on the burner. We grilled last night, and it ignited, but the flame, even when on high, was extremely low. Could this be a cleaning problem of some sort? If so, how would we go about that?
    Guru:
  • 1,051 Answers
Eventually grease and other debris will accumulate around the burners and require cleaning. Remove the burners, they should pull straight up and out and clean any grease. Also clean the inside of the base as best as possible. Replace burners and you'll be enjoying a grilled meal in no time.
Posted on May 05, 2010
Poor flame after changing tank on gas grille
Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
Jul 05, 2014 | Weber Genesis E-310 Gas Grill
Natural gas grill low flame
Did you change the reg , lpg burns at 14 inches wg nat gas burns at 4inches wg
Feb 16, 2013 | Char-Broil Commercial Stainless Steel...
Viking range burners won't light
from I review I found it might be this...Simple replacement of Glow Bar igniter requires removal of entire front panel with many screws
so sounds like your igniter might be shot - it heats up to ignite the burners - easy fix - get a long torch lighter and just light the gas after turning it on -
Nov 05, 2017 | Viking VGIC485-6G Gas Kitchen Range
When I try to light my brand new Q300, it won't ignite. I can hear that the tank is on and gas is being sent to the grill. However, it doesn't light. When I shut the grill off and the gas tank...
What you have is delayed ignition. It's being caused by the gas regulator. It is solvable, though.
Turn the gas tank valve OFF and disconnect the hose from the tank.
Wait 5 minutes and reconnect the hose to the tank.
Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
Once the valve is fully open, light 1 burner and turn it to HIGH. Did the burner light and does th eflame height look correct? If so, light the remaining burner the identical same way. Now, to both flame heights look correct? If so, you solved the problem. Remember to always open the tank valve Very, Very Slowly. And always light the burners with the Lid/Hood Open.
If the above did not solve the problem, you will need to replace the Hose/Regulator Assembly. Since your grill is brand new, the Hose/Regulator Assembly will be covered under Warranty. Have your Proof of Purchase handy and call Weber 1-800-446-1071. Also, if you haven't done so already, register your grill before calling http://help.weber.com/register/ even if you don't need a new Hose/Regulator Assembly.
Hope this helped you troubleshoot & solve the problem.
Jul 06, 2011 | Weber Q300 Grill
Crossover does not ignite
The gas ports on the burner that feeds the cross over may be blocked. You have to remove the cooking grates and flame tamers. Light the grill and make sure all the ports are open on the burner that lights with the igniter. If the flame stops along the burner, then it will not light the cross over to the next burner.
Jul 02, 2011 | Weber SPIRIT E-210 (NG)
We just used the grill the other night went out to cook tonight will not ignite ....I can hear the gas so that is not it ...any suggestions? I am newby at all this but have been doing fine .....
Are you saying the ignitor won't light the burner(s), but you can hear gas going thru the burners?
If that's the case, try match lighting the burners. That's a good way to find out if you are really getting enough gas for combustion.
If after match lighting it, you find that burner flames remain low, even when they're turned to High. Here's what you need to do:
1. Turn the gas tank valve OFF.
2. Disconnect the hose from the tank and wait 5 minutes.
3. Reconnect the hose to the tank and open the tank valve VERY, VERY SLOWLY (Slow Motion,
slow).
4. Once the tank valve is fully open, try lighting the burner farthest away from the tank first and turn
it to High. Did the burner light and the flame height looks normal? If so, light the remaining
burner(s) the same way. Do all the flame heights look normal? If so, you solved the problem.
Remember to always turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Pleas let me know and Happy Grilling, Newby!!
Jun 15, 2011 | Char-Broil 7000 Quick Set Gas Grill
The crossover tube won't ignite past the first few inches from the front element. I have tapped it to clear it, cleared teh little side holes and even ran a wire through it (as a few of the...
If the cross over tube burner has rusted to the point of collapse is a pretty good indicator that it needs to be replaced. I personally, don't see in correlation between LP tank and the collapse of the crossover tube burner. A weak tank, as you called it, would not have any bearing to it.
Now, if you're match lighting the other burners and the flame height remains low, even when turned to high. That's a problem with the grills regulator, which can easily be solved.
Turn the Tank Valve OFF and disconnect the hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Open the tank valve VERY, VERY Slowly (Slow motion, slow), until the valve is fully open. Light the burner farthest from the tank first and turn the burner to HIGH. If the flame height now, looks correct, light the remaining burners the same way. If all the flame heights have returned to normal, you solved that problem.
if it didn't solve the problem, you need to replace the grill's hose/regulator assembly and the crossover tube. The hose/regulator assembly can be purchased at any home center or hardware store, that sells gas grills and accessories. Tank the old one with you for comparison purposes. The Crossover Burner can be purchased from Weber or Factory Appliance Parts http://www.appliancefactoryparts.com/
Hope this aids you in troubleshooting and solving the problem. Please let me know. Thanks and Happy Grilling!!
May 27, 2011 | Weber Genesis Silver B Grill
Shortly after igniting the infrared burner, and while the burner is still heating up, the gas will explode spontaneously, blowing out the flame.
What you have is partially delayed ignition, This could be caused by a manufacturer's defect or the burner is clogged with debris. To test this theory, when you're preheating the burner, preheat on the lowest flame setting that you have, that will keep the burner lit. After 8 to 10 minutes, gradually turn the flame up to high. If the burner responds as it should, you shouldn't get that delayed ignition problem. If you do get it, the burner is defective and should be replaced.
Hope this helps solve your problem.
Feb 28, 2011 | Fire Magic Infrared Burner System For...
Weber Genesis Silver A Grill Logo
350 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Are you a Weber Grilling Expert? Answer questions, earn points and help others
