Question about Dryers
Kenmore dryer Mod# 110.96591220 has worked fine UNTIL... wife put another load of clothes in and now it will not start at all. It has power, the timer works butm will not start. Help!
  • Dryers Master
  • 19,396 Answers
Hi.
The overload had caused overheating, blowing the thermal fuse. The fuse is located on the exhaust of the dryer.
Here the part:THERMAL FUSE (Disposable Thermal Fuse)
If that does not fix the problem, test and eventually replace thermal cutoff and thermostat. Both are tested disconnecting them from circuit and reading Ohms at room temperature. Set multimeter on impedance at Rx1. If the parts are good, they must read zero or very low impedance.
Here the kit :THERMAL CUT-OFF (Thermal Cut-Off Kit).
Here all diagrams for your appliance.
Regards.
Ginko.
Posted on May 10, 2010
2009 Kenmore Dryer. Wondering why it seems to only work on 1 drying cycle? Everytime I try to put it on another cycle all the lights flash and beep...and nothing...
sounds like the washer might not be spinning the water out of the clothes good enough . 1 60 minute cycle should dry them more than dry enough .
Oct 18, 2015 | Kenmore 8804 5.8 cu. ft. Electric Dryer
Kenmore model# 96281100 elect. dryer
Jimbo, this dryer uses a cyling thermostat to turn the heater on and off. If your vent is pinched or clogged, or the vent to the outside is clogged, you are going to have long dry times and damp clothes. Try doing a load with the vent disconnected from the back of the dryer. If everything turns out ok, then it's a venting issue. Catriver
Sep 14, 2007 | Kenmore 63942 Dryer
Our Kenmore Front loader Dryer Mod # 110.61402310 i put our clothes in the Dryer and powered it on and then Nothing wont Power on
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released. hope it helps
Feb 13, 2015 | Kenmore Dryers
My wife dried a load of clothes took those out put in another load,dryer would not come on?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 08, 2010 | Kenmore 62602 Electric Dryer
Kenmore mod 110 87870110 gas dryer- at first push
the vent could be plugged and unit is going into thermal overheat if it works in timed dry properly then the moistier sensor is faulty.
Dec 01, 2009 | Kenmore Dryers
My Kenmore Mod 110.68722700 clothes dryer stops drying the clothes if run too long. The lights are on but it appears to power off. Any help please?
Let it cool down completely. Disconnect the vent from the back and turn on the dryer. See if there is proper air flow. Try running a load with the vent hose off. If it works now the vent hose is clogged.
May 24, 2008 | Kenmore Dryers
Dryers Logo
95 people viewed this question
Top Dryers Experts
