Question about Sony PlayStation 2 Slimline Console
My lene is busted, can i use the usb instead of cd
My lens is busted, can i use the usb instead of cd to play games?
Why will my xbox let me play some games but not other on live when i used to be able to play them all?
Check all X Box games for scratches on the surface of each CD Disk.
Keep in mind, each game CD is read by lens Laser from the inner then to the outer edge of CD Disk.
Most people believe CD's are played like a record, from the outer edge to the inner.
If there are scratches, CD may be damaged beyond simply cleaning.
All cleaners and methods of cleaning are not the same.
Contact the manufacture of the CD to find out the best method of cleaning
or possibly repairing so game can be played.
If you CAN play some games and NOT others, this rules out a Laser Lens Player fault condition. Look for a reason of the CD will not play in the Laser Lens Player.
Here is the top 5 reasons CD's will NOT play.
1.) CD in inserted into player wrong way?.
2.) CD surface is dirty or dusty?.
3.) CD is possibly warped or bent?.
4.) CD surface is scratched?.
5.) Wrong CD/ or format for CD player?.
Hope this lists helps!
FASTESTNASCAR
Jan 01, 2012 | Microsoft Xbox 360 Console
How do i clean the lens on white owl night vision
Well! harley with 38girls, if they are dirty on the inside of lenes. This Night Owl has four or five lenses. Therefore, it needs to taken to a camera shop for they can clean the inside of the lenes. For the out side of lenes, get a camera lenes clean kit. These kit can be used to clean eye glasses. One more thing here, make sure that you have lens covers for this NV monocular. I hope this help you, stewbison.
Jul 24, 2011 | Night Owl Optics NONEXGEN-W Monocular
Will not read the disc
open xbox and clean lens or buy a replacement Lens £7 online
(open xbox cleanthe lens with a q-tip and isophyol (sorry spellin might be poo) if that fails then u can buy lenes off the internet and there cheap they work £7 at the most
Nov 26, 2010 | Microsoft Xbox 360 Console
Acer aspire 3690, my cd-rom will play movies, audio and some old games can be read but mostly refuses to read most of my game disks now, any ideas??
Try an external DVD drive that you can connect to your USB port. The drive you have in the laptop either has a dirty laser lens, which you can carefully clean with a "Q" and alcohol, or the laser itself may be going out. The drive can be replaced. You mentioned you have a cd-rom. If you can play movies (DVD) it is more likely a DVD drive instead of a cd-rom. CD-ROMs can only read data or music.
Nov 19, 2010 | Acer Aspire 3690-2196 Notebook
Ps3 console will play ps2 games but does not load ps3 games
This is a sign that the Blue ray lens for your PS3 is busted. Try to contact Sony if your PS3 is still under warranty. IF not, try to buy yourself a CD lens cleaner kit. This costs around $5-$10.. hopefully it fixes the problem.
Mar 14, 2010 | Sony Playstation 3 (PS3) Console
Why my ps2 not play games only play video,But Before My Ps2 Play Video And games too, what is my ps2 problum plz help, my emai: bowram_brt@yahoo.com thanks
When your console does not read any disk, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only few CD, DVD. After more prolonged usage , often the PS start losing the rest of functions, and ends up not reading anything at all.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD/DVD cleaner disk to clean the lens. If that does not work you will need to disassemble the PS, and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD lens, or the whole drive unit.
before doing tis, contact Sony to check if the unit can be replaced or repaired by Sony, you find the number on the Console documentation.
Sep 18, 2009 | Capcom Video Game Consoles & Games
My PS3 has stopped recognizing games
it has something to do with the circuit inside, maybe the blu-ray lens reader laser got weak, the blu-ray diode just got busted there are tons of possibility the best thing you can do is that call the manufacturer and have them take a look
Sep 07, 2009 | Sony Playstation 3 (PS3) Console
Ps3 games not playing
your lens is dirty but the disk cleaners dont normaly work i been told to use compressed air and spray it in the cd drive (do this at your own risk of course) or gone bust , some ps3 s use a certain lens sometimes they work for yrs sometimes they last a week some a few months
150 if u need to get one from sony
about 40- 60 to buy a lens seperate ( easy to replace)
Apr 17, 2009 | Sony PlayStation® 3 (60 GB) Console
Disc doesn't play
yes its 100% lens problem.the lense of the ps2 consists of two parts,one is the one that reads the dvd disc and the other one that reads the cd-r only.the dvd reader is already busted that is why it only recognises only some cds which are cd-r's.try replacing the lens and you can play dvd discs again.hope this one helps
Jan 01, 2009 | Sony PlayStation 2 (PS2) Console
Why doesnt my PS2 read Twisted Metal Black?
Try cleaning the disc and the lens or try a diff disc and see if that plays. if it does your cd's busted.
Jun 08, 2008 | Sony PlayStation 2 Slimline Console
Sony PlayStation 2 Slimline Console Logo
21 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
