Question about Electric Mobility Mobility Electric Power Scooter Wheelchair. Heavy Duty
Scooter stops intermittenly
Fully charged battery and the scooter stops as if battry is down. The batteries are new. If I wait a few minutes it runs ok.
  • 177 Answers
Hi. Does the machine stop suddenly, or does it slowly stop as it normally would? Does this happen on hills or slopes?
A lot of scooters have a self-resetting circuit breaker connected to the battery leads. If the machine draws to much current ( amps ) then the circuit breaker trips out. After a few minutes the circuit breaker will reset and you can continue.
This could mean that the circuit breaker is faulty or that the motor is drawing to much current, or is burnt out.
Some machines have a very light duty circuit breaker, and these can trip out often. I have changed many of these circuit breakers for this reason.
Check all your battery leads are secure and tight.
If it is still a problem, get a serviceman to check the motor current is what it should be.
Good luck. Neil.
Posted on Jun 07, 2010
Scooter runs fine but when I come to a stop, it shuts off and I have to turn the key and and off before it will start again. It has new batteries and is fully charged.
you are loosing connection in your control circuit, check all connections including the batteries and their connections.you can also see other options at Scooter Doctor App
Nov 17, 2015 | Electric Mobility Rascal Scooter...
How can I fix This problem. after about 1.5 miles the scooter comes steadily to a stop. waiting for a few minutes it will go again Ok.
The motor is overheating. The service manual will tell you how to test. Pride has a service manual you can download from their website.
May 20, 2014 | Pride Go-Go Ultra X 4-Wheel
I have a golden companion II 3 wheel scooter with new batteries, the problem isafter a complete charge the scooter starts off fine but gradually loses power as indicated by meter in 5 to 10 minutes. A
hi ,there are two parts to batteries holding power and preforming well, firstly how good are the batteries, secondly how good is the charger ?, good batteries and a bad charger will make the batteries appear bad...
Regards
Rob
www.gewizrepairs.co.uk
Feb 22, 2014 | Golden Technologies Golden CompanioN II -...
Battery fully charged but not power to run
Measure the battery voltage individually. If each battery has less than 10 volts, charge them with an automotive style NON automatic battery charger.
Jan 11, 2014 | Pride Celebrity X 4-Wheel Electric Scooter...
My scooter will not fully charge
This could be the charger socket is worn and not making a good connection when charging or it could be the charger itself at fault. Now you have changed the batteries, I presume new and both the same type, you need to look at the charging side.
Apr 03, 2013 | Rascal 600 T Electric Scooter w Seat Lift...
My srtrider will only go for a few feet then comes to an abrupt stop its abit like the back wheels jam..but then it will go for another couple of feet then come to a stop again there are no warning lights...
If your batteries are running very low, this is the most likely source of your problems. 80% of my scooter repairs involve batteries. The fact that your scooter runs is a good thing. The fact that it runs only a few feet and gives you no error code when it stops indicates the electronics have no battery power to indicate a flash code. The back wheels jamming probably relates to a no power condition causing the brake to lock (it takes power to release the brake and turn the motor)
This scooter uses two U-1 batteries that last between 1 and 2 years. From your description, I would replace the batteries first and make any further determination of any problems, if any,after that. These batteries are available locally at a large discount (between $50 and $160 each) and can be installed with basic tools, saving you money on the labor charge.
Shop around for the best price. Charge the new batteries fully before use. Enjoy.
Hope this helps.
Nov 25, 2010 | Electric Strider Midi 4 Wheel Mobility...
TRITON #PL3-01 HAS NEW BATTRIES, BUT WILL NOT MOVE WHEN HAND CONTROL IS ACTIVATED. WHERE MIGHT PROBLEM EXIST.
mcdevito75 here, Most likely at the battery connection, are the battery--ies fully charged?? check connections at battery, and motor.
Jun 23, 2010 | Pride Luxury Line Maxima Scooter - 4 Wheel...
Scooter dash lights flash up and down .were normaly they come on and stay at top .they just constantly run up and down ..batteries show on charger in boot .that its fully charged
Hi. Some scooters will show a pattern like this while the charger is operating, but when the charger is turned off it should stop. Some internal chargers have a relay that is activated while the charger is on to disable the scooter. Does the scooter operate properly after the charger is turned off? If not, then unplug the charger where it connects to the batteries inside the scooter and see if this helps. If this helps, you might need a new charger.
Good luck. Neil.
May 14, 2010 | Electric Strider Maxi 4 Wheel Mobility...
I have a pride victory xl8. Problem - was running
All scooters have a protection system built in to prevent burning up the motor, and the user, should the scooter overheat. It sounds like yours overheated. If the temp. outside was warm to hot, and your weight is near the weight limit for the scooter, and you are taxing the motors over a hill, or unstable terrain, then the scooter goes into "limp home mode", or just enough to get you a bit aways, and then it will turn off. After a few minutes to cool off, it will go again, but shut down fairly quickly because it takes a spell to let the whole transaxle-motor assembly to get cool.
Check your weight, and anything else you may be carrying with you on the scooter. Check the terrain, and incline you are going against. Throttle down for all these occassions. If you overloaded the system at some point, then you may have overheated the brushes. Remove them (2) with a standard screwdriver and see if the copper coil is still flexible and springy. If not, replace it/them.
The damage may already be done, so it may need a new motor/transaxle assembly. An expensive proposition I'm afraid.
Jun 28, 2009 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Electric Mobility Mobility Electric Power Scooter Wheelchair. Heavy Duty Logo
501 people viewed this question
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
