Question about Sony PlayStation 2 Slimline Console
My PS2 On/Off Button is Jammed
The button to start up my PS2 is jammed. whenever i try to push it, it wont move. its like stuck. HELP!
  • 55 Answers
This site should help you get the case open.
http://www.neoseeker.com/Articles/Hardware/Guides/ps2diy/
you need to get in there and find out what's causing the button to stick. It could also be the button on the front of the drive that's stuck. if that's the case you might be able to pop it back out once you get the outer PS2 case off using a knife or a small screwdriver.
Posted on Mar 25, 2008
Seat belt won't buckle. What should i do?
please open the buckle assembly. Pretty sure something is stuck in it. clean all parts and reassemble.
Aug 28, 2017 | Seat Cars & Trucks
SINGER 9960 Quantum Stylist 600-Stitch Computerized Sewing MachineWhat's your problem?
once it jammed it jammed the gears inside also, witch maybe plastic.
If thats the case it maybe toast!
Jul 15, 2012 | Sewing Machines
2003 ford transit turbo manual gearbox, stuck in 2nd gear, cant start
does the clutch push normally or is the linkage broken not disengaging clutch, and then does shifter move around or locked and wont move, loose linkage in shifter or gears are jammed inside transmission and something went, if shifter wont move at all then trans is jammed inside and needs repair.
Jun 09, 2012 | Ford Transit Cars & Trucks
Dryer turns on but does not start when i push the start button. The timer comes on all the buttons light up, light is on inside dryer, but does not start just makes a sound when i hit the start button
if it's a humming sound the motor is bad or something is jammed keeping the motor from spinning.open the dryer door and move the drum by hand if the drum can't be moved the belt could be jammed on something or there's something stuck in the blower wheel.the blower wheel is behind the duct that the lint filter slides into.if you can move the drum then you most likely have a bad motor,try spinning the drum and push the door switch in and have someone else push the push to start button and see if the dryer will start,if the motor has a flat spot it could start like this.let me know what you find
Jul 14, 2010 | Kenmore 62602 Electric Dryer
Remote quit working.....tv comes on and goes off by itself at various times
Sometimes Buttons on remote control "stick" underneath the faceplate. It's possible the on/off button is jammed. A lot of times when a button is jammed the other buttons fail to work.
Could also be the reason you needed to replace the batteries with a button being continously pushed will drain the battery life.
Push every button on the remote and kinda wiggle each button while pushing to possibly see if its stuck.
Hope this helps.
May 26, 2009 | Norcent Technologies PT-4291HD 42 in....
Gas dryer won't start.
if the motor hums when you push the start button but wont move you probably have a frozen motor. happens from too much lint packed around the motor and ruins the bearings. if you can access the motor from a front kick panel you can check this. possibly something is jammed in the blower wheel as well. unplug it and check it out
May 24, 2009 | Dryers
The menu that controls contrast, brightness ect is stuck on the menu and when i push the number 1 button on he monitor it does nothing but lock the osd. If i hit the down button the contrast will move down...
Try pressing the number 1 again. It should exit the OSD. While the screen is stuck with the OSD. Press the power button (blue) and push to turn it on again.
Hope this helps.
Mar 15, 2009 | ViewSonic VX924 19" LCD Monitor
My slimline ps2 switch is jammed
if you have warrenty by all means get it repaired , but if not go onto ebay buy the switch unit and Turn off the ps2 while on to discharge it , make sure you touch your hand on a metal object every 15min open up the ps2 and on the right or left should be the switch and you pull on the ribbon VERY LIGHTLY and it should pop out (cable)and you should be able to take out the switch and then replace switch and connect it .Close the console and see if it works
Nov 18, 2007 | Sony PlayStation 2 Slimline Console
Won't shut off
press and hold the on/off button
Oct 22, 2007 | Coby MP-C7085 MP3 Player
Help front panel wont work and treble +10 keeps coming up by itself
Check all of the push buttons on the front panel.. I have seen that sometimes a switch could have gotten jammed or pushed an and broken and the button gets stuck and wont let anything else work
Sep 21, 2006 | Yamaha HTR-5650 Receiver
Sony PlayStation 2 Slimline Console Logo
97 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
