Question about Sony Ericsson XPERIA X10 Cell Phone
My sony xperia wont charge I connected it with the std supplied cable and it wont charge ?
Sony Ericsson X1 is not charging plz help me whats the problem how i charge my mobile
Posted on Apr 21, 2012
  • 3 Answers
I had the same problem, its quite common fault with the X10's i phoned up my network and they sent me out a new base unit for the phone and works fine... make sure you have all contacts saved before your phone fully dies as you wont be able to access the unit again EVER unless you borrow a battery, changing the battery wont work its a problem with the phone itself :)
Posted on Apr 09, 2011
Change the usb ic
Posted on Dec 24, 2010
Standard charger only charge Li-Ion. X10 is using Li-Po. So, make sure it is compatible.
Posted on May 03, 2010
How do i connect sony mobile phone to sony tv
Watch and listen to your Xperia TM content on your TV
Open this link & watch this video will let u know how to connect sony mobile to bravia via mirroring.
Thank You
Dec 01, 2014 | Sony Cell Phones
Sony xperia t troubleshooting
restore settings
or this one note all data will be deleted
How to Soft Reset or Reboot or Restart SONY XPERIA T LT30p ?
To soft reset SONY XPERIA T LT30p, press the POWER BUTTON KEY for several seconds, we will see the menu to restart or turn off. Choose restart/reboot than the SONY XPERIA T LT30p will do the soft reset or restart. This is safe to do because non of important data or applications will wipe or erase.
#Option 1, Hard Reset SONY XPERIA T LT30p with Software Menu :
  1. Make sure the battery is charge properly
  2. Turn on SONY XPERIA T LT30p smartphone
  3. Don't forget to backup all important data
  4. Go to menu: Setting > Backup & reset > Factory Data Reset > Erase internal storage > Reset Phone
  5. Choose Erase everything to continue and confirm you ready to do the format SONY XPERIA T LT30p
  6. The SONY XPERIA T LT30p will continue the step until ready to use in clean factory default.
#Option 2, Hard Reset SONY XPERIA T LT30p with Flashtool applications:
  1. Flashtool in the applications from Sony can be download from Sony website.
  2. Flashtool software need to installed in you computer and ready with USB data cable
  3. Make sure SONY XPERIA T LT30p battery is charge properly or full charge
  4. Power off SONY XPERIA T LT30p
  5. Boot SONY XPERIA T LT30p to flashmode with using: Volume Down Button and connect to USB cable at No.1 above
  6. Follow the menu at you computer display, it is easy to understand the steps.
#Option 3, Hard Reset SONY XPERIA T LT30p with Hardware Key Button:
  1. Make sure the battery fully charge
  2. Do not forget to backup all important data
  3. Turn off the SONY XPERIA T LT30p
  4. Press and Hold together: Power Button + Volume Up Button for several seconds
  5. Follow the menu at LCD screen to continue the hard reset SONY XPERIA T LT30p
You can choose the step options above to do hard reset while the SONY XPERIA T LT30p get problem or not running well. But we always suggest to do routine backup before your smartphone get problem. If SONY XPERIA T LT30p already stuck or run slowly or not responsive, then better try to do backup as you can because all important applications will be wipe or removed from SONY XPERIA T LT30p after doing master reset, but some data which saved at memory card will be safe, better to remove the microsd memory card before doing the hard reset.
Jun 16, 2014 | Cell Phones
How to nulock sony xperia s lt26i
solution 1, Hard Reset SONY XPERIA S LT26i with Software Menu :
  2. Turn on SONY XPERIA S smartphone
  4. Go to menu: Setting > Backup & Reset > Factory Data Reset > Reset Phone
  5. Choose Erase everything to continue and confirm you ready to do the format SONY XPERIA S
  6. The SONY XPERIA S will continue the step until ready to use in clean factory default.
solution 2, Hard Reset SONY XPERIA S LT26i with Flashtool applications:
  3. Make sure SONY XPERIA S battery is charge properly or full charge
  4. Power off SONY XPERIA S
  5. Boot SONY XPERIA S to flashmode with using: Volume Down Button and connect to USB cable at No.1 above
solution 3, Hard Reset SONY XPERIA S LT26i with Hardware Key Button:
  3. Turn off the SONY XPERIA S
  5. Follow the menu at LCD screen to continue the hard reset SONY XPERIA S
Be careful before doing this step to master reset, because all important data and applications will be removed from SONY XPERIA S, we always suggest you backup all important data before performing the hard reset.
Dec 19, 2013 | Sony Ericsson XPERIA S LT26I Nozomi Arc HD
Xperia arc LT15i wont turn on
the charging pin of ur phone is not working properly ..... take it to the service statio they will fix the problem
Nov 06, 2013 | Sony Ericsson Xperia Arc
My Xperia x10i isn't coming on and it was on charge overnight
Looks like you have problem with usb cable or usb port. Try to use another cable. If it will not help - check connection of usb port to main plate. This service manual will help you.
Sep 27, 2013 | Sony Ericsson XPERIA X10 Cell Phone
My new sony experia arc s wont turn on
If it is NOT TURNING ON,.. PLEASE try:
1.Go to PC companion -> Sony Update Service and select phone update without connecting your phone.
2. Select your device and download the update (DONOT CONNECT PHONE)
3. When the download completes it will prompt for connecting you phone.
4. Before that phone must be switched OFF (donot turn on).
JUST PRESS DOWN THE VOLUME DOWN KEY AND CONNECT THE USB CABLE.
5. The Phone's LED will glow green and the update for phone will start.
6. After the update completes you will get the phone as an fresh new Operating System.
(WARNING - YOU WILL LOOSE ALL YOUR DATAS AND GET A FRESH START)
Apr 13, 2013 | Sony Ericsson Xperia Arc S
Sony xperia x10 went dead wont charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Nov 12, 2012 | Sony Ericsson XPERIA X10 Cell Phone
Unlock code
First Option:
Second Option:
Aug 31, 2012 | Sony Ericsson XPERIA X1 Smartphone
My xperia is not charging and a blue light is on. help.
id face the same problem..my xperia x1 wont switch on or charge..i luv this phone..i dont knw what the prob is.. plssssss help me :(
Apr 10, 2010 | Sony Ericsson XPERIA X1 Smartphone
Sony Ericsson XPERIA X10 Cell Phone Logo
1,839 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
