Question about White Mountain F69206X 6 Quart Ice Cream Maker
Motor screams like bearing is bad - White Mountain F69206X 6 Quart Ice Cream Maker
    Problem Solver:
  • 15 Answers
If you dont have any luck getting them to replace the motor, send it to me... I can repair it. See here for information.
Posted on Aug 28, 2012
    Problem Solver:
  • 5 Answers
The newer White Mountain Freezers have Chinese made motors with a history of problems. Read the reviews for the 4 & 6 quart freezers at Amazon. If your freezer is less than one year old contact the manufacturer for replacement or repair. You can also purchase repair parts from them if it's out of warranty. Here is their website:
http://www.jardenstore.com/
Posted on Aug 16, 2010
Motor making loud noise and Shaft not turning Is repair possible
The bearing or bush of the motor would be faulty. try to put some oil on the shaft.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 10, 2016 | Cuisinart Ice Cream Makers
Can I somewhere donwload instruction of this machine? Don't work chocholate line and leaking syrup machine must be turn off or I can do ice scream and repair on the same time? Taylor Combo 8634 HT
Maybe providing Make and model of your up to nw unspecified ice cream maker someone might find instructions.
Actually, you can find them yourself, using Google search for terms
MANUAL MAKE AND MODEL of Ice Cream Maker.
Oct 23, 2015 | Ice Cream Makers
I have an ice cream maker ice 45u but the mixer blade is not turning. The power is there because i can hear it and when i pull the leaver down the cogs turn on the sprinkler system are turning i have...
Check that all gears are in good working order. The paddlewill not turn properly and the motor will not run if the gears are worn ordamaged gears. Inspect the paddle for damage and replace if necessary. You alsomay need to replace worn or damaged gears in the motor. Lubricate the motor,drive shaft and motor bearings. Hope this will help you. Good Luck.
Sep 03, 2011 | Cuisinart ICE-45 1.5 Quart Ice Cream Maker
A loud noise coming from the machine when I arrived at the store this morning. When it is on standby, the machine makes the noise as well as when it is on auto. Therefore, I just turn everything off, and...
You could have a few things going on, maybe a bad probe or board, sounds like you might have your temp too high it depends on the sound it is making, is it screaming or grinding. Easiest and cheapest first fix is too replace blades, they should be replaced every 3 months unless it is used alot like a yogurt shop then monthly
Apr 15, 2011 | Taylor 632-27 Ice Cream Maker
My Taylor 754-27 on the right side will stop workng just as the porduct gets up to consistancy. Do you think it is a weak or bad motor. The motor just stops and then when the product starts to warm up I...
Hi Lori and welcome to FixYa. I am Kelly,
If you have someone capable of swapping controllers between units move the controllers side to side by exchanging positions. I think you have a controller problem. Via the viscosity control (soft / hard) it senses amperage of the motor while in use. You either have a bad controller or a bad temp control. If you swap controllers and the problem persists then the temp control is bad. If the symptom changes to the other side then the controller is bad.
Thanks for choosing FixYa,
Kelly
Mar 26, 2011 | Taylor 632-27 Ice Cream Maker
Why is the beater scraping the cooling drum?
Check drive shaft alignment,bent beater assy and scrapper blades.
Dec 04, 2010 | Taylor 632-33 Ice Cream Maker
New motor makes loud noise when operating
Use a food grade grease to lubricate the gears. The newer White Mountain freezers have Chinese made motor drives and are a piece of junk. Don't confuse the newer models with your old American built machines. If it's still under warranty contact the manufacturer for warranty repair. Read the most recent customer reviews for the 4 & 6 quart electric freezers on Amazon and other websites. You will see a rash of motor failures!
Jul 20, 2010 | White Mountain F69206X 6 Quart Ice Cream...
My freezer turn for a few minute then stop but motor still run
mcdevito75 here, You may be overloading the motor, follow the recommendations in your owners manual, or, the motor could be going bad.
Apr 22, 2010 | Rival 8605-M 6 Quart Ice Cream Maker
Taylor Y754-27 Soft Serve Ice cream machine
Gearboxes definitely go bad. The first sign is usually noise, I would describe it as a rumbling. The best way to determine if it's the gear box is:
1. empty and disconnect machine from power.
2. remove the freezer door and beater assembly
2. remove the rear panel - 4 screws
3. Remove the belts on the noisy side
4. Spin the big pulley and listen for the noise, you may want to remove the belts on the quiet side to compare the two.
I have a video that was shot to help change the hex coupler, but you would follow all of the same steps to replace the gear box.
Dec 12, 2009 | Taylor 632-27 Ice Cream Maker
White Mountain F69206X 6 Quart Ice Cream Maker Logo
689 people viewed this question
Top White Mountain Ice Cream Makers Experts
ray gallant
Ruth summersides
Are you a White Mountain Ice Cream Maker Expert? Answer questions, earn points and help others
