Question about Cooper Hammering
Wired Leviton 5225-1 switch the same way that switch was wired that came out and the breaker keeps going out. The Leviton switch is wired exactly as the Cooper switch that I took out, that was working, but the Leviton No. 5225-1 switch keeps popping the breaker.
  • 10865 Answers
SOURCE: Installing a Leviton 5225 switch with outlet.
A switch is wired using the hot wires only, the black wire. It is simply a break in the line so that when the switch is off no power flows and when the switch is on the power does flow.
You are correct that the middle outlet would have two black wires and two white wires.
If you want to tap into that middle outlet and run power up the wall I suggest you look into some wiremold products. Go to their website, or any home depot and check it out. Get back if you think I can help you further. I am an electrician.
Here is a link that may help you.
http://www.make-my-own-house.com/electrical-wiring-diagrams.html
Posted on Jun 02, 2009
  • 2841 Answers
SOURCE: I have just installed 2 Leviton decora switch with
This is a single pole light switch and should be wired as any other SP switch. The only difference is that is has a pilot light. All the white neutral wires are tied together and then pushed back in the box with none connected to the switch. The grounds are tied together with a jumper wire connected to the green screw on the switch. That will leave you with 2 or more black wires. If you have just two normally you can connect them to the two screws on the switch and it does not matter which screws. However it may be that with the pilot light you need to connect the wire going to the light to the top screw and the power wire to the bottom or vice versa. Try both ways. If you have more than 2 black wires you need to connect the incoming power black wire and outgoing power black wires together and then jump to one of the screws on the switch. The black wire left over is the black wire going to the light itself. If none of this works then it is obvious the pilot light in the switch is burnt out.
Posted on Jan 06, 2010
Testimonial: "Thanks a million. I will recheck the wiring tomorrow. Chas"
  • 351 Answers
SOURCE: how to install leviton 5225 wsp wall
For this combo , the white wires connect to the two silver screws on one side of the combo .The black power wire connects to the screw next to the switch. IF you want to have the receptacle hot all the time then jumper the hot black from the switch screw to the receptacle screw. The screw in the center is for the black wire from any lihghts that you want to control. IF it is the receptacle that you wish to control with this switch .. then the power connects to the screw next to the switch and the center screw jump a wire to the screw next to the receptacle
Posted on May 04, 2010
  • 403 Answers
SOURCE: I have a thermosol AF 240 steam generator it is
Is the wire compatable for a 50 amp breaker. Also unit souuld be on its own dedicated curcuit, also how many amps is the service in the building, if your only at 100 amp it will not work.
Posted on Mar 06, 2011
  • 140 Answers
SOURCE: I replaced my old 3way
Sounds as if you have a bad illuminated switch. The little LED or light inside the switch is itself possibly bad. Return it to the store and get a different one.
Posted on Jul 15, 2015
Two of the electrical outlets in our kitchen have no power. I checked to make sure the connections were tight and they were, still no power. Then I replaced both of them with new receptacles (ones that...
Each outlet receives power from previous outlet box or switch box in a long chain of parallel wiring back to ceiling box, or junction box, and then back to circuit breaker.
Use process-of-elimination to find problem.
Locate all boxes on same circuit breaker. Locate box before the two dead boxes... it can be in ceiling light, or switch box, or outlet box. Then test those wires. Look for loose quick connect where wires are pushed into hole on back of device, or loose white wires twisted together and shoved to back of box.
http://waterheatertimer.org/See-inside-main-breaker-box.html
http://waterheatertimer.org/How-to-wire-switches.html
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 03, 2013 | Leviton 10 Brown Switch Outlet...
Wired in 5224 switch using (1) white wire and (3) black ones and it popped the breaker. I switched the wires and now both toggle switches control same light. The previous switch controlled a light and a...
10-25-12
Copy following link for wiring diagrams for Leviton double switch.
http://waterheatertimer.org/How-to-wire-switches.html#double
Only 3 wires will connect to switch. Not 4
If you blew breaker than you connected Neutral wire to switch.
Neutral wire never connects to switch.
Identify Hot wire.
There is only one Hot wire that carries power to switch box.
This wire connects to one side of device ... which side? ... the side where both screws are bonded together.
Oct 25, 2012 | Leviton Electrical Supplies
Light switch outlet
Sounds like you are wiring a combination switch and outlet:
Open following link for illustration:
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#combo
May 24, 2012 | Leviton Combo Switch Receptacle - 5225-T -...
I AM TRYING TO REPLACE A LEVITON 5225 SWITCH IN MY KITCHEN. DO YOU HAVE WRITTE INSTRUCTIONS ON THE NET AND IF SO, HOW DO I DOWNLOAD THEM, OR BRING THEM TO MY COMPUTER FOR READING?
Leviton 5255 is a switch-outlet combo
Open following link for illustration and written instructions for combo wiring:
Add a comment if you have trouble with wiring.
Take a moment and vote on answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on switch or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 27, 2011 | Leviton 5225WSP Switch and Outlet
What model Leviton GFCL should I use? My wire is a 600 volt 12/2 with ground. Said wire feeds other GFCL outlets.
Any off-the-shelf GFCI sold today with work on 12-2 wire:
By code, 12-2 wire should be connected to 20 amp circuit breaker, but typically most switches and outlets wired to that circuit are rated 15 amp. Amp rating is printed on electrical devices.
Leviton 15 amp 7599-W:
http://www.amazon.com/Leviton-7599-W-Receptacle-Feed-Through-SmartlockPro/dp/B000VYO9MU/ref=pd_cp_hi_3
Leviton 20 amp 7899-W
http://www.amazon.com/Leviton-7899-W-SmartlockPro-Indicator-Wallplate/dp/B000N663PM/ref=pd_cp_hi_0
Wiring:
http://waterheatertimer.org/How-to-wire-GFCI.html
Jun 17, 2011 | Leviton R01-7299-0NI Switch And GFCI...
I replaced my old 3way toggle switches with the LEviton 5613 3way lighted rocker switches. Wired exactly the way the older toggle switches were wired. Switches work fine just like the older ones but one...
http://www.leviton.com/OA_HTML/ibeCCtpItmDspRte.jsp?item=4044§ion=10103&minisite=10025
The Leviton page for Leviton 5613 does not have a troubleshoot.
Manual shows simple wiring diagram.
3-way switches will not operate lights if switches are wired incorrectly.
Check your ground wire is connected.
Leviton 5613 series is illuminated.
Check that both switches have 5613 number.
Swap switches and see if problem is inside switch.
Nov 13, 2010 | Leviton 5613-2WSP Grounded Switch
The black to switch is broken at switch-----source is from light ---no neutral can I connect a combination switch ? ----light controlled with toggle ---plug hot all the time. ...
If I understand correctly you want to replace a switch with a switch-plug combo?
A switch-plug combo requires a neutral wire on the silver screw.
The black hot wire from breaker goes to the dark-colored screw.
The black wire going to switch goes to gold-colored screw.
If this is not correct and you want more help, add a comment.
Nov 03, 2010 | Leviton Combo Switch Receptacle - 5225-T -...
Old switch only has three screws, with a white wire connected to the sliver screw and a green wire connected to the copper screw and the red screw is on the other side. Where does the red wire go on the...
I don't understand your problem. Green wire is ground goes to the yoke. it should not have any current on it If it does sumbody messed up real bad!
a combo outlet/switch has three brass screws and one nickel screw. yoke should have a green hexagonal screw.
Oct 25, 2009 | Leviton Combo Switch Receptacle - 5225-T -...
Jun 02, 2009 | Leviton 5225WSP Switch and Outlet
Can not figure out who to wire mt swith/outlet
without the right tool its going to be hard to figure out but it sounds like whom ever wired it use one of the white wires as a hot wire and one of the black wires as the switch leg once you figure the out the other black and white wire would get wired to the outlet side like a normal outlet black to brass and white to silver
if you need anymore help or questions write me and ill see what i can do
Apr 05, 2009 | Leviton 5225WSP Switch and Outlet
Hammering Logo
64 people viewed this question
Top Cooper Hammering Experts
John Trevino
Steve
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Cooper Hammering Expert? Answer questions, earn points and help others
