Question about Bosch 24 in. SGS47E02 Exxcel Free-standing Dishwasher
Light on.Timer on.No water is coming in.Machine not starting
Have cleaned all filters. The last few times it was working it started to make more noise than usual. This machine is 6 years old and has been
trouble free. Any suggestions?
I could not check the pipe that lets the water in but we have never had
any problem with this before.
We keep the salt and rinse aid always topped up.
  • 901 Answers
May be pump problem. Air trapping inside the pump also makes this noise. Add water in the chamber direct manually. Close the door and start the cycle. If the running is Ok, it is air trapping problem. Next wash load it will be alright. Otherwise clean the pump.
Posted on May 03, 2010
Coffe does not come out, it starts sounding that it will then it stops
If you remove the porta filter, will water come out when you turn on the pump? If so, your porta filter is clogged and soaking it in white venigar will unclog it. To keep it from clogging, after each use, put it back on the machine and run hot water thru it until the water runs clear. (Remove grounds first)
Does water come out the steam wand?
When was the last time you ran a cleaner thru it? The Saeco de scaler cleaner is designed specifically for your machine. Purchase from Amazon for about $10.00 and use every six months.
if it still won't work,melt me know.
Feb 28, 2015 | Saeco VIA Venezia
Start up prgram
see the cause and fix it:
test the water inlet valve, is not coming power, test for voltage.
2)test the timer can be faulty, clean the contacts, loose wires,connector clean and tigh. very well.
3) see if you model has control board, read your instruction manual for some codes, and put to function auto diagnostic test.
God bless you
Jul 18, 2012 | Washing Machines
I have a Whrilpool washer model LHW0050PQ 2. It will work perfectly then will not spin. At the end of the cycle the done light just flashes. If I choose to just choose spin cycle you will hear it go...
This is almost certainly a simple problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum.
Locate and clean the filter. There is a round unscrewable filter cover on the front of the machine at the bottom right, behind a small door. Many models of this design also have a small hose to the right of the filter cap that you can pull out, remove a plug from and drain off any water in the filter before you remove the filter its self and get your floor wet, so take a look for this before you remove the filter and get soaked.
If this IS the case, you need to call the repair guy out again and when he gets there, kick him all round the house until he gives you a refund foe his last 2 visits!
Jul 11, 2011 | Whirlpool Washing Machines
My Jacuzzi jetted tub has stopped working. During the last 3 or 4 times used, it initially wouldn't work when I turned the timer dial switch on, however, after a few minutes it started working. It also...
other than your switch , it could only be the moter or connection to it. always make sure you have enough water in the tub before turning it on or you'll ruin it.
Sep 17, 2009 | Home
Sensing light comes on and then the timer stop going down
I do nto have a solution- just the exact same problem. My machine gets stuck on 76 when doing a "normal wash" . last night I hit cancel and drain, then went to "time saver" and ran the wash and it seemed to work fine. Funny that both of our amchines stop at 76. Any ideas?
Nov 18, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Fujitsu Heat Pump - problems with timer? When starting the heat pump - the operation light, together with the timer light blinks twice, then the operation light blinks another five times. Then the...
I had the same problem. The heater did not work in heating mode. However it was OK in air-conditioning mode. The operation light and the timer light blink twice and then the operation light blinks for 5 times followed by few seconds non blinking, then the cycle repeats again. I have read on the internet that you better unplug the power cord and then plug it again so that the heater re-sets itself. My only problem was that my heater is directly plugged to the power with no visible plug. So I went to the main distribution board and put off the power for about 20 seconds for the whole home. HOORAY!! The heater worked after that.
Jun 24, 2008 | Fujitsu Heating & Cooling
Indesit w93 washing machine fills with water but doesn't start washing
Hi there. I have an old model, the indesit WM12. Never counted the flashing light (yours was 10) but my dial started clicking constantly at the drain part. I called Idesit and they told me it was a blockage in the filter.
The filter they speak of it located, on mine, at the front of the machine at the very bottom on the right. It is a black dial about 3 - 4 inches in diameter. Unscrew that anti-clockwise (a real pain because so much water comes out. My wife and I unscrewed it, filled a baking tray with water, screwed it back up, emptied / substituted tray then same all over again - until empty. Though putting it on drain again and again helped at same time). When I pulled out the filter found a 'colour catcher' sheet in it. We used them first time ever the other day. Removed that, gave filter a wee clean and, hey presto, all is working again. Hope that helps. Jim
Feb 26, 2008 | Indesit W 123 Front Load Washer
Kenmore air purifier- model 85500
Power Off the unit then Press and HOLD the Off-Timer and Function buttons at the same time WHILE Powering the unit back On. The Replace Filter light will blink for 5 seconds than go out. Now you can release the the buttons.
Just to make sure everything is working fine power off and on the unit.
On a side note if you are a tight wad like me you may want to just smak the filter layers against the ground a few times to clean them and re-use them / make them last longer. When the replace fileter light comes on too often then it is time to replace the filter.
No worries ;o)
CDA
Dec 18, 2007 | Air Purifiers
Washing machine shuts down in spin cycle
Try the "spin only" button to take the water out of your machine. If this does not work, take the pipe from the wall socket and lay it on the floor for the water to spill out. The spin normally does not work when the outlet filter is clogged; if the filter is clean you should then check your pipe coming out from under the tub (plug off the wall first before doing all these things). Last check your outlet pump, could be blocked with something. Refit carefully, you might need a nice pair of pliers to get the grip clip on and off the pipes.
The outlet pipe into the wall stands at a particular height, refit exactly to this height, about 3 feet from ground.
Nov 29, 2007 | Washing Machines
Light comes on but machine doesn't start
well lets see, you have one of two or both, the water level switch or the timer, if the machine dont recive a good level of water(depend on the seting) it dosent start washing, but if the water level switch dont receive curent from the timer, it wont work, so you gona need a tech any way....good luck
Aug 06, 2006 | Hoover PE235 Front Load Washer
Bosch 24 in. SGS47E02 Exxcel Free-standing Dishwasher Logo
319 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
