Question about Marantz PM-68 Amplifier
Hi,when switching on the AMP it always makes a "clicking"sound once. Now it keeps "clicking" all the time. No affect on the sound but it is disturbing me.... What can it be and how can it be fixed? Regards, Michel M
Sharp 29 inch crt tv on timer flashing
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 01, 2015 | Sharp Televison & Video
No picture no sound. Red led blinks once relay clicks once and repeats
These blinks [flashes] are fault indication. You can get an idea about the faulty stage circuit inside the TV, by the number of these blinks. Count it carefully, by switching it ON and OFF, more than 2 times at least, so that, you can make sure about the number of these blinks. If you wish to get more details, check the site linked here. Surf the site in "MOSAIC" view.
Jan 25, 2014 | Sony KV-XF34M65 34" TV
I am making late payments from last three months. Is it the reason of getting my credit score down?
You should be more responsible about making payments. Late and missed payments really affects your credit score. Credit score shows how responsible you are, but if you can not make payment in time and have a low credit score, it will be quite hard for you to get a good financial offer in future. But it's never too late to work on your credit, so you need to start making payments in time and do you best to pay off the debt. Late payment is always a bad thing and always affect you credit, even if you use a loan for bad credit or fast cash loans.
Feb 16, 2012 | Computers & Internet
I have a '96 samsung 25" tube tv. model # TXE2546 - series # 3CAG700429. when i turn it on it has always made a click sound a couple of seconds afterwards. the "power & timer" led light flashes about...
This problems the FBT-the Flyback Transformer have cold solders.Must resolders the FBT.The right side wall of the FBT-the "H" horizontal transistor,must be also resolder too.
Oct 18, 2010 | Samsung TXJ2754 27" TV
My LG washer keeps displaying DE and makes door clicking noise and if it unlocking the door and will not start a cycle. We have bought a new door sensor, and control panel. What else can it be?
Hi dear.According to your explanation,MAIN PWB ASSEMBLY is faulty.Not the door lock or control panel.However you can try this & see if it's works.I hope that helps.Thanks. Does the spring of Latch Hook actuate?If No:Replace door assembly
Is there clicking sound once or twice when the
START/PAUSE button is pressed to start the cycle? If No:Check the DOOR SWITCH
ASSEMBLY Connector and
MAIN PWB ASSEMBLY
(Red 4 pin and white 4 pin
connector (1)).
Is DOOR SWITCH ASSEMBLY broken?If Yes:Replace the DOOR
SWITCH ASSEMBLY
Aug 21, 2010 | LG WM-2277HW Front Load Washer
Automatic headlights don't work all the time on 1999 Buick Regal GS with 144,000 miles. Intermittent problem. Sometimes they work and sometimes they don't. I always keep headlight switch on middle...
hi,
you had specified as, the headlights are not working properly & making a buzz sound.The problem is the circuit has a loose connectivity either at the switch or near the bulb. while you are able to hear the buzzing sound check the position of the wires near the source of sound. You will be able to find where the connectivity should be tightened exactly.please do this as early as possible since the loose connection can damage the circuit and the switches due to high temperature.
thanks, have a nice day.
Feb 09, 2010 | 1999 Buick Regal
My amp has 2 channels, clean and distortion. distortion works, but the clean channel doesnt. When i hit the button, it switches the distortion off, but there is no sound. The distortion light stays on...
initially you want to think bad solder joint, but it think its a bad mosfet or rectifier or diode. it would be hard for an untrained person to identify your problem let alone an experienced tech. it may be time to move on to another amp. in my shop it would be at least 65 bucks for the repair. so where did the "heat"/energy go from that point and what parts were affected. there may be a domino affect. burn one part, not usually.
yostamplifier.com
Jan 17, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
No sound whatever
when you switch the unit on make sure that you hear two clicks, this will tell you whether the protection relay is working. Should you hear the two clicks this will indicate that the audio ic`s are working. There are fuses inside the main component box, four on the transformer. Let me know the outcome
craig:)
Jan 20, 2008 | JVC MX-J900 CD Shelf System
No sound and picture or video
please help !!!! is it an expensive fix ? yes it is too expensive to fix it better to buy new one. as even you fix it , it will always give you problem. good luck
Oct 06, 2007 | Sony KV-27FS13 27" TV
Marantz PM-68 Amplifier Logo
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
