Question about Waterway Above Ground Hi Flo Pump
I have a SP-10-1N11CB above ground water pump - does it require oil?
Why would it lose prime
Many reasons!!! Air is getting into your plumbing system, before the pump... On the suction side. Our at the shaft seal. Check all threaded fittings in front of the pump reseal as required. If above ground pump is easy to check all the way to pool. Which will include skimmer and main drain. If in ground, very difficult to check skimmer and M/D. Good luck.
Feb 21, 2015 | Pool & Spa
How does a home well water system work?
Deep well.
Pressure valve located on front of above-ground-storage-tank will turn pump on-off depending on amount of water pressure inside tank.
When water is consumed inside home, the pressure valve responds to the lower pressure and closes electrical contacts... sending electricity to water well pump located deep underground.
The pump turns on and lifts water through a pipe into the above ground storage tank.
When the tank is full of water, the pressure valve senses the higher pressure and turns off electricity going to pump
Pump shuts off.
There is a one-way check valve on the water line going down to pump, and this keeps water from flowing back down into well.
The above ground tank maintains water pressure for the house.
When pressure is reduced by taking a shower, the pressure valve turns pump on again, and cycle repeats.
Aug 20, 2014 | Water Heaters
SP-1510-Z1-XEHC
bad motor on pump need a new one
Jul 06, 2014 | Hayward 1hp Power Flo Matrix Above Ground...
Sp-1510-z1-xehc above ground DE filter. How much DE
the part number you listed has nothing to do with a DE filter. try again
Jun 23, 2014 | Hayward 1hp Power Flo Matrix Above Ground...
The 2906 motor pump use oil
the oil that comes out is pool water and some thick lube
not sure if its suppose to be dry graphite
but i would not add oil , just dry from pool water
Jun 15, 2014 | Smartpool Dolphin Robo - Kleen Above...
A pump is operated for 6 hours daily to deliver 0.028flow of water to a tank 12m above the ground. calculate the amount of energy and power required
0.028 what? It takes much less energy and power to raise 0.028 teaspoons of water than to raise 0.028 acre-feet of water.
Jun 11, 2013 | Office Equipment & Supplies
Robo - Kleen Above Ground Robotic Pool Cleaner seems to be leaking oil? Also, fan does not seem to be running all the time?
Motor is in oil bath. When it leaks that means water is getting into motor housing. Try and take apart to clean and dryout. Then needs to be sealed and filled with oil. This worked with mine not sure what type oil. Looks like mineral oil or something similar.
Jul 02, 2011 | Smartpool Dolphin Robo - Kleen Above...
I recieved a Sp 0711-A13 Hayward Pro Series sand Filter and I have no idea how to hook it up. What are the requirements to attatch it to my above ground pool? There is no paper work.
you can go to http://www.haywardnet.com and get all the info you need. You can download a manual there. Go to products, and then above or inground and then on literature&manuals
Jul 23, 2010 | Hayward SAND FILTER, PRO SERIES
I am starting an above the ground pool with a salt water system
25 pounds per 1,000 gallons or 3 kg per 1,000 liters of water.
Jun 02, 2010 | Intex Automatic Salt Water System for ...
I have a 1 hp hayward sp above ground pool that needs bearings
This is not a projcet for the light of heart. By the time you buy the tools nessary you could have this done by a motor shop for about the same money or quite often for less. You can get a book on how this is done at your local library if you want to do this yourself. It will still give you general instructions as their are a lot of different brands and styles of motors.
Apr 30, 2010 | Pool & Spa
Waterway Above Ground Hi Flo Pump Logo
756 people viewed this question
Top Waterway Garden Experts
Ian Kime
Ian Kime
Mike Raino
Level 1 Expert
john h
Are you a Waterway Garden Expert? Answer questions, earn points and help others
