Question about Garden
I am experiencing a problem with an air-lock in an in-ground spa gravity feed 6? main drain. If have repeatedly forced through water to clear the air-lock and also tried sucking out the air-lock. Pushing water from the collector tank to the spa main drain seems to have the most successful results and for a period of approximately 1 week I seem to have trouble free operation. After that, the air-lock seems to re-occur. I believe that I screwed up when plumbing the main drain as I followed engineering instructions to fit a 90 degree elbow at 18? below the spa beam which has basically created a high point in the gravity line. I fully understand that if I can clear the air-lock, this will not be a problem. At no time does the water fall below this high-point. The main drain pipe is about 180ft in length so I am aware that there could have been a lot of air trapped, but after 6 months of trying to clear this air, I am becoming very confused and frustrated. I do not believe that I am losing any water in the pool or spa. Here are my questions: 1) If I did have a slight break in the spa main drain line, is it at all possible that it might result in sucking in air rather than losing water? Silly question, but I am at that point! 2) The water is sanitized by an Intellichlor salt chlorine generator. Is it possible that any part of this chemical process might create a gas which would cause my air-lock to re-occur? 3) Are there any other know reasons that might explain this reoccurring problem?
  • steve58641 May 02, 2010
    Hi
    Please confirm that what you said is true for a gavity feed system.
    The pump is not directly connected to the main drain. I would have thought that any air in the water returned to the spa would float to the surface of the spa and dissipate, as can be seen visually.
    Incase it helps, I have already tried changing the pump. I changed it from a 1/5HP to a 2.5HP pump about a month ago as part of my troubleshooting.
    Thanks
    Steve
  • 11,896 Answers
There could be a few things preventing your jets from pumping water. If you just drained your hot tub, it is common to have an air lock in the plumbing and you must bleed the air out of the lines. Look for tiny bleed screws on the end of the pump. Open these bleed screws to allow air out. Always do this with the power off and be ready to close them quickly because water will spray out with the air. If you have a bleed screw on top of your filter, be sure to bleed air from there too. After bleeding, try turning the power on again and see if the jets work. You may have to bleed the lines several times before the jets fully function, but you should see an improvement each time. As long as you get the majority of air out of the lines and the jets start flowing again, the remainder of air will work its' way out.
If you didn't just drain your tub and you don't think you have an air lock, try the following:
1) Is the high speed pump working? If yes, skip to step 2. If no, check the voltage at the pump. If there is voltage, your pump is faulty and needs to be replaced. If there is no voltage, test back to the power source for open circuits or switches.
2) Is there good water flow out of some of the jets? If yes, skip to step 3.
If you don't have good water flow, try the following:
- Take apart the pump wet end and look for obstructions or a broken impeller.
- Make sure your filter is not clogged and is clean. If in doubt, try running your spa without the filter and see if there is an improvement.
- Check for closed or broken knife valves (gate valves).
- Make sure the water level is not too low and the floating weir on the skimmer is not stuck.
3) If you have good water flow out of some of the jets, look for jets that may be closed. Many jets can be adjusted for pressure and can be turned off at the jet. Also look for loose or worn out jet seals and check the nozzles for obstructions.
Posted on May 03, 2010
  • 426 Answers
Yes it is possible that air is getting into the line, in very small amounts at a time but it likely is not your plumbing work rather, air bubbles that are in the water caused by the pump, Check all of your seals for leaks and if necessary fix the highpoint and see if that solves your problem, if not you will need to look elsewhere
Posted on May 02, 2010
Spa won't start after cleaning. What might be wrong?
After draining a spa it is common to get an air lock in the plumbing. Depending on the manufacturer or plumbing configuration will determine the easiest way to accomplish this. The concept is the same, help the water to start moving. Either relieve the air down low, i usually loosen the pump drain plug until water sprays out or force water through the plumbing in the natural direction of water flow. Those little 24 hour circulation pumps are usually the biggest culprit for this problem.
Apr 25, 2017 | Pool & Spa
The spa will not start - the pump is definitely connected to working power and the last time i tried it worked fine. However today when I push the on button nothing happens?
When you say nothing happens, I wonder if the unit is making any sound at all or do you mean there is no water flow? If there is no water flow in your hot tub or spa then it could be just a simple air lock. Often when you drain your hot tub or spa you have to prime the system afterwards, this includes the pump but may also include the suction lines. The suction lines can develop an airlock in the upper portions of the suction line. To remove an airlock you simply force water into the suction line or release the air in the line by opening a union. Hot Tub Repair 101 What is an E6 or Error 6 Code Mean
Additionally, you could need new hot tub filters. If the filters are dirty and water flow is restricted your power pak may shut itself down as well. This can be as simple as cleaning your filters or replacing them. Hot Tub Filters
Here are a few things to consider
  • release any air locks
  • clean filters
  • make sure there is no obstructions in the lines
  • check to make sure GFCI is operational
I hope this helps.
Dec 26, 2015 | Pool & Spa
Does not drain
Hello, the problem is gravity. Do the following test: disconnect the drain hose from the PVC drainage. Then bring the end of the drain hose as low as possible closer to the ground, preferably place a tilted bucket so you can catch the water instead of just spilling it on the floor. If the draining occurs, then the issue is gravity.
Solution: lift the dishwasher by placing it on a dolly or wood frame and see if the height is enough for the water to drain itself by gravity force.
Or > install a draining pump. Costly but effective.
Dec 15, 2013 | Lamber F92EK Under Counter Commercial...
Leaking from freezer bottom on inside. cleaned hole on bottom of freezer. last 3 days then leaks again.
I've seen this problem repeatedly, all you can do is check that the drain pan is level and all the panels are installed properly so that the defrost water can gravity feed down the drain, look things over carefully check for moved or misiing gasket material
Jun 22, 2011 | Refrigerators
Plugged in our EZ Spa for first time - panel shows 'SN'
Open your drain for a moment till you get water or force water into the skimmer. If you have an air lock in the pipes this will stop the spa from working.
Jun 25, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
Must pump remain below water level to work properly
I believe those pumps have no suction, and only pump out, thus they need to be primed to work. Gravity primes the modern ones. In the older ones, you primed them and essentially set up a siphon to feed it. So, yes, I believe they do need to be below water level.
Nov 25, 2009 | Intex Krystal Clear Model 635 Pool Filter...
After I drained and cleaned my "Jacuzzi 220" I filled it and got a FL2 code and now only half my jets work. Is it as simple to fix as disconnecting the pressure switch and reattaching? Thanks, Richard
You probably need to run water into the skimmer to force air out of the suction line. sounds like one of the pumps is not priming due to air lock. When you drain the spa, get into the habit of running water into the skimmer when you start refilling it.
You can get it to prime by loosening the discharge side pump union until the air is out, then re-tighten. The FL2 code is a "flow" error for the circ pump.
Oct 25, 2009 | Pool & Spa
Is it possible to contaminate the membrane and filters by placing drain under pressure in order to clear and forcing water out the overflow on the side of the faucet of the whre 25 Reverse osmosis system
OK, now I understand. First, on the Reverse Osmosis Membrane Housing Outlet Ports there is only a Check Valve attached to the Permeate (Pure Water) Port, not the Concentrate Port (Drain Water). The Permeate line is what fills the storage tank, so you don't want back pressure from the tank reversing into the membrane filter which could severely damage it. So, there is a high Risk for Sewer Water to Back-flow into the Membrane Filter and Contaminate it as it is discharging water to the sewer drain if there is any noticeable pressure restriction in the drain distribution manifold. Second, this is why "Air-Gap" Faucets are supposed to be used when installing Reverse Osmosis Systems. With an Air-Gap Faucet, there are three (3) attachments for tubing at the base of the faucet, and a small hole drilled out underneath the lever or handle of the faucet. The 1/4" pressurized drain line tube from the RO System attaches to the 1/4" barbed fitting under the faucet base, then a 3/8" drain line tube attaches to the 3/8" barbed fitting. So when the drain water is pumped up to the faucet under pressure, it returns to the sewer line under Gravity, or No Back Pressure. Then, if the plumbing becomes restricted in any way that the RO Unit can't drain into the sewer under gravity feed, the hole drilled in the base of the faucet allows the back pressure to be escaped to the atmosphere, and if necessary drain water out of the hole until the plumbing pressure restriction can be resolved. This eliminates the possibility of a reverse flow pressure situation from occurring. Hope this helps, and you can always visit us online at www.puresafe.com We have filter cartridges for all makes and models of RO Systems, and 1/2 micron filters that no one else in the trade is using at this time. Thanks, Victor
Aug 05, 2009 | Whirlpool WED6400S Electric Dryer
My skimmer line is stopped up, it will not skim from the top, the bottomline is fine. Could the valve havr something to do with that. Can I disassemble the valve and go in the line from the valve back to...
IT COULD BE THAT THERE IS SOMTHING IN THE LINE IF YOU ARE NOT LOOSING WATER IT SHOULD NOT BE A BREAK IN THE LINE IF USING A WET VAC YOU HAVE TO MAKE SURE THAT WHEN TRYING TO VAC OR BLOW AIR YOU HAVE TO BE AIR TIGHT W FORCE A RAG ARUOND HOSE YOU MAY ALSO HAVE A AIR LOCK IF YOUR JUST OPENING THESE ARE CLEARED BY TAKING A GARDEN HOSE STICKING IT INTO SKIMMER WATER ON RAG AROUND HOSE TO MAKE TIGHT AND FILLING PUMP CUP TURN OFF BOTTOM LINE IF YOU CAN AND REPEAT TILL IT CLEARS
Jun 22, 2009 | Pool & Spa
No jet flow hot springs highlife 1990
you might have an air lock, when you first start filling the spa, start the water running in the skimmer first. that should force air out of the pump and should pick up prime right away. if not, you may have a valve problem.
Mar 30, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
