Question about Dell Inspiron 530 Desktop Computer
Usb powered speakers will not power up - Dell Inspiron 530 Desktop Computer
  • 186 Answers
Is there a on switch connection in write place check it ;
Posted on May 02, 2010
Can I connect original Harmon/Kardon Sound Sticks speakers with a 3.5 mm headphone-type jack instead of the USB it came with?
USB speakers are a different animal to standard passive or active speakers.
The USB cable will carry power and a digital signal and the speakers have circuitry to convert this into a stereo analogue signal the speakers require.
Normal active computer speakers with a 3.5 mm jack plug obtain the power from an independent power source, passive speakers require no additional power, but in both cases they use an analogue signal from the sound card.
The short answer you wanted is no...
Mar 27, 2016 | Audio Players & Recorders
My speakers will not power on
Are they powered from the USB cable, or from a separate DC jack? If it's a USB cable try using another. if still not working, try them on another computer. If they still don't work after that, they're faulty.
If they're powered from a DC jack, try another power adaptor.
Aug 24, 2014 | Altec Lansing Avs200w 2-piece Multimedia...
No Power to my speakers
If you are using USB 2.0 Powered speakers the internal mini-amplifier could be defective. Try using the speakers on a DVD player, or other audio device and see if you get the same results. Check to see that the USB port on your Computer is Active and responding correctly. Lastly if a Speaker set is USB 3.0 some may not be 2.0 backward compatible. The speakers are fully dependent on the power amplifier within the device.
Dec 15, 2013 | HP MULTIMEDIA SPEAKER 2.0
I had ordered an altec lansing 1220 speakers from flipkart. While i plugged in the speakers there was no power input to the system....hence it didn't work...when I checked on altec lansing website it...
This speaker is using a USB to draw its power. You can try using other USB ports on the computer or use USB chargers (Apple, HTC, Android phones, etc) to test it, if all else fail then you may need to return it because its defective.
Aug 27, 2011 | Altec Lansing BXR1220 2 Speakers
1. my computer wont recognize my bose speakers in the usb port, probably due to the reason that when the usb is plugged in or out a popup comes up saying the usb is drawing too much power from my computer...
This type of speaker set up needs what is called a "Powered USB Hub". It has to do with the amount of milli amps needed to run the speakers. USB ports in the typical Laptop are not capable of that much power output. Has nothing to do with normal low power devices, mp3, phones, thumb drives. do not draw much power from the port. There is 5 volts there to charge phones and the like but not run powered speakers. Hope this is clear as mud, and hope it helps Fix Ya up.
Jun 20, 2011 | Bose Companion® 5 2.1 Speakers
I cant install them?
The CA-2016 desktop 2-piece system it is a USB powered amplifier that draws the power through a USB cable. No batteries or AC power source/wires are required which leaves the desk top clean. The speaker system is magnetically shielded and has a LED power indicator. This being said setup the speakers plug in the USB cable, notice if the LED power indictor light is on. Adjust volume control on speakers and on your computer ( make sure your not muted ). PC's have a lot of different media players that can and will effect the volume control so if one or more of those items are adjusted to low volume or muted, there will be little to no output to your speakers.
Dec 05, 2010 | Cyber Acoustics CA-2016 Computer Speakers
No sound from the CA speakers - but controls still work!
Hello there!
First things first!
Just reinstall the USB driver for this speakers, and enable sound on multimedia, NOT muted. pop up volume.
RMS speakers if problem continue.
1.0 usb?
2.0 usb?
Feb 18, 2008 | Cyber Acoustics Portable USB Powered...
They just stopped working!
is your computer old? Are The Speakers old? Is Your USB Not Dusty? ( if is, blow on USB Port )
Dec 15, 2007 | Benwin SP691 2-Pc USB Powered Speakers...
Durabrand 2.0 CH USB Speaker System
Hi, Based on your post/description, the Durabrand 2.0 CH USB Speaker System is a basic external speaker that plugs into your PC's speaker/headset output (green jack). It is supposed to get its power from the +5VDC supplied by the USB port. Some USB port have current limiting therefore it can be anywhere from 10 - 500 mA. The power requirement of your external Durabrand speaker maybe beyond what the PC's USB ports can supply. It does not need to be recognized by the OS since it only connects to the USB to get power but there is no data interaction. Perhaps what you can do is get an external +5VDC power supply whose output is in USB type connector. The current rating would depend on the requirement of your speaker. Offhand, if the speakers are not that big, probably a 1 Amp would do. This is of course assuming that the Durabrand speaker system is fully functional. If with an external power supply it is still a no go and you have verified that sound do come out of your green jack (with the use of an ordinary headset), then the Durabrand is defective. Hope this be of help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 22, 2007 | Denon AVR-987 Receiver
Dell Inspiron 530 Desktop Computer   Logo
19 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
