Question about Navman iCN 520 GPS Receiver
Navman510 hi could you help me,on the gps screen on my navman has the message error no nmea data do you know what that means because it takes about half to a hour to get a signal cheers
    Problem Solver:
  • 6 Answers
It will take ages to find a signal the first time it tried. Once locked on it should pick up the sats really quickly the next time you turn on the device.
If you turn it off completely (battery switch to off) then it will take ages again the next time it is turned on.
Hope this helps.
Posted on Jul 09, 2008
Uniden um425 vhf to navman trackfish 6600 what coloured wires do I connect.
Hi Gil!
Easy peasy.
From your 6600, the data sends are the white wire NMEA (+) and the black wire (-). There are two black wires. Doesn't matter which one you use as they're interconnected anyway.
To your UM425, the green wire is NMEA in and the bare wire is ground.
white from 6600 to green and
black from 6600 to bare.
Hope this helps you out.
Jan 09, 2015 | Uniden Boating
What is the connection path from Garmin 72 to raymarine c80, using NMEA 1083
I'm taking this as you want to send the gps information to your C80 not receive from the C80? If this is the case the brown wire on the garmin is the nmea data out +. The Black wire is considered nmea out neg (-) of the garmin. So hook the garmin brown to the white on the raymarine. Hook the black from the garmin to the green on the raymarine. That means you are outputting lat/long info to the raymarine from the garmin.
Jan 14, 2012 | Raymarine C80 GPS Receiver
I have a SI-TEX black box receiver and I'd like to connect it to a Garmin GPS chartplotter. The SI-TEX black box receiver instructions at one point say:"If the GPS has a NMEA output (or NMEA REF) connect...
Yes, the NMEA- output (I think you lefy uot the "-" in your questoin), anyway, the NMEA - or NMEA negative or NMEA ref is hooked to battery supply ground.
Dont forget to program the Garmin to look for 48,000 baud data.
Jan 10, 2010 | Boating
Continual "waiting for gps " message
the message should also read no mnsa data first... if these units are not in continual use,they get corrupt for some reason. all you can do is hope the gps fix will work itself out,otherwisw buy a new unit.
Dec 26, 2008 | Navman ICN510 GPS Receiver
Navman se 3450 comm and baud settings
The correct baud rate etc settings are 57600, 8, N, 1 (ie 57600 baud, 8 bit, no parity, 1 stop bit). You can verify this and see other details of specifications at or
The other thing you may have forgotten that you need is to install the Navman driver - unless you have done this, you will get a "card not recognised" error when you slide on the GPS sleeve. This driver, version 3.1.6, can be downloaded from the Navman website.
I don't think you need to set the COM port number as a number, rather you select the Navman driver and it automatically knows which COM port is associated. This is COM 6 on my setup, but might vary between devices?
The other thing that some GPS software requires is to know the "type of GPS receiver" - this is "Other NMEA"
Dec 08, 2008 | Navman 3450 GPS Receiver
I have a lowrance 3600c igps linked to a navman vhf 7100 but for some reason it has stoped giving information on my position to the radio. I have cheked all the wires are ok it was fine last week when i...
If your GPS was sending NMEA data and now is not, your NMEA configuration may have been inadvertently changed, either due to a user error, or possibly a software glitch.
You can configure the unit to use specific NMEA sentences.
1. Press MENU|MENU| then scroll down to SYSTEM SETUP and press |ENT.
2. Scroll down to COMMUNICATIONS PORT, then press ENT then scroll down to CONFIGURE NMEA and press ENT.
3. A menu appears showing the prefixes of the available NMEA sentences.
A check mark next to a prefix means the prefix is in use. Use the arrow keys (on the track pad) like a mouse to select a prefix, then press ENT to turn off the prefix. (Press
ENT again to check the box and turn a prefix on.)
I'm not exactly sure how the data is labeled on that model but you looking for a sentence that looks like an abbreviation for GPS Lat Lon (it may be something like GPLL). If you're not sure, turn them all on, the VHF will only use the sentences it recognizes.
4. When the desired prefixes are checked or unchecked, press
EXIT|EXIT|EXIT|EXIT to return to the previous page.
let me know if this worked for you, or if I may be of further assistance.
Aug 18, 2008 | Lowrance GPS
Navman510 will not charge
cannot seem to be able to put all of the postcode cannot find anyone to show me how to do it
Aug 09, 2008 | Navman ICN510 GPS Receiver
NMEA communication does not work ( but file transfer is OK)
Try rebooting windows, with gps off connect the cable to gps.
Go out side get a good gps signals on nav menu.
Set the gps communications menu to , nmea, 2.1
Plug the device into a good usb port.
If you look under modems, in control panel you should see a new modem called explorist xxx
If you look at the properties for that you can see its com port number.
I just tried this program
and it views nmea from the explorist, just set the com port to the one in the explorist modem .
Jun 06, 2008 | Magellan eXplorist 500 GPS Receiver
No guage screen on my garmin 4208
Need more info:
Is your Garmin hooked up to your engine's computer via an NMEA 2000 data cable?
The gauge option will not appear in the menu if the GPS does not recognise the data coming from your engine. (If you turn on the GPS simulator, you should see the gauges on that screen.)
There are 3 possible reasons that the gauges do not appear in the menu:
1) improper wiring between engine and gauges.
2) GPS has not been set up to receive data in the GPS's NMEA setup menu.
3) Engine has not been set up to send NMEA data.
This is a relatively new feature that only works on newer engines that are NMEA 2000 capable, such as Volvo and Evinrude Etec.  The engines usually need an optional instrument package to make use of the NMEA 2000 system.
We're just scratching the surface here, please reply with any questions.
Oct 22, 2007 | Garmin GPSMAP 4208 GPS Receiver
Navman iCN 520 GPS Receiver Logo
202 people viewed this question
Top Navman GPS Experts
Martin Murray
Are you a Navman GPS Expert? Answer questions, earn points and help others
