Question about LG 37LG30 37 in. LCD HDTV
No power? Went to turn today my 37" LG tv on and it seem to have no power what so ever? tried it again about an hour later and now i have a standby light coming on, but when i press power on, it seems to flash once like its was just about to come on, then flash 3 more times then go back to being on standby. some times the standby light comes on and when i press power on it just loses all power and i have no standby light at all? can you help me please. thanks.
  • LG Master
  • 3,897 Answers
Power board failed check the main board the 5 volt side may have a few capacitors blown. check all of them as usually when 1 starts to go rest can follow don't cost much to replace. the ones next to the heat sink are first to start to wear out, use the ratings that are on the old capacitors and replace the same 105c temp rating. and rating to failed capacitors, you will see the faulty capacitors they will have blown bowed tops or a liquid on the bottom of them
Posted on Jun 21, 2017
3 Suggested Answers
circuitworld
  • 335 Answers
SOURCE: hello. I got a Lg
First disconnect all power to the TV for about 30 minutes this gives the filter caps time to discharge as this resets the logic section upon power-up. After 30 min try powering back up if you still have the same problem then there's a problem with the power supply board. You may have some caps with high ESR levels which can cause this kind of fault. But it could other components on the power board causing a similar fault like switching transformers that have shorted, or opened either which can cause EDDY Currents which will cause feedback in opto-couplers and shut the TV down. Let me know what results you get after the 30 minute power-down.
Posted on Oct 18, 2010
budmrtn
  • 11361 Answers
SOURCE: LG 37 lcd. whenever i
First place to check will be the power supply module, need to verify if it is putting out staedy DC first. This can be due to simple thing such as bad caps.
Please read my guide for more details.
Service manual: www.elektrotanya.com
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Posted on Aug 01, 2011
I have a LG 32LG3000 LCD TV and the power light continually flashed red and the tv does not turn on.
Tries tv unplug,replug it back like about an hour later.See,if the tv will resetting self and working again.Not.The tv power supply board it is the causes and the problems.That the board where the tv power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Sep 06, 2011 | LG 32LG30 32 in. LCD HDTV
Power light, keeps flashing red to blue
Tries tv unplug,replug it back like about an hour later.By letting tv resetting itself.Tv should be working again.If still have the same problems.The power supply board is the causes and problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Feb 17, 2011 | LG 37LG30 37 in. LCD HDTV
LG 37LC7D 37-inch 720p LCD HDTV
Unplug it for about an hour to let it reset itself and try again, if it still has problem then you will have to open it up or take it to the repair shop. The power supply module will have to be looked at first to make sure all the voltages are present. Right now the 5vdc standby power supply is working and may be partially function processor.
Please see my basic troubleshooting guide here:
http://s807.photobucket.com/home/budm/allalbums
Jul 10, 2010 | LG 37LC7D 37 in. LCD HDTV
40'' Sony Bravia goes into standby with the light blinking 9 times
I finally managed to solve this problem by unplugging everything - scarts - HDD cables - power etc and left it for an hour. When I turned it back on again the problem had sorted itself out.
Sep 30, 2009 | Sony Televison & Video
TV wont turn on with power button or remote
Try putting the cables back where they were. After that re-route them again but this time use the manuel.
If that doesn't work, consult the TV's manuel.
Jul 04, 2009 | ViewSonic N3735W 37 in. LCD TV
LG LCD 37'' standby problem
if you want i will buy the tv from you
Nov 17, 2008 | LG 37LC7D 37 in. LCD HDTV
DELL 42 inch Plasma TV
I have a 42" LG LCD TV and just experienced this today. Watching cable, then the screen went to black, but audio continued. I pressed the guide button on my remote and pic came on with my guide menu. But then went to black again 10sec later and has remained that way for nearly an hour. Tried switching off both cable box and TV, disconnecting and reconnecting cables, but no luck. Finally unplugged mains, waited a minute, then turned back on. Everything seems normal now after the reboot. Phew.
Jan 17, 2008 | Sony KV-36XBR450 36" TV
Tv will not turn on
your tv needs to be repair again power supply problem or circuit.good luck.
Apr 04, 2007 | Toshiba 37HLX95 37 in. LCD TV/DVD Combo
LG 37LG30 37 in. LCD HDTV Logo
82 people viewed this question
Computer Repairing
Computer Repairing
