Question about Dryers
I have a Kenmore Dryer (mod.# 110.96591220) that worked fine...until. Wife put in 2nd load of clothes and dryer will not start. I have checked voltage ect., and power is at the dryer.... don't know where to check from there.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. It seems to be the issue with the Thermal Fuse going bad and needs to be replaced. It is mounted to the exhaust duct inside the back cover panel. Also, often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 02, 2010
2009 Kenmore Dryer. Wondering why it seems to only work on 1 drying cycle? Everytime I try to put it on another cycle all the lights flash and beep...and nothing...
sounds like the washer might not be spinning the water out of the clothes good enough . 1 60 minute cycle should dry them more than dry enough .
Oct 18, 2015 | Kenmore 8804 5.8 cu. ft. Electric Dryer
Kenmore model# 96281100 elect. dryer
Jimbo, this dryer uses a cyling thermostat to turn the heater on and off. If your vent is pinched or clogged, or the vent to the outside is clogged, you are going to have long dry times and damp clothes. Try doing a load with the vent disconnected from the back of the dryer. If everything turns out ok, then it's a venting issue. Catriver
Sep 14, 2007 | Kenmore 63942 Dryer
Our Kenmore Front loader Dryer Mod # 110.61402310 i put our clothes in the Dryer and powered it on and then Nothing wont Power on
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released. hope it helps
Feb 13, 2015 | Kenmore Dryers
My wife dried a load of clothes took those out put in another load,dryer would not come on?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 08, 2010 | Kenmore 62602 Electric Dryer
Dryer won't start
Try 2 things to see what has happened.
1st listen for a click from the door switch just as the door opens or closes. (No click = no start)
2nd reach in and rotate the drum by hand just a little bit making sure you hear the motor also turn. Then try to restart the dryer.
If rotating the drum enabled you to start the dryer the motor switch is sticking.
Kelly
Feb 25, 2010 | Dryers
Kenmore mod 110 87870110 gas dryer- at first push
the vent could be plugged and unit is going into thermal overheat if it works in timed dry properly then the moistier sensor is faulty.
Dec 01, 2009 | Kenmore Dryers
Dryer wont start
there is not a reset button, but check your thermofuse. If it is blown replace it and clean your exhaust vent
Sep 28, 2009 | Whirlpool LER4634J Electric Dryer
Kenmore Dryer won't turn on
Hi...
This are the tipe on how to Troubleshot dryer follow the steps below
IF the dryer is noisy
Level the dryer
Check the drum belt
Check the drum support rollers
Check the idler pulley
Check the glides
Check drum bearings
Check the blower
Check the baffles
If the dryer tumbles, but there is no heat
Check for proper air flow
Test the safety fuse
Test the thermostats
Test the centrifugal switch
Test the timer motor
Test the heating element
Good luck !!!!
Regards
PCmania
Jul 03, 2009 | Kenmore 63942 Dryer
Open Questions:
Dryers Logo
16 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
